    NEW Forum Software Issues
    Scheduled Pinned Locked Moved Ideas Box & Board Issues
    78 Posts 17 Posters 14.5k Views 19 Watching
    • Gus RG
      Gus R @Rich O Brien
      @Rich-O-Brien said in NEW Forum Software Issues:
      @Gus-R said in NEW Forum Software Issues:
      like to see is a dark mode and larger text/font on the right side bar.
      We'll look into a plugin to enable dark mode. The font sizing is Theme related but we'll look into it too.
      Yes please. Thanks Rich.
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
        rv1974
        @Rich-O-Brien Is some sort of native dark mode planned by mistake? this white is burning my eyes
        • ntxdaveN
          ntxdave @Rich O Brien
          @ntxdave said in NEW Forum Software Issues:
          • After I read a new post and do not have a reply, how do I get back to the list of new posts/topics?
          Click the clock icon to see Recent
          Wher is the clock icon?
          • I have a number showing up with my icon in the upper right corner. How do I clear that?
          Click the Bell and Mark All Read
          Where is the Bell?
          • With the new UI, how do I add a numbered list?
          Markdown Cheat Sheet | Markdown Guide
          A quick reference to the Markdown syntax.
          (www.markdownguide.org)
          OK, this one I figured out.
          Have fun exploring it and getting used to it most of all
          I am sure I will figure things out but I am strggeling a little with the new forum and finding that it really fills up my history log a lot. 😕
          Press F1...thank me later
          BoxB 1 Reply Last reply
          • BoxB
            Box @ntxdave
            @ntxdave
            ntxdaveN 1 Reply Last reply
            • G
              GĂĄbor @gullfo
              @gullfo said in NEW Forum Software Issues:
              1. part way scrolling through a list of posts suddenly there is some refresh looping causing the entire page from the advert on down to jump back and forth (up and down really) making things unusable.
              We have set pagination on to prevent this. You can change this setting at your personal settings.
              Reply Quote 2
                Rich O Brien Moderator @rv1974
                @rv1974 All I ask is time and patience while we dial stuff in. Imagine its your brand new home and you get to paint it and decorate it. But first we need the utilities to work.
                R 1 Reply Last reply
                  rv1974 @Rich O Brien
                  @Rich-O-Brien no problemo, is it in plans at least?
                    @rv1974 yes, but right now we are resolving logging issues for those impacted.
                    I understand your not digging the visuals. Its on our todo list
                      No more "Your posts" ?
                      majidM 1 Reply Last reply
                        External links don't works anymore like this
                        [image]https://images2.imgbox.com/4d/ce/GMEgEXqA_o.gif[/image]
                        Same links were working yesterday!
                        same image in direct drag & drop!
                        GIFwombo.gif![GIFwombo1.gif]Free Krea(/assets/uploads/files/1710177720075-gifwombo1.gif) ![GIF_krea.gif]GIFwombo1.gifGIF_krea.gif
                          Rich O Brien Moderator @pilou
                          @pilou If you click Help
                          You can see new way to link images
                          ![Image](http://url/a.png)
                          not
                          [image][/image]
                          • ntxdaveN
                            ntxdave @Box
                            @Box
                            I am not seeing these 2 icons. Is it a iPad issue (which is where I look at the forums most of the tone)?
                            • Rich O BrienR Rich O Brien moved this topic from SketchUcation Community Forums on
                              Rich O Brien Moderator @ntxdave
                              @ntxdave
                              Have you tried pressing your avatar to expose more options?
                              There's lots of new toys to play with so take your time and explore the interface. There's no documentation to follow as its forum software. You will gradually find things.
                              It is also highly customisable so a menu position for one user maybe located differently to another. That is why its important you poke around. Not to find a problem but to just explore it.
                              I know its a major shift but take the time and explore the UI. Its the best way to learn.
                              • ntxdaveN
                                @ntxdave
                                Yes, I did not see other options. Either I am just missing something or maybe it is something related to my iPad. I just see a number on my avatar. I cannot do a screen capture to show you what I see/don’t see. 😞
                                It is also highly customisable so a menu position for one user maybe located differently to another. That is why it’s important you poke around. Not to find a problem but to just explore it.
                                I have not seen options for customizing the menu unless you are talking about the list of things on the settings page.
                                Again, I would like to point out that I do not see the things @Box pointed out before. I have seen some things if I click to have a side panel show up on my iPad.
                                I know it’s a major shift but take the time and explore the UI. It’s the best way to learn.
                                • ntxdaveN
                                  ntxdave @ntxdave
                                  @ntxdave
                                  Ok, I just figured out what @Box pointed out. Thanks..........
                                    sashapepperspray
                                    What happened to private messaging? (and how can I see my old ones)?
                                      rv1974
                                      Some imperfections:
                                      I'm very used to entering N in address bar in Firefox and get "new posts" on forums. Now it's redirecting to the main board - not good.
                                      Was really needed to rename New to Recent?
                                      Going from forum to plugin store to download stuff still demands to login once again.
                                      'Your posts' are gone.
                                      I'd prefer 'edit' pencil button not to be buried in dropbox menu
                                        @rv1974 said in NEW Forum Software Issues:
                                        We didn't rename anything. Its the newer software's naming convention. We will take a look at URL slug
                                        So would I....will see if there's an option to customise button positions
                                        @sashapepperspray said in NEW Forum Software Issues:
                                        We still have the older forum. Private messages are not capable to be migrated so we'll provide a means to download your messages to CSV once we finish resolving issues here.
                                        alsomarA 1 Reply Last reply
                                        • alsomarA
                                          alsomar Extension Creator @Rich O Brien
                                          Hi there! I like the new look, but I can't find where to change my signature.
                                          Alejandro Soriano Visuals ¡ All my links
                                          BoxB Rich O BrienR 2 Replies Last reply
                                          • majidM
                                            majid @pilou
                                            @pilou said in NEW Forum Software Issues:
                                            I had the same question...
                                            • 2 / 4
