    1.3k Posts 300 Posters 3.1m Views 298 Watching
      taekle
      Fredo6
      I did this with DC and loft by splines.
      After making transformed copies of only two profiles, then I launched loft by splines.
      Here is my other post which contains more images and information.
      http://forums.sketchucation.com/viewtopic.php?f=289&t=30749#p270943
      Thanks for your efforts I could go further in my DC investigation. 😄
      spiral by loft
      http://taekle.blogspot.com
        Hi Fredo
        I just tried the Skinning feature.
        At first I thought it failed to create the mesh - but then I realised it had created it, just not in the current context. I was working on some curves inside a component with Hide Rest of Model enabled - so I did not see the mesh getting created.
        • fredo6F Offline
          @thomthom said:
          Hi Fredo
          Currently the mesh is created as a Group at the first level of the model. That's a small bug.
          Anyway, I will probably improve this part, in particular the possibility to use existing groups, if you build the mesh piece by piece
            It's quite straightforward to make your new mesh-group in the same 'context' as the selected curve edge[0], in the form entities=edge.parent.entities group=entities.add_group()
            Then the 'group' for the new mesh will be in the same 'context' as the curve's 'edge'... 🤓
            • fredo6F Offline
              TIG,
              The bug is simply that I used model.enntities instead of model.active_entities, which is the current working context.
              I cannot rely on edges context, because Curviloft can actually 'borrow' contours from Edges that can be within different groups or components.
              fredo
                Got you...
                So just add the active_ to entities and it works !!! 😒
                Line#198 in CurviloftGeometry.rb
                @top_group = @model.**active_**entities.add_group
                • charly2008C Offline
                  charly2008
                  some further simple constructions with Curviloft. The last image show the basi construction.
                  Charly
                  Curviloft95 Basic Construction.skp
                    Cool geometric exploration ☀
                    • ken28875K Offline
                      ken28875
                      Wow, that's pretty cool. 👍
                      Who would think that Sketchup could do such a thing with a few click of the mouse.
                      Follow Your Dreams.
                        d12dozr
                        Amazing stuff, Charly 👍
                        http://goo.gl/f7ooYh
                          charly2008
                          some new curviloft objects.
                          Charly
                          • ken28875K Offline
                            ken28875
                            Wow, this is really cool. 👍
                            Could you please show the screenshots of the sketchup geos?
                            Thank you, Sir.
                            _KN
                            Follow Your Dreams.
                              robert111
                              charly2008
                              can you make juste one tutorial for yours nice jobs
                                charly2008
                                Hi Ken, hi Robert,
                                at first a few screen shots from SketchUp.
                                • mitcorbM Offline
                                  mitcorb
                                  You have a great imagination, and I assume your knowledge is less limited than many 😄 👍 👍
                                  I notice in the SKup captures that the geometry is coincident but not intersecting. I did not realize that a render app would tolerate this?
                                  By the way, which render app is it?
                                    dedmin
                                      charly2008
                                      Hi mitcorb,
                                      I use Kerkythea. With Kerkythea I have the most experience. I consider myself still a beginner as regards to rendering. I would recommend anyone to begin with Kerkythea and to study the program thoroughly. This is a good basis for understanding other rendering programs.
                                      Charly
                                        charly2008
                                        I usually start trying to construct a basic form. Then you can play with the spline Methods. Then make a group and copy them and connect them several times. Make it a group again and use again rotate copy. It is very easy. The result is mostly interesting geometric objects. Useless but nice to see.
                                        I would be very interested in what ideas others user have. Has someone already used it for architectural purposes?
                                        Charly
                                        Untitled.skp
                                          robert111
                                          charly thanks for your nice tuto , but i am interresting for this objet
                                          if you can make tuto too ,
                                            charly2008
                                            Robert,
                                            it is very easy. I used this basic construction shown in my post before. Connect the faces as you want and use spline method "junction by orthogonal Betier curves" as shown below.
                                            Charly
                                            Junction by orthogonal Bezier curves
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 65
                                            • 66
                                            • 16 / 66
