    1.3k Posts 300 Posters 3.2m Views 298 Watching
      Hi Fredo
      I just tried the Skinning feature.
      At first I thought it failed to create the mesh - but then I realised it had created it, just not in the current context. I was working on some curves inside a component with Hide Rest of Model enabled - so I did not see the mesh getting created.
      • fredo6F
        @thomthom said:
        Hi Fredo
        Currently the mesh is created as a Group at the first level of the model. That's a small bug.
        Anyway, I will probably improve this part, in particular the possibility to use existing groups, if you build the mesh piece by piece
          It's quite straightforward to make your new mesh-group in the same 'context' as the selected curve edge[0], in the form entities=edge.parent.entities group=entities.add_group()
          Then the 'group' for the new mesh will be in the same 'context' as the curve's 'edge'... 🤓
          • fredo6F
            TIG,
            The bug is simply that I used model.enntities instead of model.active_entities, which is the current working context.
            I cannot rely on edges context, because Curviloft can actually 'borrow' contours from Edges that can be within different groups or components.
            fredo
              Got you...
              So just add the active_ to entities and it works !!! 😒
              Line#198 in CurviloftGeometry.rb
              @top_group = @model.**active_**entities.add_group
              • charly2008C
                charly2008
                some further simple constructions with Curviloft. The last image show the basi construction.
                Charly
                Curviloft95 Basic Construction.skp
                  Cool geometric exploration ☀
                  • ken28875K
                    ken28875
                    Wow, that's pretty cool. 👍
                    Who would think that Sketchup could do such a thing with a few click of the mouse.
                    Follow Your Dreams.
                      d12dozr
                      Amazing stuff, Charly 👍
                      http://goo.gl/f7ooYh
                      • charly2008C
                        charly2008
                        some new curviloft objects.
                        Charly
                        • ken28875K
                          ken28875
                          Wow, this is really cool. 👍
                          Could you please show the screenshots of the sketchup geos?
                          Thank you, Sir.
                          _KN
                          Follow Your Dreams.
                            robert111
                            charly2008
                            can you make juste one tutorial for yours nice jobs
                            • charly2008C
                              charly2008
                              Hi Ken, hi Robert,
                              at first a few screen shots from SketchUp.
                              • mitcorbM
                                mitcorb
                                You have a great imagination, and I assume your knowledge is less limited than many 😄 👍 👍
                                I notice in the SKup captures that the geometry is coincident but not intersecting. I did not realize that a render app would tolerate this?
                                By the way, which render app is it?
                                  dedmin
                                  • charly2008C
                                    charly2008
                                    Hi mitcorb,
                                    I use Kerkythea. With Kerkythea I have the most experience. I consider myself still a beginner as regards to rendering. I would recommend anyone to begin with Kerkythea and to study the program thoroughly. This is a good basis for understanding other rendering programs.
                                    Charly
                                    • charly2008C
                                      charly2008
                                      I usually start trying to construct a basic form. Then you can play with the spline Methods. Then make a group and copy them and connect them several times. Make it a group again and use again rotate copy. It is very easy. The result is mostly interesting geometric objects. Useless but nice to see.
                                      I would be very interested in what ideas others user have. Has someone already used it for architectural purposes?
                                      Charly
                                      Untitled.skp
                                        robert111
                                        charly thanks for your nice tuto , but i am interresting for this objet
                                        if you can make tuto too ,
                                        • charly2008C
                                          charly2008
                                          Robert,
                                          it is very easy. I used this basic construction shown in my post before. Connect the faces as you want and use spline method "junction by orthogonal Betier curves" as shown below.
                                          Charly
                                          Junction by orthogonal Bezier curves
                                            robert111
                                            charly thanks for your tuto but i havent cuved form , i dont know why??
                                            look this picture
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 65
                                            • 66
                                            • 16 / 66
