    NEW Forum Software Issues
    Scheduled Pinned Locked Moved Ideas Box & Board Issues
    78 Posts 17 Posters 11.5k Views 19 Watching
      No more "Your posts" ?
      majidM 1 Reply Last reply Reply Quote 1
        External links don't works anymore like this
        [image]https://images2.imgbox.com/4d/ce/GMEgEXqA_o.gif[/image]
        Same links were working yesterday!
        same image in direct drag & drop!
        GIFwombo.gif![GIFwombo1.gif]Free Krea(/assets/uploads/files/1710177720075-gifwombo1.gif) ![GIF_krea.gif]GIFwombo1.gifGIF_krea.gif
          Rich O Brien Moderator @pilou
          @pilou If you click Help
          You can see new way to link images
          ![Image](http://url/a.png)
          not
          [image][/image]
          • ntxdaveN Offline
            ntxdave @Box
            @Box
            I am not seeing these 2 icons. Is it a iPad issue (which is where I look at the forums most of the tone)?
            Press F1...thank me later
            • Rich O BrienR Rich O Brien moved this topic from SketchUcation Community Forums on
              Rich O Brien Moderator @ntxdave
              @ntxdave
              Have you tried pressing your avatar to expose more options?
              There's lots of new toys to play with so take your time and explore the interface. There's no documentation to follow as its forum software. You will gradually find things.
              It is also highly customisable so a menu position for one user maybe located differently to another. That is why its important you poke around. Not to find a problem but to just explore it.
              I know its a major shift but take the time and explore the UI. Its the best way to learn.
              • ntxdaveN Offline
                ntxdave @Rich O Brien
                @Rich-O-Brien said in NEW Forum Software Issues:
                @ntxdave
                Yes, I did not see other options. Either I am just missing something or maybe it is something related to my iPad. I just see a number on my avatar. I cannot do a screen capture to show you what I see/don’t see. 😞
                It is also highly customisable so a menu position for one user maybe located differently to another. That is why it’s important you poke around. Not to find a problem but to just explore it.
                I have not seen options for customizing the menu unless you are talking about the list of things on the settings page.
                Again, I would like to point out that I do not see the things @Box pointed out before. I have seen some things if I click to have a side panel show up on my iPad.
                I know it’s a major shift but take the time and explore the UI. It’s the best way to learn.
                • ntxdaveN Offline
                  ntxdave @ntxdave
                  @ntxdave
                  Ok, I just figured out what @Box pointed out. Thanks..........
                    sashapepperspray
                    What happened to private messaging? (and how can I see my old ones)?
                      rv1974
                      Some imperfections:
                      I'm very used to entering N in address bar in Firefox and get "new posts" on forums. Now it's redirecting to the main board - not good.
                      Was really needed to rename New to Recent?
                      Going from forum to plugin store to download stuff still demands to login once again.
                      'Your posts' are gone.
                      I'd prefer 'edit' pencil button not to be buried in dropbox menu
                        Rich O Brien Moderator @rv1974
                        @rv1974 said in NEW Forum Software Issues:
                        We didn't rename anything. Its the newer software's naming convention. We will take a look at URL slug
                        So would I....will see if there's an option to customise button positions
                        @sashapepperspray said in NEW Forum Software Issues:
                        We still have the older forum. Private messages are not capable to be migrated so we'll provide a means to download your messages to CSV once we finish resolving issues here.
                        alsomarA 1 Reply Last reply Reply Quote 1
                        • alsomarA Offline
                          alsomar Extension Creator @Rich O Brien
                          Hi there! I like the new look, but I can't find where to change my signature.
                          Alejandro Soriano Visuals Β· All my links
                          BoxB Rich O BrienR 2 Replies Last reply Reply Quote 0
                          • majidM Offline
                            majid @pilou
                            @pilou said in NEW Forum Software Issues:
                            I had the same question...
                            • BoxB Offline
                              Box @alsomar
                              @alsomar Click your Avatar, top right and choose Edit Profile then scroll down to Signature and then to save changes.
                                Rich O Brien Moderator @alsomar
                                @alsomar I believe you maybe behind the reputation system this newer forum uses.
                                So maybe @Box suggestion is unavailable to you. If you are unable to change it let me know and I'll see what we can do.
                                I'd be interested to know if you are able or not.
                                gullfoG 1 Reply Last reply Reply Quote 0
                                • gullfoG Offline
                                  gullfo @Rich O Brien
                                  @Rich-O-Brien doesn't look like there is an option to edit signature in the settings or profile areas (found via the vertical triple dots).
                                  also, the "your posts" is called "best posts" - maybe call it "latest posts" or "recent posts" as i'm sure not all my most recent posts are the "best" ones πŸ™‚
                                  Glenn
                                  http://www.runnel.com
                                  Gus RG Rich O BrienR 2 Replies Last reply Reply Quote 1
                                  • Gus RG Offline
                                    Gus R @gullfo
                                    @gullfo said in NEW Forum Software Issues:
                                    Did you try clicking on your profile image thumbnail on the upper right and clicking "edit profile" in the pull down menu?
                                    www.instagram.com/gusrobatto/
                                    www.facebook.com/gusrobatto
                                      Rich O Brien Moderator @gullfo
                                      @gullfo its unfortunate but this reputation is a way to circumvent spammers. Things are exposed after reach a certain reputation level.
                                      I'll see if there's a way around without it resulting in an influx of Spam posts.
                                      Rich O BrienR gullfoG 2 Replies Last reply Reply Quote 0
                                        Rich O Brien Moderator @Rich O Brien
                                        @gullfo if you make 3 more post the system will reward you added reputation.
                                        With this added rep you should see more options to edit at your profile.
                                        BTW, if you click a users avatar you see their rep and you can follow them
                                        As for the best vs your post this is something I've noted to add once our login issues are resolved.
                                        • alsomarA Offline
                                          alsomar Extension Creator @Box
                                          @Box said in NEW Forum Software Issues:
                                          I don't have this option now, I think I had it in the old syle. Anyway, thank you for answering.
                                          The option doesn't exist in my profile, so I gues I have a bad reputation πŸ˜‚πŸ˜‚
                                          • panixiaP Offline
                                            panixia @Rich O Brien
                                            Its been a huge undertaking to get the old content into this newer system.
                                            Wow, really promising so far..
                                            I wonder if beta forum and old private messages will be retrieved later on or if they are lost..
                                            • 2 / 4
