    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
      minguinhirigue
      Really nice one I missed from a long time... Thanks.
      • Mike LuceyM Offline
        Mike Lucey
        Thanks tak2hata,
        I can see this plugin becoming a great favorite πŸ‘
        Mike
        • utilerU Offline
          utiler
          No way!!
          Now I can see what a woman looks like with a beard.
          purpose/expression/purpose/....
          • W Offline
            Whaat
            Great plugin! Thanks for sharing!
            • CadFatherC Offline
              CadFather
              Just when you think you've seen it all.. tak2hata comes along with another great idea...thanks! β˜€
                CadFather
                yes please.. πŸ‘
                  I have a request as a developer. Can you add an option to attach a fur parameters to a SU material as attributes. Multiple exporters to rendering programs could call your plugin to receive info on location and parameters of the fur. Instead of choking SU, an exporter would get the geometry info from your plugin and translate it into the rendering program entities, without creating it inside SU.
                  Oooh! Good idea. Keep all data as attributes per face. And use simple lines (in reduced numbers) to represent the fur.
                  • N Offline
                    notareal
                    Would it be possible?
                    Cheers
                    Tomasz
                    That would be great!
                    Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                      tomasz
                      Hi, Thanks a lot for such an interesting plugin!
                      @tak2hata said:
                      Creating Too Much Polygon is very slow.
                      And to use code "entities.fill_from_mesh" must need blank Group.
                      This Plugin executes each selected faces.
                      Creating Group each new 800 polygons.
                      so it parts.
                      I have a request as a developer. Can you add an option to attach a fur parameters to a SU material as attributes. Multiple exporters to rendering programs could call your plugin to receive info on location and parameters of the fur. Instead of choking SU, an exporter would get the geometry info (EDIT: transformations of components) from your plugin and translate it into the rendering program entities, without creating it inside SU.
                      Cheers
                      Tomasz
                      Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                      • olisheaO Offline
                        olishea
                        one of the best plugins around!!
                        i'm making everything furry! 😎
                        render cooking πŸ˜„
                        oli
                          tomasz
                          I am testing the plugin and have noticed that it doesn't take an area of a triangle into account. It think it won't be that hard to fix. πŸ˜„
                            That's probably because of MaxNumber(/Face) setting you have set. The Dencity(Num/m2) appears to deal with the area, but larger faces needs more fur, so you need to increase the MaxNumber.
                            • tridemT Offline
                              tridem
                              one more THANK YOU
                              ...and one more request πŸ˜† in such a tool it's usefull having the Esc key available, to stop the process if it take too long than expected
                                That is easier said than done. It's difficult to get any key press events while scripts are running. Though I thing Fredo has some feature like that...
                                • massimoM Offline
                                  massimo Moderator
                                  Really funny thank you tak2hata! πŸ‘
                                    KarinaGM
                                    Wow!
                                    Amazing tool.
                                    I've just downloaded it and can't wait to start (playing) experimenting
                                    THANKS!
                                    **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminarΓ‘ perdiendo ambas"
                                    -BenjamΓ­n Franklin.**
                                    • olisheaO Offline
                                      olishea
                                      so much fun!!
                                      would be nice if there was a "set defaults" button....and if it remembered your settings between tweaking.
                                      would also be good if the grass was automatically placed on a new layer so you can quickly turn it off or on....you could render the scene without the geometry even being present.
                                      Sketchup view of an old model of mine:
                                      http://i654.photobucket.com/albums/uu269/olishea/urchin_hairy.jpg
                                      oli
                                      • tridemT Offline
                                        tridem
                                        I believe so... eg 'round corner' can do it
                                          tak2hata
                                          I updated the plugin. it's version 1.0.
                                          I saw some requests now.
                                          It seems to be difficult in my skill.
                                          Hereafter, I will study Ruby more.
                                          by TAK2HATA
                                            πŸ˜„ Yea, you've started something. πŸ˜„
                                            If you need help with anything just ask at this forum, people are happy to help.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 32
                                            • 33
                                            • 15 / 33
