    [Plugin] Work Plane
    183 Posts 32 Posters 148.4k Views 32 Watching
      You gave Susan a tophat? Classy! ๐Ÿ˜„
        DIEGO-RODRIGUEZ
        @diego-rodriguez said:
        tig, really thank you very much.
        to hear any suggestions on this tool. thank you very much.
        I found only one bug. does not draw the rectangle tool on inclined coplanar faces.
        i'm thinking this is some sort of glitch with sketchup itself regarding the orientation of the bounding box.. you can recreate this behavior without using WorkPlane.. see attached skp
        yes. and if it works the other tools (circle, polygon, arch)
        However,
        if the geometry is generated as a group or component directly from ruby, SI can draw shapes on inclined planes.
        if you later apply any modification to this geometry (move, scale, ungroup, etc. ..) this property is lost.
        Le adjunto imรกgenes de dos plugins que probรฉ.
        polar zonohedron
        http://img832.imageshack.us/img832/2558/52784550.gif
        work plane 1.5
        http://img834.imageshack.us/img834/3791/94618514.gif
        • EarthMoverE Offline
          EarthMover
          Diego, the "Rotated Rectangle" tool works well on sloped planes. (Even after it's been manipulated)
          Content Creator at Skapeup
            EarthMover
            ๐Ÿ˜„ I had her out partying last night and she forgot to take it off! ๐Ÿ˜ณ
              Little problem ๐Ÿ˜„
              Rotation from the context menu is not on the Coplanar plan of the Work plane (when this one is inclined) ๐Ÿ˜‰
              it would have been too simple ๐Ÿ’š
              • CadFatherC Offline
                CadFather
                you're right Diego, and that's quite a nasty one
                  The glitch where you can't align a 2pt-rectangle [or sometimes a circle] onto a sloping face if it's a group/component-instance and its plane doesn't pass through the origin and is not axial on the x_axis [ ๐Ÿ˜’ ] is a known problem with both v7 and v8 - it's logged with them and hopefully a fix might appear in a maintenance release...
                  The problem isn't specific to this tool - it's general and is easily reproduced by making objects manually and trying to snap 2pt-rectangles to their sloping faces in different orientations... [however, a 3pt-rectangle will work OK as it's not 'built-in' and its code is in fact the starting point for my WorkPlane's tool itself] ๐Ÿ˜ฒ ๐Ÿ˜ข
                  • jeff hammondJ Offline
                    However,
                    really, i think it's beyond wether or not the shape was created via ruby..
                    also, you can move a group and still have it accept the rectangle tool IF you move it along the green axis.. it's a su glitch..
                    look at this video for more weird behavior.. depending on the xy orientation, the rectangle may or may not work..
                    tig can probably fix this but it's gonna be him fighting the su bug instead of fixing a bug in his script..
                    [flash=660,405:vu38m2u3]http://www.youtube.com/v/4ZFhL-rD2PM?fs=1&hl=en_US&color1=0x2b405b&color2=0x6b8ab6&border=1[/flash:vu38m2u3]
                      CadFather
                      ..seems worse in su8
                        DIEGO-RODRIGUEZ
                        strange.
                        I have reported this error:
                        http://sketchup.google.com/support/bin/request.py?contact_type=bug
                        and his response was:
                        "Hi Diego:
                        Thank you for your message and attach particular image capture.
                        We've been very helpful!
                        Answering your question: the behavior you encountered is a
                        normal behavior.
                        Geometry within a group or component does not relate to the same
                        so
                        geometry itself.
                        If you want to draw a rectangle, tilted in one of his drawings, you
                        suggest you draw the geometry and twist it to match the
                        plane. Another option is to do it without going to the group.
                        I hope these tips have been helpful!
                        Regards,
                        The Google Team
                        any programmer can tell google about this problem?
                        probably have more success than me.
                          [all this glitch talk aside...]
                          it might be nice if tig could make a 3point rectangle tool (or does one already exist?).. it would be able to draw properly on the work plane but it's use would extend far beyond that..
                          there are plenty of instances where the normal fails and a 3pt version would easily accomplish it..
                          it'd basically be just like the first steps of WorkPlane so most of the coding is already done anyway (well, it at least seems that way for someone that doesn't write code ๐Ÿ˜‰ )
                            [edit - lol.. it's almost already in 2D tools] ๐Ÿ˜‰
                              EarthMover
                              Jeff, check here. That is what I'm using in the last video I posted - http://download.sketchup.com/downloads/downloads/rubyscripts/rectangle.zip Shows up as "Rotated Rectangle" in the Draw Menu.
                              (It's also included in CadFather's CD Draw tools)
                              • BoxB Offline
                                Another excellent Tig Tool.
                                Just one question/suggestion, is it possible to have numbering added to the grid.
                                When I'm putting together a ship I have over 300 frame references set at .64m, to have those frame numbers automatically on the grid would be a godsend.
                                  hahaha
                                  i've wanted that tool since i started using sketchup.. looks like it's been around at least that long ๐Ÿ˜ณ
                                  [diego, i'm thinking this is the best solution at the moment for drawing rectangles on the workplanes.. 'โ‡งR' seems to be a perfect shortcut (that is if you're used to 'R' for ]
                                  • kenK Offline
                                    ken
                                    Well, this plugin started out as a reliable, jeans wearing working plugin. Now it is a $20,000.00 โ€œSay Yes to the Dressโ€ wedding gown.
                                    Thanks TIG
                                    • mitcorbM Offline
                                      mitcorb
                                      I woke up this morning, 5:00am GMT-6, saw the latest version 1.6, downloaded it as zip only, placed it in my collecting folder, go out of town for 5 hours and the damned thing is obsolete 3 times over!
                                      Talk about your "worktigers" ๐Ÿ˜†
                                      TIG, you are one dedicated guy. And you are appreciated!
                                        Here's v2.0 http://forums.sketchucation.com/viewtopic.php?p=274345#p274345
                                        Thought I'd post it while it's hot...
                                        Three 'Rotate Selected X/Y/Z' options are now added for the group's 3 axes; each one rotates the WorkPlane about its appropriate axis...
                                        A new 'Move Selected' tool is added to the context-menu: this lets you move a selected WorkPlane although for other tools it is 'locked', done as the main Move tool - by picking two points, or one-point + typed_distance: it draws a temporary outline of the original WorkPlane location as you move it around, so you can snap to it if needed.
                                        ๐Ÿค“
                                          Ben Ritter
                                          Yeah, now here's I guy who love his work. Or, he has nothing else to do ๐Ÿ˜‰
                                          Thank you so much.
                                            EarthMover
                                            ๐Ÿ˜ Getting better and better!
                                            In the next release, when you bring up the "move" tool, can you have the "move click" drop in temporary world axis clines? It would make moving the thing a lot easier.
                                            I also think it might behoove workflow to have the right click options added to the toolbar. (CadFather?) What do the rest of you guys think? Which way is easier?
                                            ๐Ÿ˜† Poor TIG.....we've got to be making him nuts! I hope everyone remembers to get the wallet out and donate to the man for all his hard work!!!!!!!
                                            • 4 / 10
