    [Plugin] Work Plane
    183 Posts 32 Posters 151.2k Views 32 Watching
      Pilou it's a glitch... v1.8 is in the pipeline now... πŸ˜’
        Ok So wait an see πŸ˜„
          Adjusment selected is curious πŸ˜„
          Here Grid was 10 10 , with 1 1 then 10 10 , with 3 3
          I understand that I have that asked (why there is not neat (3*3)
          but
          seems fill grid must be fully filled or red frame adjusted to 3 3 + rest(?)
          Hole is perturbating πŸ˜„
          Not Delect selected?
          And option Center first point(actual default) or Framed face will be a must πŸ˜„(avoid to play with and unlock)
          • EarthMoverE Offline
            EarthMover
            TIG, the planar / perpendicular flip is great. Would it be terribly difficult to add rotating of work plane in 15 degree increments to the post adjustment options? If it's a PITA, don't worry about it.
            BTW, I was looking through the code for this plugin and it's amazing the amount of thought and strategy that goes into each little feature. I really appreciate the work you are putting into this and all your plugin releases.
            Content Creator at Skapeup
              Here's v1.8 http://forums.sketchucation.com/viewtopic.php?p=274345#p274345
              The 'Rounding' glitch with some Adjusted WorkPlanes Grids fixed.
              All grids should now be centered on point-1 and the edge grids made smaller to suit if the plane's dim itself is not a multiple of the grid...
                Here's v1.9 http://forums.sketchucation.com/viewtopic.php?p=274345#p274345
                A 'Rotate Selected' option has been added to the context-menu.
                You can type in any angle in the dialog and the selected WorkPlane rotates about its axis [pt1>>pt2] by that angle...
                  My 1.8 live only 10 minutes πŸ’š
                  I don't very well understand the interest of the first center point but as I can rescale all the plane no problem πŸ˜„
                  I abuse but a Polar Grid will be also fine if you have some free times β˜€
                  http://www.utc.fr/tsibh/public/tsibh/08/rapport_stage/laurent_neuge/CQ_radiologie_conventionnel_fichier/39_Mire_de_Wellhofer.jpg
                    DIEGO-RODRIGUEZ
                    tig, really thank you very much.
                    to hear any suggestions on this tool. thank you very much.
                    I found only one bug. does not draw the rectangle tool on inclined coplanar faces.
                    I use sketchup8
                    Draw rectangle inclined coplanar workplane
                    versions work : 1.5 or lower
                    versions does not work : 1.6 or higher
                    • CadFatherC Offline
                      CadFather
                      Tig, you are so fast even you can't keep up with the versions as you make them!
                      • jeff hammondJ Offline
                        i'm thinking this is some sort of glitch with sketchup itself regarding the orientation of the bounding box.. you can recreate this behavior without using WorkPlane.. see attached skp
                        planes.skp
                          You gave Susan a tophat? Classy! πŸ˜„
                            DIEGO-RODRIGUEZ
                            yes. and if it works the other tools (circle, polygon, arch)
                            However,
                            if the geometry is generated as a group or component directly from ruby, SI can draw shapes on inclined planes.
                            if you later apply any modification to this geometry (move, scale, ungroup, etc. ..) this property is lost.
                            Le adjunto imΓ‘genes de dos plugins que probΓ©.
                            polar zonohedron
                            http://img832.imageshack.us/img832/2558/52784550.gif
                            work plane 1.5
                            http://img834.imageshack.us/img834/3791/94618514.gif
                              EarthMover
                              Diego, the "Rotated Rectangle" tool works well on sloped planes. (Even after it's been manipulated)
                                EarthMover
                                πŸ˜„ I had her out partying last night and she forgot to take it off! 😳
                                  Little problem πŸ˜„
                                  Rotation from the context menu is not on the Coplanar plan of the Work plane (when this one is inclined) πŸ˜‰
                                  it would have been too simple πŸ’š
                                    CadFather
                                    you're right Diego, and that's quite a nasty one
                                      The glitch where you can't align a 2pt-rectangle [or sometimes a circle] onto a sloping face if it's a group/component-instance and its plane doesn't pass through the origin and is not axial on the x_axis [ πŸ˜’ ] is a known problem with both v7 and v8 - it's logged with them and hopefully a fix might appear in a maintenance release...
                                      The problem isn't specific to this tool - it's general and is easily reproduced by making objects manually and trying to snap 2pt-rectangles to their sloping faces in different orientations... [however, a 3pt-rectangle will work OK as it's not 'built-in' and its code is in fact the starting point for my WorkPlane's tool itself] 😲 😒
                                        However,
                                        really, i think it's beyond wether or not the shape was created via ruby..
                                        also, you can move a group and still have it accept the rectangle tool IF you move it along the green axis.. it's a su glitch..
                                        look at this video for more weird behavior.. depending on the xy orientation, the rectangle may or may not work..
                                        tig can probably fix this but it's gonna be him fighting the su bug instead of fixing a bug in his script..
                                        [flash=660,405:vu38m2u3]http://www.youtube.com/v/4ZFhL-rD2PM?fs=1&hl=en_US&color1=0x2b405b&color2=0x6b8ab6&border=1[/flash:vu38m2u3]
                                          CadFather
                                          ..seems worse in su8
                                            DIEGO-RODRIGUEZ
                                            strange.
                                            I have reported this error:
                                            http://sketchup.google.com/support/bin/request.py?contact_type=bug
                                            and his response was:
                                            "Hi Diego:
                                            Thank you for your message and attach particular image capture.
                                            We've been very helpful!
                                            Answering your question: the behavior you encountered is a
                                            normal behavior.
                                            Geometry within a group or component does not relate to the same
                                            so
                                            geometry itself.
                                            If you want to draw a rectangle, tilted in one of his drawings, you
                                            suggest you draw the geometry and twist it to match the
                                            plane. Another option is to do it without going to the group.
                                            I hope these tips have been helpful!
                                            Regards,
                                            The Google Team
                                            any programmer can tell google about this problem?
                                            probably have more success than me.
                                            • 4 / 10
