    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
    • massimoM Offline
      massimo Moderator
      Really nice images cronicash. πŸ‘
      • PixeroP Offline
        Pixero
        @richard said:
        Mate you can select the surface and make alternatives to fill the same space so that the components aren't all the same!
        Thats not what I was after.
        Styling fur/hair/grass is a way of...styling it to suite the geometry like combing hair on a head.
        "Guide hairs" is a way of using a few strands too control placement and direction and styling of a at render time full dense fur/grass/hair.
        Here are two links to other fur solutions that explains combing:
        http://www.worley.com/E/Products/sasquatch/combing.html
        http://www.joealter.com/newSite/combing.htm
          Ruturaj
          Really nice plugin ......
          Very nice
          Thanks .........
          Thanks,
          RuturaJ
            AcesHigh
            @xrok1 said:
            i knew i should have popped that before it got out of hand! 😲
            who would have ever imagined fur for SU?????????????????????????????
            a very hairy nipple?? πŸ˜„ πŸ˜„
            • E Offline
              ENG. YASEEN
              I Made This By Fur Plugin 😍
              http://i567.photobucket.com/albums/ss118/ALGALY/XYZ4Studioin4.jpg
              😎 πŸ‘
              Thx tak2hata
              My Website:
              http://xyz4studio.blogspot.com/
                adityas
                What am I suppose to do after making fun with this tools?
                Should I cry or just shout to tell the author, "THIS IS A SUPER DUPER MARVELOUS PLUGIN!!!"
                Damn good... simple but... (I cant't explain with words).
                • mariochaM Offline
                  mariocha
                  Hey many, many thanks man ! impressive plugin.
                  After all, some still think art is easier on grass πŸ˜†
                  %(#008000)[Mario C.
                  • RichardR Offline
                    Richard
                    Sorry mate I understand now! Yes certainly an option to force specs easier than it certainly could be without work! Though that said this is the first we have seen of this plug so who knows, good idea though!!!! πŸ˜„
                    BUILTBRAND.COM.AU
                      tak2hata
                      Hi, All.
                      I updated make fur plugin version to 1.3a(test version).
                      Because I changed the format of the preset, it is not compatible with the one before.
                      Please warn you.
                      Thanks.
                      by TAK2HATA
                      • EscapeArtistE Offline
                        EscapeArtist
                        Just keeps getting better!
                          Daniel S
                          Thank you for the update tak2hata!
                          Perhaps in next versions you can put all the options in a submenu? Something like the attachment.
                          Daniel S
                            Why metric and imperial? Why not just deal with the units in the way that the model is?
                              tak2hata
                              Hi,Daniel.
                              I Changed menu items into sub menu named "Fur_v1_3".
                              Hi,Thomas.
                              Because I think it easy to test both imperial and metric.
                              I am not accustomed to the imperial.
                              I will corrects it in future version.
                              Thanks for your advice.
                              by TAK2HATA
                                The Numeric, Float and String class has some nice methods that let you deal with units in the user's locale and in the current model's units.
                                  tak2hata
                                  Hi, Thomas.
                                  Thanks ! I'm searching for that method.
                                  by TAK2HATA
                                    Basically:
                                    Ensure the units you use are Length objects. Length.to_s will output a unit in the user's locale and model settings. This is useful when presenting units in the UI, like for inputboxes etc.
                                    Then you have String.to_l, which is useful to convert user input into Length. If a user types "100mm" it then .to_l will convert that into the appropriate Length. (Length is always in SU's internal units: inches)
                                    "100m".to_l
                                    becomes:
                                    3937.00787401575
                                    If the user has mm set as the model units, then "100" (without any unit indication) is assumed to be in mm and the result is:
                                    "100".to_l 3.93700787401575
                                    same thing as if the user had typed "100mm"
                                    "100mm".to_l 3.93700787401575
                                      portenart.emile
                                      Hello every body,
                                      I found this plugin today. It look amazing. Ihave made the grass but i don't know why it isn't render in Vray ? I'm sure it's a specific option i have to check but i don't found it.
                                      I use Skectchup pro 7.1.6, Vray for sketchup 01.05.30, and Fur Plugin 1.3.
                                      I can send you a screenshot or a file if you need.
                                      Thanks you for your help πŸ˜„
                                      Emile
                                      • mariochaM Offline
                                        mariocha
                                        Hum .... Although the title says V1.3b
                                        the download still says v1.3a πŸ˜•
                                        %(#008000)[Mario C.
                                          This is due to a Sketchup bug and groups. The groups will render when you reopen the model.
                                          The latest VfSU does not suffer from this SU bug.
                                            jbrown
                                            Very handy.
                                            Am I missing something in the settings, though? It appears to be growing from the opposite side of the selected face and I can't figure out how to change that. Not too big a deal to select the opposite side from where it needs to go, but maybe there's an easier way?
                                            • 32
                                            • 33
                                            • 8 / 33
