    [Plugin] Work Plane
    183 Posts 32 Posters 135.9k Views 32 Watching
      DIEGO-RODRIGUEZ
      ooo, thank you very much Tig.
      and one more suggestion. only as a cosmetic.
      usage:
      run tool.
      I choose first point. > Previewing a ghost Workplane . (You can vary the size in vcv. For example 10,10) (units would use the current model)
      I choose the second point> to preview the grid phantom. (Divisions may vary)
      I choose the third point> is generated work plane
      • EarthMoverE Offline
        EarthMover
        Or, perhaps the first two clicks define the grid size automatically. This would make sense, as typically when working in a smaller space, you need a smaller gridding. Then from the context menu you can disable or adjust the grid size to suit.
        Content Creator at Skapeup
          DIEGO-RODRIGUEZ
          yes. this option looks interesting
            EarthMover
            Found another great use for work planes today......setting up spot lights! β˜€
              Here's v1.7 http://forums.sketchucation.com/viewtopic.php?p=274345#p274345
              'New' and 'Adjust' options have been added to context-menu.
              'New' lets you make a new WorkPlane on the fly...
              'Adjust' lets you change one selected WorkPlane's Settings [Plane's h/w and Grid's h/w]
              Cline 'guide' rectangle and axes are now drawn whilst you are picking the points.
              The WorkPlane Grid is now always centered on pt-1, even if a grid-dim does not divide exactly into the plane-dim.
                EarthMover
                Perfect TIG....thanks!!! (Don't forget to update the post to 1.7)
                  Pilou it's a glitch... v1.8 is in the pipeline now... πŸ˜’
                    Ok So wait an see πŸ˜„
                      Adjusment selected is curious πŸ˜„
                      Here Grid was 10 10 , with 1 1 then 10 10 , with 3 3
                      I understand that I have that asked (why there is not neat (3*3)
                      but
                      seems fill grid must be fully filled or red frame adjusted to 3 3 + rest(?)
                      Hole is perturbating πŸ˜„
                      Not Delect selected?
                      And option Center first point(actual default) or Framed face will be a must πŸ˜„(avoid to play with and unlock)
                        EarthMover
                        TIG, the planar / perpendicular flip is great. Would it be terribly difficult to add rotating of work plane in 15 degree increments to the post adjustment options? If it's a PITA, don't worry about it.
                        BTW, I was looking through the code for this plugin and it's amazing the amount of thought and strategy that goes into each little feature. I really appreciate the work you are putting into this and all your plugin releases.
                          Here's v1.8 http://forums.sketchucation.com/viewtopic.php?p=274345#p274345
                          The 'Rounding' glitch with some Adjusted WorkPlanes Grids fixed.
                          All grids should now be centered on point-1 and the edge grids made smaller to suit if the plane's dim itself is not a multiple of the grid...
                            Here's v1.9 http://forums.sketchucation.com/viewtopic.php?p=274345#p274345
                            A 'Rotate Selected' option has been added to the context-menu.
                            You can type in any angle in the dialog and the selected WorkPlane rotates about its axis [pt1>>pt2] by that angle...
                              My 1.8 live only 10 minutes πŸ’š
                              I don't very well understand the interest of the first center point but as I can rescale all the plane no problem πŸ˜„
                              I abuse but a Polar Grid will be also fine if you have some free times β˜€
                              http://www.utc.fr/tsibh/public/tsibh/08/rapport_stage/laurent_neuge/CQ_radiologie_conventionnel_fichier/39_Mire_de_Wellhofer.jpg
                                DIEGO-RODRIGUEZ
                                tig, really thank you very much.
                                to hear any suggestions on this tool. thank you very much.
                                I found only one bug. does not draw the rectangle tool on inclined coplanar faces.
                                I use sketchup8
                                Draw rectangle inclined coplanar workplane
                                versions work : 1.5 or lower
                                versions does not work : 1.6 or higher
                                • CadFatherC Offline
                                  CadFather
                                  Tig, you are so fast even you can't keep up with the versions as you make them!
                                  • jeff hammondJ Offline
                                    i'm thinking this is some sort of glitch with sketchup itself regarding the orientation of the bounding box.. you can recreate this behavior without using WorkPlane.. see attached skp
                                    planes.skp
                                      You gave Susan a tophat? Classy! πŸ˜„
                                        DIEGO-RODRIGUEZ
                                        yes. and if it works the other tools (circle, polygon, arch)
                                        However,
                                        if the geometry is generated as a group or component directly from ruby, SI can draw shapes on inclined planes.
                                        if you later apply any modification to this geometry (move, scale, ungroup, etc. ..) this property is lost.
                                        Le adjunto imΓ‘genes de dos plugins que probΓ©.
                                        polar zonohedron
                                        http://img832.imageshack.us/img832/2558/52784550.gif
                                        work plane 1.5
                                        http://img834.imageshack.us/img834/3791/94618514.gif
                                          EarthMover
                                          Diego, the "Rotated Rectangle" tool works well on sloped planes. (Even after it's been manipulated)
                                            EarthMover
                                            πŸ˜„ I had her out partying last night and she forgot to take it off! 😳
                                            • 4 / 10
