    [Plugin] Work Plane
    183 Posts 32 Posters 157.7k Views 32 Watching
    • EarthMoverE
      EarthMover
      Found another great use for work planes today......setting up spot lights! β˜€
      Content Creator at Skapeup
        Here's v1.7 http://forums.sketchucation.com/viewtopic.php?p=274345#p274345
        'New' and 'Adjust' options have been added to context-menu.
        'New' lets you make a new WorkPlane on the fly...
        'Adjust' lets you change one selected WorkPlane's Settings [Plane's h/w and Grid's h/w]
        Cline 'guide' rectangle and axes are now drawn whilst you are picking the points.
        The WorkPlane Grid is now always centered on pt-1, even if a grid-dim does not divide exactly into the plane-dim.
        • EarthMoverE
          EarthMover
          Perfect TIG....thanks!!! (Don't forget to update the post to 1.7)
            Pilou it's a glitch... v1.8 is in the pipeline now... πŸ˜’
              Ok So wait an see πŸ˜„
                Adjusment selected is curious πŸ˜„
                Here Grid was 10 10 , with 1 1 then 10 10 , with 3 3
                I understand that I have that asked (why there is not neat (3*3)
                but
                seems fill grid must be fully filled or red frame adjusted to 3 3 + rest(?)
                Hole is perturbating πŸ˜„
                Not Delect selected?
                And option Center first point(actual default) or Framed face will be a must πŸ˜„(avoid to play with and unlock)
                • EarthMoverE
                  EarthMover
                  TIG, the planar / perpendicular flip is great. Would it be terribly difficult to add rotating of work plane in 15 degree increments to the post adjustment options? If it's a PITA, don't worry about it.
                  BTW, I was looking through the code for this plugin and it's amazing the amount of thought and strategy that goes into each little feature. I really appreciate the work you are putting into this and all your plugin releases.
                    Here's v1.8 http://forums.sketchucation.com/viewtopic.php?p=274345#p274345
                    The 'Rounding' glitch with some Adjusted WorkPlanes Grids fixed.
                    All grids should now be centered on point-1 and the edge grids made smaller to suit if the plane's dim itself is not a multiple of the grid...
                      Here's v1.9 http://forums.sketchucation.com/viewtopic.php?p=274345#p274345
                      A 'Rotate Selected' option has been added to the context-menu.
                      You can type in any angle in the dialog and the selected WorkPlane rotates about its axis [pt1>>pt2] by that angle...
                        My 1.8 live only 10 minutes πŸ’š
                        I don't very well understand the interest of the first center point but as I can rescale all the plane no problem πŸ˜„
                        I abuse but a Polar Grid will be also fine if you have some free times β˜€
                        http://www.utc.fr/tsibh/public/tsibh/08/rapport_stage/laurent_neuge/CQ_radiologie_conventionnel_fichier/39_Mire_de_Wellhofer.jpg
                          DIEGO-RODRIGUEZ
                          tig, really thank you very much.
                          to hear any suggestions on this tool. thank you very much.
                          I found only one bug. does not draw the rectangle tool on inclined coplanar faces.
                          I use sketchup8
                          Draw rectangle inclined coplanar workplane
                          versions work : 1.5 or lower
                          versions does not work : 1.6 or higher
                          • CadFatherC
                            CadFather
                            Tig, you are so fast even you can't keep up with the versions as you make them!
                            • jeff hammondJ
                              i'm thinking this is some sort of glitch with sketchup itself regarding the orientation of the bounding box.. you can recreate this behavior without using WorkPlane.. see attached skp
                              planes.skp
                                You gave Susan a tophat? Classy! πŸ˜„
                                  DIEGO-RODRIGUEZ
                                  yes. and if it works the other tools (circle, polygon, arch)
                                  However,
                                  if the geometry is generated as a group or component directly from ruby, SI can draw shapes on inclined planes.
                                  if you later apply any modification to this geometry (move, scale, ungroup, etc. ..) this property is lost.
                                  Le adjunto imΓ‘genes de dos plugins que probΓ©.
                                  polar zonohedron
                                  http://img832.imageshack.us/img832/2558/52784550.gif
                                  work plane 1.5
                                  http://img834.imageshack.us/img834/3791/94618514.gif
                                  • EarthMoverE
                                    EarthMover
                                    Diego, the "Rotated Rectangle" tool works well on sloped planes. (Even after it's been manipulated)
                                    • EarthMoverE
                                      EarthMover
                                      πŸ˜„ I had her out partying last night and she forgot to take it off! 😳
                                        Little problem πŸ˜„
                                        Rotation from the context menu is not on the Coplanar plan of the Work plane (when this one is inclined) πŸ˜‰
                                        it would have been too simple πŸ’š
                                        • CadFatherC
                                          CadFather
                                          you're right Diego, and that's quite a nasty one
                                            The glitch where you can't align a 2pt-rectangle [or sometimes a circle] onto a sloping face if it's a group/component-instance and its plane doesn't pass through the origin and is not axial on the x_axis [ πŸ˜’ ] is a known problem with both v7 and v8 - it's logged with them and hopefully a fix might appear in a maintenance release...
                                            The problem isn't specific to this tool - it's general and is easily reproduced by making objects manually and trying to snap 2pt-rectangles to their sloping faces in different orientations... [however, a 3pt-rectangle will work OK as it's not 'built-in' and its code is in fact the starting point for my WorkPlane's tool itself] 😲 😒
                                            • 4 / 10
