    Rayscaper New Releases
    rayscaperrender
    466 Posts 12 Posters 213.6k Views 13 Watching
    • P
      Hey, Rayscaper users!
      Rayscaper 0.9.93 Beta is available. You can get it via:
      • The SketchUcation store.
      • Direct download: Rayscaper_Win_0.9.93_Beta.rbz.
      I recommend upgrading to the latest version.
      What Changed?
      • Fix SketchUp tag visibility updates for nested groups and components. Nested geometry now appears and reappears correctly in Rayscaper when you toggle tags in SketchUp, matching the SketchUp viewport more reliably.
      • Fix material picking when hidden or invisible objects sit in front of visible geometry. The picker now selects the material you clicked instead of the hidden object blocking it.
      • Fix crashes after exploding SketchUp tag folders and then changing tag visibility.
      • Improve viewport navigation and panel controls with a simpler pan/zoom path and a fixed panel layout.
      Full release notes: rayscaper.com/manual/release-notes
      Help Me Build the Community 👍
      If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating
      and helps me showcase its capabilities to new users.
      Follow me on X.
      Happy Rendering!
      Thomas
      • P
        Rayscaper users, a heads up: I accidentally uploaded the previous 0.9.92 version to the SketchUcation Extension Store. If you installed Rayscaper in the last 4 days, you may have reinstalled the previous version. (@mike-amos Thanks for the heads up!).
        I’ve uploaded the latest 0.9.93 version now. If you download and install the extension again, it should install version 0.9.93 correctly.
        Apologies for the hassle.
        Happy Rendering!
        Thomas
        ntxdaveN 1 Reply Last reply
          No hassle, stuff happens remain chill mate.
            The new build is good, when hiding the 'assets' panel the progress bar is also lost. Not a major issue as when it comes to labelling the render, unhiding the assets is doable.
            It would be useful when progress is slow as a stalled render is not so obvious when the progress bar is hidden.
            P 1 Reply Last reply
            • ntxdaveN
              ntxdave @pixelcruncher
              Happy Rendering!
              Thomas
              Is there a way within Rayscaper to update to the latest version? If not, is this something you could add to the ui?
              Press F1...thank me later
                On a few occasions I have downloaded the latest build and used the sketchup extension manager. This it what I have used for rollback to last version to check behaviour.
                  Rich O Brien Moderator @ntxdave
                  If you install extensions using Sketchucation Tools then it will prompt you to update. It has been that way for years.
                  • KrassK
                    Krass
                    hello, I'm trying this new version but I get a bugg, It doens't want to render anymore. I get this error message
                    I will send you my log file
                    Krass
                    • ntxdaveN
                      ntxdave @Rich O Brien
                      I agree @rich-o-brien but when I went there yesterday it said it said all my extensions were up to date. I will look again today. That is what prompted my post.
                        There was an issue where the posted version of Rayscaper was incorrect, it had .92 as the latest. If you try again you will get .93 as the uploaded file has been corrected.
                        I can certify to this as I have now got the updated .93 installed.
                          If you installed extensions manually. That is you grab the RBZ off the site and install it via Extensions > Extension Manager then don't expect Sketchucation Tools to flag an update.
                          If you install extensions via Sketchucation Tools dialog then we prompt you to install future updates
                          • ntxdaveN
                            ntxdave
                            Not sure now how I originally installed the extension, but I feel pretty confident I have updated it before via SketchUcation Tools. When I go to the SketchUp Extension manager, it says I have 0.9.92. I would like to update to the 0.9.93 version. Does this mean I need to download the new version and install if "from scratch" or is there some way I can do it via SketchUcation Tools?
                            • KrassK
                              Krass
                              I should point out that I initially succeeded with a project in version 93. Then this problem occurred.
                              Krass
                                Open Extensions > Sketchucation > ExtensionStore
                                Search for Rayscaper and click install.
                                • ntxdaveN
                                  @Rich-O-Brien OK, got the latest version installed now.
                                  I should have known this myself. DUH!
                                  • G
                                    gabrielaher Newcomers
                                    How its takes to give the license via email???
                                    • P
                                      pixelcruncher Extension Creator @Mike Amos
                                      Hey @Mike-Amos,
                                      Could you provide a screenshot? Here's what I see when hiding the assets panel. As you can see I still have a progress bar, so I think we are talking about different things:
                                      • P
                                        @Krass
                                        Thanks for the report, I can confirm the error with GPU rendering. Would you mind sending me the scene so I can try to reproduce the error?
                                        Thanks,
                                        Thomas
                                        KrassK 1 Reply Last reply
                                        • P
                                          pixelcruncher Extension Creator @gabrielaher
                                          Hi @gabrielaher ,
                                          You can buy a Rayscaper license here (if you are logged in): https://sketchucation.com/purchase-smart.php?plugin=rayscaper
                                          To manage a license you already have, you can do that here: https://sketchucation.com/webshop/my-licences.php
                                          Let us know if you need more help.
                                          Regards,
                                          Thomas
                                          • KrassK
                                            Krass @pixelcruncher
                                            @Krass
                                            Thanks,
                                            Thomas
                                            Hello, it's done, I sent you the file
                                            Krass
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 23 / 24
