    Rayscaper New Releases
    rayscaperrender
    743 Posts 14 Posters 312.1k Views 15 Watching
      • pixelcruncherP
        Hey, Rayscaper users!
        Rayscaper 0.9.93 Beta is available. You can get it via:
        • The SketchUcation store.
        • Direct download: Rayscaper_Win_0.9.93_Beta.rbz.
        I recommend upgrading to the latest version.
        What Changed?
        • Fix SketchUp tag visibility updates for nested groups and components. Nested geometry now appears and reappears correctly in Rayscaper when you toggle tags in SketchUp, matching the SketchUp viewport more reliably.
        • Fix material picking when hidden or invisible objects sit in front of visible geometry. The picker now selects the material you clicked instead of the hidden object blocking it.
        • Fix crashes after exploding SketchUp tag folders and then changing tag visibility.
        • Improve viewport navigation and panel controls with a simpler pan/zoom path and a fixed panel layout.
        Full release notes: rayscaper.com/manual/release-notes
        Help Me Build the Community 👍
        If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating
        and helps me showcase its capabilities to new users.
        Follow me on X.
        Happy Rendering!
        Thomas
        • pixelcruncherP
          Rayscaper users, a heads up: I accidentally uploaded the previous 0.9.92 version to the SketchUcation Extension Store. If you installed Rayscaper in the last 4 days, you may have reinstalled the previous version. (@mike-amos Thanks for the heads up!).
          I’ve uploaded the latest 0.9.93 version now. If you download and install the extension again, it should install version 0.9.93 correctly.
          Apologies for the hassle.
          Happy Rendering!
          Thomas
          ntxdaveN 1 Reply Last reply
            No hassle, stuff happens remain chill mate.
              The new build is good, when hiding the 'assets' panel the progress bar is also lost. Not a major issue as when it comes to labelling the render, unhiding the assets is doable.
              It would be useful when progress is slow as a stalled render is not so obvious when the progress bar is hidden.
              • ntxdaveN
                ntxdave @pixelcruncher
                Happy Rendering!
                Thomas
                Is there a way within Rayscaper to update to the latest version? If not, is this something you could add to the ui?
                Press F1...thank me later
                  On a few occasions I have downloaded the latest build and used the sketchup extension manager. This it what I have used for rollback to last version to check behaviour.
                    Rich O Brien Moderator @ntxdave
                    If you install extensions using Sketchucation Tools then it will prompt you to update. It has been that way for years.
                    • KrassK
                      Krass
                      hello, I'm trying this new version but I get a bugg, It doens't want to render anymore. I get this error message
                      I will send you my log file
                      Krass
                      • ntxdaveN
                        ntxdave @Rich O Brien
                        I agree @rich-o-brien but when I went there yesterday it said it said all my extensions were up to date. I will look again today. That is what prompted my post.
                          There was an issue where the posted version of Rayscaper was incorrect, it had .92 as the latest. If you try again you will get .93 as the uploaded file has been corrected.
                          I can certify to this as I have now got the updated .93 installed.
                            If you installed extensions manually. That is you grab the RBZ off the site and install it via Extensions > Extension Manager then don't expect Sketchucation Tools to flag an update.
                            If you install extensions via Sketchucation Tools dialog then we prompt you to install future updates
                            • ntxdaveN
                              ntxdave
                              Not sure now how I originally installed the extension, but I feel pretty confident I have updated it before via SketchUcation Tools. When I go to the SketchUp Extension manager, it says I have 0.9.92. I would like to update to the 0.9.93 version. Does this mean I need to download the new version and install if "from scratch" or is there some way I can do it via SketchUcation Tools?
                              • KrassK
                                Krass
                                I should point out that I initially succeeded with a project in version 93. Then this problem occurred.
                                Krass
                                  Open Extensions > Sketchucation > ExtensionStore
                                  Search for Rayscaper and click install.
                                  • ntxdaveN
                                    @Rich-O-Brien OK, got the latest version installed now.
                                    I should have known this myself. DUH!
                                    • G
                                      gabrielaher Newcomers
                                      How its takes to give the license via email???
                                      • pixelcruncherP
                                        pixelcruncher Extension Creator @Mike Amos
                                        Hey @Mike-Amos,
                                        Could you provide a screenshot? Here's what I see when hiding the assets panel. As you can see I still have a progress bar, so I think we are talking about different things:
                                        • pixelcruncherP
                                          @Krass
                                          Thanks for the report, I can confirm the error with GPU rendering. Would you mind sending me the scene so I can try to reproduce the error?
                                          Thanks,
                                          Thomas
                                          KrassK 1 Reply Last reply
                                          • pixelcruncherP
                                            pixelcruncher Extension Creator @gabrielaher
                                            Hi @gabrielaher ,
                                            You can buy a Rayscaper license here (if you are logged in): https://sketchucation.com/purchase-smart.php?plugin=rayscaper
                                            To manage a license you already have, you can do that here: https://sketchucation.com/webshop/my-licences.php
                                            Let us know if you need more help.
                                            Regards,
                                            Thomas
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 37
                                            • 38
                                            • 23 / 38
