    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 620.2k Views 151 Watching
      MarcusS
      Fredo6 Plugins Information on 2025-09-22 11:27:32 +0200
      • Platform: x64-mswin64_140 - Ruby: 3.2.2
      • Sketchup: 25.0.660
      • LibFredo6: v15.4b
      • LibFredo6 Binary loaded
      • Sketchucation ExtensionStore: 4.4.1
      • SCFLicense: v6.4a - 74
      • Fredo6 Plugins
        FredoCorner v2.7a
      • SCFLicense directory present
        Signature File: 2025-09-21 17:08:52 +0200
        @MarcusS If you got to https://sketchucation.com/webshop/my-licences.php can you release any seats?
        M 1 Reply Last reply Reply Quote 0
          MarcusS @Rich O Brien
          @Rich-O-Brien, yes, that worked. Thanks!
            RASKL
            Hello. I've been using Fredocorner for a number of years but it has recently stopped working.
            I am on SU 25.0.660 64 bit. Windows.
            I hover over the toolbar and i get the label saying "Round corners in 3D" but when i click the buttons nothing happens.
            Please help!
            Dan
              @RASKL
              Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
              • G Offline
                Gent
                Dear Fredo! I thank you for your work. It means a lot to me as an aspiring designer. I bought some of your products and they are great. But I have a question and I do not know where to ask it to get your answer. Situation: I want to stop working on the Windows 10 operating system and upgrade to version 11. Will the licenses for your plugins that I bought be relevant? Will I be able to use them on the new operating system? Thank you.
                  Rich O Brien Moderator @Gent
                  @Gent
                  Yes, they will work. You will need to release seats at https://sketchucation.com/webshop/my-licences.php because if the device is the same but the OS changes then the licensing will see it as a new device.
                  • G Offline
                    Gent
                    @Rich-O-Brien Thank you for your quick answer!
                      ArqFigueroa
                      Hi ! Can somebody help me please, Been working with the free version but after pay the license it stop working
                        Rich O Brien Moderator @ArqFigueroa
                        @ArqFigueroa Share the file please
                          ArqFigueroa
                          It happens with any file, even in a new one 😞
                            @ArqFigueroa Please enable this edge setting
                              ArqFigueroa
                              Ooh it works ! Thank you so much !!!
                                @ArqFigueroa It is the edge property filter. You had yours set to not select Hard edges.
                                • G Offline
                                  GraceMien Newcomers
                                  Hi there! I was curious if it's possible to round a corner with an uneven offset? I'm looking through guides and documentation, but I figured it would probably be easier to just ask the source directly instead of spending a couple hours researching a feature that might not even exist. Thank you for your time!
                                  G 1 Reply Last reply Reply Quote 1
                                    Click the edge and type the variable offset in the VCB as either a length/radius or %
                                    • G Offline
                                      GraceMien Newcomers @GraceMien
                                      Oh awesome! Thank you so much for such a quick and helpful reply. I really appreciate it.
                                      1 Reply Last reply πŸ‘ Reply Quote 1
                                        talegend
                                        this license has a different name , when I click on activate license i can't see the lices
                                        license for round corner doesn't have FredoCorner word and that's why I can't see it
                                        I can't activate this ,
                                        Fredo Push Pull worked fine , but this one is not showing
                                          Dave R @talegend
                                          @talegend said in [Plugin][$] FredoCorner - v2.7a - 31 Mar 24:
                                          Round Corner and FredoCorner are two different extensions and each requires a different license. Which one did you actually purchase the license for? Install that one.
                                            rv1974
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 22 / 23
