πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
363 Posts 149 Posters 2.0m Views 149 Watching
  • H Offline
    hgdn
    Fredo6,
    Thanks so much for upgrading already useful toy!
    Have a nice day!
    • F Offline
      Frederik
      I see the same folder structure in WinZip v14.5...
      The JPP_Dir_17 is empty, but it's there...
      Any way... Thanks A LOT for this... πŸ˜„
      Cheers
      Kim Frederik
      • F Offline
        I just posted a 'fresh' zip file in the main post.
          I can confirm that the unwanted empty v17 folder is no longer in the zip file πŸ˜„
          • W Offline
            winnie70020807
            thanks~
              RizkySyahputra
              it's amazing πŸ‘ πŸ˜›
              • F Offline
                NEW RELEASE
                version 2.0a - 16 Jul 11: Fixes for problems when applying to convoluted shapes. The issues were signaled by ThomThom.
                Note that the parameter "angle of influence" is no longer used.
                See main post for download.
                  Thanks Fredo. Much appreciated πŸ‘
                    baz
                    Great stuff Fredo, thanks.
                    Baz
                    • F Offline
                      NEW RELEASE
                      version 2.0b - 17 Jul 11: Fixes for problems when applying to convoluted shapes. The issues were signaled by ThomThom.
                      Version 2.0b also includes the Italian translation
                        πŸ‘ πŸ‘
                          pep75
                          Fredo is the man!
                          grtzzz
                          Pep
                          • N Offline
                            niks
                            just wanted to say THANK YOU πŸ‘Š
                              BBLV
                              Will this plugin allow me to perform a 1/2" roundover on perpendicular intersecting edges?
                              Example of desired finished result:
                              http://www.glumber.com/WoodTopSubpages/Details/EdgeTreatmentData/EdgeTreatmentSubPages/Edge_Profile_Photos/Roundover/HalfInchRoundover.jpg
                              • mitcorbM Offline
                                mitcorb
                                Hi, BBLV:
                                You will want to try Fredo's Round Corners, which will do that, plus chamfer, plus radiused corner and edges. Joint PushPull is a multiface simultaneous extrusion tool.
                                  rock1
                                  using this plugin when i push pull a curved surface i have to manually delete the original surface that was push pulled. is there any way that this plugin jointpushpulls just like a normal push. and not like a ctrl+pull that makes a new face? For example i just want this yellow extrusion to be a part of the whole solid.
                                  Signature removed by SCF Admin
                                    With face and tool selected...
                                    Press TAB to open dialogue box
                                    Choose Finishing Options
                                    Pick option
                                      rock1
                                      Pick option
                                      http://i.imgur.com/BOHLQ.jpg
                                      I chose thickening, then erase original faces, then keep original faces. All the options are giving the same results with the lines :?
                                        What is your question? Your image doesn't show anything useful as far as a problem is concerned.
                                          It's not a telepathic tool - just erase lines and faces that YOU don't want!
                                          • 18
                                          • 19
                                          • 6 / 19
