    NEW Forum Software Issues
    Scheduled Pinned Locked Moved Ideas Box & Board Issues
    78 Posts 17 Posters 15.8k Views 19 Watching
    • BoxB
      Box @ntxdave
      @ntxdave
      ntxdaveN 1 Reply Last reply
      • G
        Gábor @gullfo
        @gullfo said in NEW Forum Software Issues:
        1. part way scrolling through a list of posts suddenly there is some refresh looping causing the entire page from the advert on down to jump back and forth (up and down really) making things unusable.
        We have set pagination on to prevent this. You can change this setting at your personal settings.
        Reply Quote 2
          Rich O Brien Moderator @rv1974
          @rv1974 All I ask is time and patience while we dial stuff in. Imagine its your brand new home and you get to paint it and decorate it. But first we need the utilities to work.
          R 1 Reply Last reply
            rv1974 @Rich O Brien
            @Rich-O-Brien no problemo, is it in plans at least?
              @rv1974 yes, but right now we are resolving logging issues for those impacted.
              I understand your not digging the visuals. Its on our todo list
                No more "Your posts" ?
                majidM 1 Reply Last reply
                  External links don't works anymore like this
                  [image]https://images2.imgbox.com/4d/ce/GMEgEXqA_o.gif[/image]
                  Same links were working yesterday!
                  same image in direct drag & drop!
                  GIFwombo.gif![GIFwombo1.gif]Free Krea(/assets/uploads/files/1710177720075-gifwombo1.gif) ![GIF_krea.gif]GIFwombo1.gifGIF_krea.gif
                    Rich O Brien Moderator @pilou
                    @pilou If you click Help
                    You can see new way to link images
                    ![Image](http://url/a.png)
                    not
                    [image][/image]
                    • ntxdaveN
                      ntxdave @Box
                      @Box
                      I am not seeing these 2 icons. Is it a iPad issue (which is where I look at the forums most of the tone)?
                      Press F1...thank me later
                      • Rich O BrienR Rich O Brien moved this topic from SketchUcation Community Forums on
                        Rich O Brien Moderator @ntxdave
                        @ntxdave
                        Have you tried pressing your avatar to expose more options?
                        There's lots of new toys to play with so take your time and explore the interface. There's no documentation to follow as its forum software. You will gradually find things.
                        It is also highly customisable so a menu position for one user maybe located differently to another. That is why its important you poke around. Not to find a problem but to just explore it.
                        I know its a major shift but take the time and explore the UI. Its the best way to learn.
                        • ntxdaveN
                          ntxdave @Rich O Brien
                          @Rich-O-Brien said in NEW Forum Software Issues:
                          @ntxdave
                          Yes, I did not see other options. Either I am just missing something or maybe it is something related to my iPad. I just see a number on my avatar. I cannot do a screen capture to show you what I see/don’t see. 😞
                          It is also highly customisable so a menu position for one user maybe located differently to another. That is why it’s important you poke around. Not to find a problem but to just explore it.
                          I have not seen options for customizing the menu unless you are talking about the list of things on the settings page.
                          Again, I would like to point out that I do not see the things @Box pointed out before. I have seen some things if I click to have a side panel show up on my iPad.
                          I know it’s a major shift but take the time and explore the UI. It’s the best way to learn.
                          • ntxdaveN
                            ntxdave @ntxdave
                            @ntxdave
                            Ok, I just figured out what @Box pointed out. Thanks..........
                              sashapepperspray
                              What happened to private messaging? (and how can I see my old ones)?
                                rv1974
                                Some imperfections:
                                I'm very used to entering N in address bar in Firefox and get "new posts" on forums. Now it's redirecting to the main board - not good.
                                Was really needed to rename New to Recent?
                                Going from forum to plugin store to download stuff still demands to login once again.
                                'Your posts' are gone.
                                I'd prefer 'edit' pencil button not to be buried in dropbox menu
                                  @rv1974 said in NEW Forum Software Issues:
                                  We didn't rename anything. Its the newer software's naming convention. We will take a look at URL slug
                                  So would I....will see if there's an option to customise button positions
                                  @sashapepperspray said in NEW Forum Software Issues:
                                  We still have the older forum. Private messages are not capable to be migrated so we'll provide a means to download your messages to CSV once we finish resolving issues here.
                                  alsomarA 1 Reply Last reply
                                  • alsomarA
                                    alsomar Extension Creator @Rich O Brien
                                    Hi there! I like the new look, but I can't find where to change my signature.
                                    Alejandro Soriano Visuals · All my links
                                    BoxB Rich O BrienR 2 Replies Last reply
                                    • majidM
                                      majid @pilou
                                      @pilou said in NEW Forum Software Issues:
                                      I had the same question...
                                      • BoxB
                                        Box @alsomar
                                        @alsomar Click your Avatar, top right and choose Edit Profile then scroll down to Signature and then to save changes.
                                          Rich O Brien Moderator @alsomar
                                          @alsomar I believe you maybe behind the reputation system this newer forum uses.
                                          So maybe @Box suggestion is unavailable to you. If you are unable to change it let me know and I'll see what we can do.
                                          I'd be interested to know if you are able or not.
                                          gullfoG 1 Reply Last reply
                                          • gullfoG
                                            gullfo @Rich O Brien
                                            @Rich-O-Brien doesn't look like there is an option to edit signature in the settings or profile areas (found via the vertical triple dots).
                                            also, the "your posts" is called "best posts" - maybe call it "latest posts" or "recent posts" as i'm sure not all my most recent posts are the "best" ones 🙂
                                            Glenn
                                            http://www.runnel.com
                                            Gus RG Rich O BrienR 2 Replies Last reply
                                            • 2 / 4
