    [Plugin] Work Plane
    183 Posts 32 Posters 157.7k Views 32 Watching
      Adjusment selected is curious πŸ˜„
      Here Grid was 10 10 , with 1 1 then 10 10 , with 3 3
      I understand that I have that asked (why there is not neat (3*3)
      but
      seems fill grid must be fully filled or red frame adjusted to 3 3 + rest(?)
      Hole is perturbating πŸ˜„
      Not Delect selected?
      And option Center first point(actual default) or Framed face will be a must πŸ˜„(avoid to play with and unlock)
      • EarthMoverE
        EarthMover
        TIG, the planar / perpendicular flip is great. Would it be terribly difficult to add rotating of work plane in 15 degree increments to the post adjustment options? If it's a PITA, don't worry about it.
        BTW, I was looking through the code for this plugin and it's amazing the amount of thought and strategy that goes into each little feature. I really appreciate the work you are putting into this and all your plugin releases.
        Content Creator at Skapeup
          Here's v1.8 http://forums.sketchucation.com/viewtopic.php?p=274345#p274345
          The 'Rounding' glitch with some Adjusted WorkPlanes Grids fixed.
          All grids should now be centered on point-1 and the edge grids made smaller to suit if the plane's dim itself is not a multiple of the grid...
            Here's v1.9 http://forums.sketchucation.com/viewtopic.php?p=274345#p274345
            A 'Rotate Selected' option has been added to the context-menu.
            You can type in any angle in the dialog and the selected WorkPlane rotates about its axis [pt1>>pt2] by that angle...
              My 1.8 live only 10 minutes πŸ’š
              I don't very well understand the interest of the first center point but as I can rescale all the plane no problem πŸ˜„
              I abuse but a Polar Grid will be also fine if you have some free times β˜€
              http://www.utc.fr/tsibh/public/tsibh/08/rapport_stage/laurent_neuge/CQ_radiologie_conventionnel_fichier/39_Mire_de_Wellhofer.jpg
                DIEGO-RODRIGUEZ
                tig, really thank you very much.
                to hear any suggestions on this tool. thank you very much.
                I found only one bug. does not draw the rectangle tool on inclined coplanar faces.
                I use sketchup8
                Draw rectangle inclined coplanar workplane
                versions work : 1.5 or lower
                versions does not work : 1.6 or higher
                • CadFatherC
                  CadFather
                  Tig, you are so fast even you can't keep up with the versions as you make them!
                  • jeff hammondJ
                    i'm thinking this is some sort of glitch with sketchup itself regarding the orientation of the bounding box.. you can recreate this behavior without using WorkPlane.. see attached skp
                    planes.skp
                      You gave Susan a tophat? Classy! πŸ˜„
                        DIEGO-RODRIGUEZ
                        yes. and if it works the other tools (circle, polygon, arch)
                        However,
                        if the geometry is generated as a group or component directly from ruby, SI can draw shapes on inclined planes.
                        if you later apply any modification to this geometry (move, scale, ungroup, etc. ..) this property is lost.
                        Le adjunto imΓ‘genes de dos plugins que probΓ©.
                        polar zonohedron
                        http://img832.imageshack.us/img832/2558/52784550.gif
                        work plane 1.5
                        http://img834.imageshack.us/img834/3791/94618514.gif
                        • EarthMoverE
                          EarthMover
                          Diego, the "Rotated Rectangle" tool works well on sloped planes. (Even after it's been manipulated)
                          • EarthMoverE
                            EarthMover
                            πŸ˜„ I had her out partying last night and she forgot to take it off! 😳
                              Little problem πŸ˜„
                              Rotation from the context menu is not on the Coplanar plan of the Work plane (when this one is inclined) πŸ˜‰
                              it would have been too simple πŸ’š
                              • CadFatherC
                                CadFather
                                you're right Diego, and that's quite a nasty one
                                  The glitch where you can't align a 2pt-rectangle [or sometimes a circle] onto a sloping face if it's a group/component-instance and its plane doesn't pass through the origin and is not axial on the x_axis [ πŸ˜’ ] is a known problem with both v7 and v8 - it's logged with them and hopefully a fix might appear in a maintenance release...
                                  The problem isn't specific to this tool - it's general and is easily reproduced by making objects manually and trying to snap 2pt-rectangles to their sloping faces in different orientations... [however, a 3pt-rectangle will work OK as it's not 'built-in' and its code is in fact the starting point for my WorkPlane's tool itself] 😲 😒
                                  • jeff hammondJ
                                    However,
                                    really, i think it's beyond wether or not the shape was created via ruby..
                                    also, you can move a group and still have it accept the rectangle tool IF you move it along the green axis.. it's a su glitch..
                                    look at this video for more weird behavior.. depending on the xy orientation, the rectangle may or may not work..
                                    tig can probably fix this but it's gonna be him fighting the su bug instead of fixing a bug in his script..
                                    [flash=660,405:vu38m2u3]http://www.youtube.com/v/4ZFhL-rD2PM?fs=1&hl=en_US&color1=0x2b405b&color2=0x6b8ab6&border=1[/flash:vu38m2u3]
                                    • CadFatherC
                                      CadFather
                                      ..seems worse in su8
                                        DIEGO-RODRIGUEZ
                                        strange.
                                        I have reported this error:
                                        http://sketchup.google.com/support/bin/request.py?contact_type=bug
                                        and his response was:
                                        "Hi Diego:
                                        Thank you for your message and attach particular image capture.
                                        We've been very helpful!
                                        Answering your question: the behavior you encountered is a
                                        normal behavior.
                                        Geometry within a group or component does not relate to the same
                                        so
                                        geometry itself.
                                        If you want to draw a rectangle, tilted in one of his drawings, you
                                        suggest you draw the geometry and twist it to match the
                                        plane. Another option is to do it without going to the group.
                                        I hope these tips have been helpful!
                                        Regards,
                                        The Google Team
                                        any programmer can tell google about this problem?
                                        probably have more success than me.
                                        • jeff hammondJ
                                          [all this glitch talk aside...]
                                          it might be nice if tig could make a 3point rectangle tool (or does one already exist?).. it would be able to draw properly on the work plane but it's use would extend far beyond that..
                                          there are plenty of instances where the normal fails and a 3pt version would easily accomplish it..
                                          it'd basically be just like the first steps of WorkPlane so most of the coding is already done anyway (well, it at least seems that way for someone that doesn't write code πŸ˜‰ )
                                          • jeff hammondJ
                                            [edit - lol.. it's almost already in 2D tools] πŸ˜‰
                                            • 4 / 10
