    NEW Forum Software Issues
    Scheduled Pinned Locked Moved Ideas Box & Board Issues
    78 Posts 17 Posters 8.5k Views 19 Watching
      Gábor @gullfo
      @gullfo said in NEW Forum Software Issues:
      1. part way scrolling through a list of posts suddenly there is some refresh looping causing the entire page from the advert on down to jump back and forth (up and down really) making things unusable.
      We have set pagination on to prevent this. You can change this setting at your personal settings.
        Rich O Brien Moderator @rv1974
        @rv1974 All I ask is time and patience while we dial stuff in. Imagine its your brand new home and you get to paint it and decorate it. But first we need the utilities to work.
        R 1 Reply Last reply Reply Quote 0
          rv1974 @Rich O Brien
          @Rich-O-Brien no problemo, is it in plans at least?
            @rv1974 yes, but right now we are resolving logging issues for those impacted.
            I understand your not digging the visuals. Its on our todo list
              No more "Your posts" ?
              majidM 1 Reply Last reply Reply Quote 1
                External links don't works anymore like this
                [image]https://images2.imgbox.com/4d/ce/GMEgEXqA_o.gif[/image]
                Same links were working yesterday!
                same image in direct drag & drop!
                GIFwombo.gif![GIFwombo1.gif]Free Krea(/assets/uploads/files/1710177720075-gifwombo1.gif) ![GIF_krea.gif]GIFwombo1.gifGIF_krea.gif
                  Rich O Brien Moderator @pilou
                  @pilou If you click Help
                  You can see new way to link images
                  ![Image](http://url/a.png)
                  not
                  [image][/image]
                  • ntxdaveN Offline
                    ntxdave @Box
                    @Box
                    I am not seeing these 2 icons. Is it a iPad issue (which is where I look at the forums most of the tone)?
                    Press F1...thank me later
                    • Rich O BrienR Rich O Brien moved this topic from SketchUcation Community Forums on
                      Rich O Brien Moderator @ntxdave
                      @ntxdave
                      Have you tried pressing your avatar to expose more options?
                      There's lots of new toys to play with so take your time and explore the interface. There's no documentation to follow as its forum software. You will gradually find things.
                      It is also highly customisable so a menu position for one user maybe located differently to another. That is why its important you poke around. Not to find a problem but to just explore it.
                      I know its a major shift but take the time and explore the UI. Its the best way to learn.
                      • ntxdaveN Offline
                        ntxdave @Rich O Brien
                        @Rich-O-Brien said in NEW Forum Software Issues:
                        @ntxdave
                        Yes, I did not see other options. Either I am just missing something or maybe it is something related to my iPad. I just see a number on my avatar. I cannot do a screen capture to show you what I see/don’t see. 😞
                        It is also highly customisable so a menu position for one user maybe located differently to another. That is why it’s important you poke around. Not to find a problem but to just explore it.
                        I have not seen options for customizing the menu unless you are talking about the list of things on the settings page.
                        Again, I would like to point out that I do not see the things @Box pointed out before. I have seen some things if I click to have a side panel show up on my iPad.
                        I know it’s a major shift but take the time and explore the UI. It’s the best way to learn.
                        • ntxdaveN Offline
                          ntxdave @ntxdave
                          @ntxdave
                          Ok, I just figured out what @Box pointed out. Thanks..........
                            sashapepperspray
                            What happened to private messaging? (and how can I see my old ones)?
                              rv1974
                              Some imperfections:
                              I'm very used to entering N in address bar in Firefox and get "new posts" on forums. Now it's redirecting to the main board - not good.
                              Was really needed to rename New to Recent?
                              Going from forum to plugin store to download stuff still demands to login once again.
                              'Your posts' are gone.
                              I'd prefer 'edit' pencil button not to be buried in dropbox menu
                                @rv1974 said in NEW Forum Software Issues:
                                We didn't rename anything. Its the newer software's naming convention. We will take a look at URL slug
                                So would I....will see if there's an option to customise button positions
                                @sashapepperspray said in NEW Forum Software Issues:
                                We still have the older forum. Private messages are not capable to be migrated so we'll provide a means to download your messages to CSV once we finish resolving issues here.
                                alsomarA 1 Reply Last reply Reply Quote 1
                                • alsomarA Offline
                                  alsomar Extension Creator @Rich O Brien
                                  Hi there! I like the new look, but I can't find where to change my signature.
                                  Alejandro Soriano Visuals · All my links
                                  BoxB Rich O BrienR 2 Replies Last reply Reply Quote 0
                                  • majidM Offline
                                    majid @pilou
                                    @pilou said in NEW Forum Software Issues:
                                    I had the same question...
                                    • BoxB Offline
                                      Box @alsomar
                                      @alsomar Click your Avatar, top right and choose Edit Profile then scroll down to Signature and then to save changes.
                                        Rich O Brien Moderator @alsomar
                                        @alsomar I believe you maybe behind the reputation system this newer forum uses.
                                        So maybe @Box suggestion is unavailable to you. If you are unable to change it let me know and I'll see what we can do.
                                        I'd be interested to know if you are able or not.
                                        gullfoG 1 Reply Last reply Reply Quote 0
                                        • gullfoG Offline
                                          gullfo @Rich O Brien
                                          @Rich-O-Brien doesn't look like there is an option to edit signature in the settings or profile areas (found via the vertical triple dots).
                                          also, the "your posts" is called "best posts" - maybe call it "latest posts" or "recent posts" as i'm sure not all my most recent posts are the "best" ones 🙂
                                          Glenn
                                          http://www.runnel.com
                                          Gus RG Rich O BrienR 2 Replies Last reply Reply Quote 1
                                          • Gus RG Offline
                                            Gus R @gullfo
                                            Did you try clicking on your profile image thumbnail on the upper right and clicking "edit profile" in the pull down menu?
                                            www.instagram.com/gusrobatto/
                                            www.facebook.com/gusrobatto
                                            • 2 / 4
