    1.3k Posts 299 Posters 2.5m Views 297 Watching
      I'm sure you've already found it... but in my similar scripts they can 'orient' faces consistently using my 'orient_faces' method [that is published around here somewhere and incorporated in modified forms in these tools]. As long as the created edges have no more than two faces you can consistently 'orient' them all to match even if the mesh 'flips' at some points - they might ALL be made the wrong way round compared to what the user expects... but then a simple reverse fixes them all in one go [I also do tricks like assume the topmost face faces upwards and use that to orient the set from - but that's not foolproof either... open shells might concave OR convex!]
      • fredo6F Offline
        TIG,
        The main problem with have with the SU API is that there is no Bulk methods to work on a set of elements for Smoothing, Reversing, Orienting, etc.... (whereas these methods exist in the natural GUI). As a result, doing it by program results in long response time, even longer that to generate the basic mesh geometry. We could ask the SU Google Team to add these methods in a next version, but you know there is no guarantee.
        For face orientation, my plan is to calculate the orientation in the algorithm itself (based on the ordering of points in the Geom::PolygonMesh construction).
        For the time being, I consider this is not a critical issue for the user, because s/he can always orient, reverse and smoothen instantly the face mesh, even complex, via the native SU GUI (of course, Orient Face should be more known). I assume that users need Curviloft occasionally and do not need to generate 20 meshes by minutes.
          taekle
          Fredo6
          I did this with DC and loft by splines.
          After making transformed copies of only two profiles, then I launched loft by splines.
          Here is my other post which contains more images and information.
          http://forums.sketchucation.com/viewtopic.php?f=289&t=30749#p270943
          Thanks for your efforts I could go further in my DC investigation. 😄
          spiral by loft
          http://taekle.blogspot.com
            Hi Fredo
            I just tried the Skinning feature.
            At first I thought it failed to create the mesh - but then I realised it had created it, just not in the current context. I was working on some curves inside a component with Hide Rest of Model enabled - so I did not see the mesh getting created.
            • fredo6F Offline
              @thomthom said:
              Hi Fredo
              Currently the mesh is created as a Group at the first level of the model. That's a small bug.
              Anyway, I will probably improve this part, in particular the possibility to use existing groups, if you build the mesh piece by piece
                It's quite straightforward to make your new mesh-group in the same 'context' as the selected curve edge[0], in the form entities=edge.parent.entities group=entities.add_group()
                Then the 'group' for the new mesh will be in the same 'context' as the curve's 'edge'... 🤓
                • fredo6F Offline
                  TIG,
                  The bug is simply that I used model.enntities instead of model.active_entities, which is the current working context.
                  I cannot rely on edges context, because Curviloft can actually 'borrow' contours from Edges that can be within different groups or components.
                  fredo
                    Got you...
                    So just add the active_ to entities and it works !!! 😒
                    Line#198 in CurviloftGeometry.rb
                    @top_group = @model.**active_**entities.add_group
                    • charly2008C Offline
                      charly2008
                      some further simple constructions with Curviloft. The last image show the basi construction.
                      Charly
                      Curviloft95 Basic Construction.skp
                        Cool geometric exploration ☀
                        • ken28875K Offline
                          ken28875
                          Wow, that's pretty cool. 👍
                          Who would think that Sketchup could do such a thing with a few click of the mouse.
                          Follow Your Dreams.
                            d12dozr
                            Amazing stuff, Charly 👍
                            http://goo.gl/f7ooYh
                              charly2008
                              some new curviloft objects.
                              Charly
                              • ken28875K Offline
                                ken28875
                                Wow, this is really cool. 👍
                                Could you please show the screenshots of the sketchup geos?
                                Thank you, Sir.
                                _KN
                                Follow Your Dreams.
                                  robert111
                                  charly2008
                                  can you make juste one tutorial for yours nice jobs
                                    charly2008
                                    Hi Ken, hi Robert,
                                    at first a few screen shots from SketchUp.
                                    • mitcorbM Offline
                                      mitcorb
                                      You have a great imagination, and I assume your knowledge is less limited than many 😄 👍 👍
                                      I notice in the SKup captures that the geometry is coincident but not intersecting. I did not realize that a render app would tolerate this?
                                      By the way, which render app is it?
                                        dedmin
                                          charly2008
                                          Hi mitcorb,
                                          I use Kerkythea. With Kerkythea I have the most experience. I consider myself still a beginner as regards to rendering. I would recommend anyone to begin with Kerkythea and to study the program thoroughly. This is a good basis for understanding other rendering programs.
                                          Charly
                                            charly2008
                                            I usually start trying to construct a basic form. Then you can play with the spline Methods. Then make a group and copy them and connect them several times. Make it a group again and use again rotate copy. It is very easy. The result is mostly interesting geometric objects. Useless but nice to see.
                                            I would be very interested in what ideas others user have. Has someone already used it for architectural purposes?
                                            Charly
                                            Untitled.skp
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 65
                                            • 66
                                            • 28 / 66
