    [Plugin] Work Plane
    183 Posts 32 Posters 134.1k Views 32 Watching
      DIEGO-RODRIGUEZ
      @earthmover said:
      Or, perhaps the first two clicks define the grid size automatically. This would make sense, as typically when working in a smaller space, you need a smaller gridding. Then from the context menu you can disable or adjust the grid size to suit.
      yes. this option looks interesting
      • EarthMoverE Offline
        EarthMover
        Found another great use for work planes today......setting up spot lights! β˜€
        Content Creator at Skapeup
          Here's v1.7 http://forums.sketchucation.com/viewtopic.php?p=274345#p274345
          'New' and 'Adjust' options have been added to context-menu.
          'New' lets you make a new WorkPlane on the fly...
          'Adjust' lets you change one selected WorkPlane's Settings [Plane's h/w and Grid's h/w]
          Cline 'guide' rectangle and axes are now drawn whilst you are picking the points.
          The WorkPlane Grid is now always centered on pt-1, even if a grid-dim does not divide exactly into the plane-dim.
            EarthMover
            Perfect TIG....thanks!!! (Don't forget to update the post to 1.7)
              Pilou it's a glitch... v1.8 is in the pipeline now... πŸ˜’
                Ok So wait an see πŸ˜„
                  Adjusment selected is curious πŸ˜„
                  Here Grid was 10 10 , with 1 1 then 10 10 , with 3 3
                  I understand that I have that asked (why there is not neat (3*3)
                  but
                  seems fill grid must be fully filled or red frame adjusted to 3 3 + rest(?)
                  Hole is perturbating πŸ˜„
                  Not Delect selected?
                  And option Center first point(actual default) or Framed face will be a must πŸ˜„(avoid to play with and unlock)
                    EarthMover
                    TIG, the planar / perpendicular flip is great. Would it be terribly difficult to add rotating of work plane in 15 degree increments to the post adjustment options? If it's a PITA, don't worry about it.
                    BTW, I was looking through the code for this plugin and it's amazing the amount of thought and strategy that goes into each little feature. I really appreciate the work you are putting into this and all your plugin releases.
                      Here's v1.8 http://forums.sketchucation.com/viewtopic.php?p=274345#p274345
                      The 'Rounding' glitch with some Adjusted WorkPlanes Grids fixed.
                      All grids should now be centered on point-1 and the edge grids made smaller to suit if the plane's dim itself is not a multiple of the grid...
                        Here's v1.9 http://forums.sketchucation.com/viewtopic.php?p=274345#p274345
                        A 'Rotate Selected' option has been added to the context-menu.
                        You can type in any angle in the dialog and the selected WorkPlane rotates about its axis [pt1>>pt2] by that angle...
                          My 1.8 live only 10 minutes πŸ’š
                          I don't very well understand the interest of the first center point but as I can rescale all the plane no problem πŸ˜„
                          I abuse but a Polar Grid will be also fine if you have some free times β˜€
                          http://www.utc.fr/tsibh/public/tsibh/08/rapport_stage/laurent_neuge/CQ_radiologie_conventionnel_fichier/39_Mire_de_Wellhofer.jpg
                            DIEGO-RODRIGUEZ
                            tig, really thank you very much.
                            to hear any suggestions on this tool. thank you very much.
                            I found only one bug. does not draw the rectangle tool on inclined coplanar faces.
                            I use sketchup8
                            Draw rectangle inclined coplanar workplane
                            versions work : 1.5 or lower
                            versions does not work : 1.6 or higher
                            • CadFatherC Offline
                              CadFather
                              Tig, you are so fast even you can't keep up with the versions as you make them!
                              • jeff hammondJ Offline
                                i'm thinking this is some sort of glitch with sketchup itself regarding the orientation of the bounding box.. you can recreate this behavior without using WorkPlane.. see attached skp
                                planes.skp
                                  You gave Susan a tophat? Classy! πŸ˜„
                                    DIEGO-RODRIGUEZ
                                    yes. and if it works the other tools (circle, polygon, arch)
                                    However,
                                    if the geometry is generated as a group or component directly from ruby, SI can draw shapes on inclined planes.
                                    if you later apply any modification to this geometry (move, scale, ungroup, etc. ..) this property is lost.
                                    Le adjunto imΓ‘genes de dos plugins que probΓ©.
                                    polar zonohedron
                                    http://img832.imageshack.us/img832/2558/52784550.gif
                                    work plane 1.5
                                    http://img834.imageshack.us/img834/3791/94618514.gif
                                      EarthMover
                                      Diego, the "Rotated Rectangle" tool works well on sloped planes. (Even after it's been manipulated)
                                        EarthMover
                                        πŸ˜„ I had her out partying last night and she forgot to take it off! 😳
                                          Little problem πŸ˜„
                                          Rotation from the context menu is not on the Coplanar plan of the Work plane (when this one is inclined) πŸ˜‰
                                          it would have been too simple πŸ’š
                                            CadFather
                                            you're right Diego, and that's quite a nasty one
                                            • 4 / 10
