    [Plugin] Work Plane
    183 Posts 32 Posters 151.2k Views 32 Watching
      DIEGO-RODRIGUEZ
      tig, really thank you very much.
      to hear any suggestions on this tool. thank you very much.
      I found only one bug. does not draw the rectangle tool on inclined coplanar faces.
      I use sketchup8
      Draw rectangle inclined coplanar workplane
      versions work : 1.5 or lower
      versions does not work : 1.6 or higher
      • CadFatherC Offline
        CadFather
        Tig, you are so fast even you can't keep up with the versions as you make them!
        • jeff hammondJ Offline
          i'm thinking this is some sort of glitch with sketchup itself regarding the orientation of the bounding box.. you can recreate this behavior without using WorkPlane.. see attached skp
          planes.skp
            You gave Susan a tophat? Classy! 😄
              DIEGO-RODRIGUEZ
              yes. and if it works the other tools (circle, polygon, arch)
              However,
              if the geometry is generated as a group or component directly from ruby, SI can draw shapes on inclined planes.
              if you later apply any modification to this geometry (move, scale, ungroup, etc. ..) this property is lost.
              Le adjunto imágenes de dos plugins que probé.
              polar zonohedron
              http://img832.imageshack.us/img832/2558/52784550.gif
              work plane 1.5
              http://img834.imageshack.us/img834/3791/94618514.gif
              • EarthMoverE Offline
                EarthMover
                Diego, the "Rotated Rectangle" tool works well on sloped planes. (Even after it's been manipulated)
                Content Creator at Skapeup
                  EarthMover
                  😄 I had her out partying last night and she forgot to take it off! 😳
                    Little problem 😄
                    Rotation from the context menu is not on the Coplanar plan of the Work plane (when this one is inclined) 😉
                    it would have been too simple 💚
                      CadFather
                      you're right Diego, and that's quite a nasty one
                        The glitch where you can't align a 2pt-rectangle [or sometimes a circle] onto a sloping face if it's a group/component-instance and its plane doesn't pass through the origin and is not axial on the x_axis [ 😒 ] is a known problem with both v7 and v8 - it's logged with them and hopefully a fix might appear in a maintenance release...
                        The problem isn't specific to this tool - it's general and is easily reproduced by making objects manually and trying to snap 2pt-rectangles to their sloping faces in different orientations... [however, a 3pt-rectangle will work OK as it's not 'built-in' and its code is in fact the starting point for my WorkPlane's tool itself] 😲 😢
                          However,
                          really, i think it's beyond wether or not the shape was created via ruby..
                          also, you can move a group and still have it accept the rectangle tool IF you move it along the green axis.. it's a su glitch..
                          look at this video for more weird behavior.. depending on the xy orientation, the rectangle may or may not work..
                          tig can probably fix this but it's gonna be him fighting the su bug instead of fixing a bug in his script..
                          [flash=660,405:vu38m2u3]http://www.youtube.com/v/4ZFhL-rD2PM?fs=1&hl=en_US&color1=0x2b405b&color2=0x6b8ab6&border=1[/flash:vu38m2u3]
                            CadFather
                            ..seems worse in su8
                              DIEGO-RODRIGUEZ
                              strange.
                              I have reported this error:
                              http://sketchup.google.com/support/bin/request.py?contact_type=bug
                              and his response was:
                              "Hi Diego:
                              Thank you for your message and attach particular image capture.
                              We've been very helpful!
                              Answering your question: the behavior you encountered is a
                              normal behavior.
                              Geometry within a group or component does not relate to the same
                              so
                              geometry itself.
                              If you want to draw a rectangle, tilted in one of his drawings, you
                              suggest you draw the geometry and twist it to match the
                              plane. Another option is to do it without going to the group.
                              I hope these tips have been helpful!
                              Regards,
                              The Google Team
                              any programmer can tell google about this problem?
                              probably have more success than me.
                                [all this glitch talk aside...]
                                it might be nice if tig could make a 3point rectangle tool (or does one already exist?).. it would be able to draw properly on the work plane but it's use would extend far beyond that..
                                there are plenty of instances where the normal fails and a 3pt version would easily accomplish it..
                                it'd basically be just like the first steps of WorkPlane so most of the coding is already done anyway (well, it at least seems that way for someone that doesn't write code 😉 )
                                  [edit - lol.. it's almost already in 2D tools] 😉
                                    EarthMover
                                    Jeff, check here. That is what I'm using in the last video I posted - http://download.sketchup.com/downloads/downloads/rubyscripts/rectangle.zip Shows up as "Rotated Rectangle" in the Draw Menu.
                                    (It's also included in CadFather's CD Draw tools)
                                    • BoxB Offline
                                      Another excellent Tig Tool.
                                      Just one question/suggestion, is it possible to have numbering added to the grid.
                                      When I'm putting together a ship I have over 300 frame references set at .64m, to have those frame numbers automatically on the grid would be a godsend.
                                        hahaha
                                        i've wanted that tool since i started using sketchup.. looks like it's been around at least that long 😳
                                        [diego, i'm thinking this is the best solution at the moment for drawing rectangles on the workplanes.. '⇧R' seems to be a perfect shortcut (that is if you're used to 'R' for ]
                                        • kenK Offline
                                          ken
                                          Well, this plugin started out as a reliable, jeans wearing working plugin. Now it is a $20,000.00 “Say Yes to the Dress” wedding gown.
                                          Thanks TIG
                                          • mitcorbM Offline
                                            mitcorb
                                            I woke up this morning, 5:00am GMT-6, saw the latest version 1.6, downloaded it as zip only, placed it in my collecting folder, go out of town for 5 hours and the damned thing is obsolete 3 times over!
                                            Talk about your "worktigers" 😆
                                            TIG, you are one dedicated guy. And you are appreciated!
                                            • 4 / 10
