    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 613.5k Views 151 Watching
      @newnoob said:
      I'm using SketchUp 2021, it's been a while since I updated my profile.
      Yes. It most certainly has been a while. Please update it now. That information helps us help you.
      @newnoob said:
      At the start I didn't even know that I have and need ExtensionStore tools, only until after I installed fredospline and tried to use it a warning popped and up informing me that I needed to update it.
      The SCF Extension Store tool has been required from the first point when Fredo's extensions became commercial. Really you should have been using it for years as it makes searching for and installing extensions from Sketchucation so much easier. It also makes it much easier when it comes time to udate to the next version of SketchUp. You can install the SCF tool first and use it to install your bundle of SCF extensions without having to search for them all.
      @newnoob said:
      Well now everything is working again, thanks for listen to my update pain. 😢 😎
      You're welcome.
        rv1974
        Hello Fredo,
        1. Is it possible to keep the new offset faces selectedafter the command is finished?
        2. When geometry selected is it possible to filter out the hard edges* and process only edges laying on 'inner' faces?
          *- I assume some extra 'angle between faces' parameter would be needed.
        • F Offline
          Filippidi
          Well,
          my Fredo Corner plugin has expired and I upgrade it via sketchupucation to the latest version, but it does not work. I also upgrate LibFredo6 to the latest version v13.7a. I tried all the posibble intallation methods but still says that this version of fredo corner has expired. Please upgrade to the latest version.
          Can anyone help me please?
            Have you purchased the license for RoundCorner? Are you still using SketchUp 2016 Pro as indicated in your forum profile?
              mamzzou
              Hi everyone !
              I made all the update needed (i have the latest version of fredo lib6 v13.7a and the latest version of sketchucation tools v4.3.0)
              and the pluggin doesn work, i close sketchup many times, i shut down my computer many times and nothing works..
              i cannot use the fredo tools joint push pull too...
              Can someone help me pleaaaaaaase ?
              I checked my license and i have perpetual license so everything's okay...
                Go to...
                https://i.imgur.com/VQBGaYg.png
                https://i.imgur.com/LMJ7ugP.png
                Copy text and paste it here
                  Are you still using the version of SketchUp listed in your profile?
                    If you haven't got a version >=2017 nothing will work !
                      Dunnys
                      Hi Fredo...
                      Great plugin!!! I do have an issue at the moment with a object that I trying to get the corners / edges rounded on. one of the edges causes an ruby error "undefined method `[]' for nil:NilClass" that sound to me like a pointer issue some where, here is the log from ruby.
                      i'm running SU2021 pro. and have latest version of plugin and fredolib installed. I have attachet screenshot and sketchup model
                      Again thx. for this great plugin.
                      Regards
                      Michael
                      Date: 25-Jan-23 13:29:08
                      An error occurred in FredoCorner
                      An error occured in the Ruby code
                      fredocorneralgo.rbe: 2618 -- chemin_analyze_crossing
                      fredocorneralgo.rbe: 2421 -- brane_intersect_chemins
                      fredocorneralgo.rbe: 2060 -- block in catena_process_branes_protected
                      fredocorneralgo.rbe: 2047 -- each
                      fredocorneralgo.rbe: 2047 -- catena_process_branes_protected
                      fredocorneralgo.rbe: 2009 -- block in catena_process_branes
                      fredocorneralgo.rbe: 2008 -- catch
                      fredocorneralgo.rbe: 2008 -- catena_process_branes
                      fredocorneralgo.rbe: 965 -- block in solid_construct_branes
                      fredocorneralgo.rbe: 964 -- each
                      fredocorneralgo.rbe: 964 -- solid_construct_branes
                      fredocorneralgo.rbe: 919 -- block in solid_reconstruction
                      fredocorneralgo.rbe: 918 -- each
                      fredocorneralgo.rbe: 918 -- solid_reconstruction
                      fredocorneralgo.rbe: 883 -- solid_add_remove_edges
                      fredocornertool.rbe: 1840 -- selection_change
                      fredocornertool.rbe: 1828 -- selection_add_remove_edges
                      fredocornertool.rbe: 1851 -- selection_set
                      fredocornertool.rbe: 1533 -- block in preselection_instantiate
                      fredocornertool.rbe: 1530 -- each
                      fredocornertool.rbe: 1530 -- preselection_instantiate
                      fredocornertool.rbe: 1525 -- preselection_analyze
                      fredocornertool.rbe: 761 -- true_activate
                      fredocornertool.rbe: 746 -- block in activate
                      lib6plugin.rbe: 1758 -- tem_context
                      fredocornertool.rbe: 746 -- activate
                      fredocornertool.rbe: 194 -- select_tool
                      fredocornertool.rbe: 194 -- launch
                      fredocornertool.rbe: 176 -- action__mapping
                      data6.rb: 65 -- call
                      data6.rb: 65 -- launch_action
                      lib6plugin.rbe: 240 -- launch_action
                      bootstrap_fredocorner.rbe: 103 -- launch_action
                      bootstrap_fredocorner.rbe: 118 -- block in startup
                      lib6plugin.rbe: 1469 -- command_invoke
                      lib6plugin.rbe: 1449 -- block (2 levels) in build_config_commands
                      lib6traductor.rbe: 1385 -- block in add_command
                      controller_lordofthetoolbars.rbe: 133 -- block in new
                      fredo_corners.zip
                        brad_jessicamay
                        Plugin no longer works with sketchup
                          Some more info would help us help you.
                          Are your Sketchucation Tools updated to 4.3.0?
                          Sketchucation Tools | SketchUcation
                          (sketchucation.com)
                          Is your Libfredo up to date?
                          SketchUp Plugins | PluginStore | SketchUcation
                          SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                          (sketchucation.com)
                          Same for FredoCorner?
                            That is not a very helpful post !
                            Please explain how it doesn't work, SketchUp version, all error messages, Ruby Console output etc, and confirm that you have the latest versions of the extension, and LibFredo6, and the SketchUcation toolset installed [for the licensing] and that you have restarted SketchUp to sync everything.
                              satori0904 Newcomers
                              nice to meet you
                              I bought the app the other day
                              An error occurred in the app and I can no longer use it.
                              sketchup2022
                              fred corner 2.6
                              LibFredo6 13.7
                              Sketch Ucation 4.3.0
                              is using
                                nice to meet you
                                sketchup2022
                                fred corner 2.6
                                LibFredo6 13.7
                                is using
                                • fredo6F Offline
                                  fredo6
                                  Could you upgrade to LibFredo6 v13.9. This should solve the problem.
                                    Hello
                                    upgrade LibFredo6 v13.9
                                    I tried it, but it didn't improve.
                                      Your profile says you are using SketchUp 2017 Make on Mac. Is that correct? What version of Mac OS?
                                      • fredo6F Offline
                                        fredo6
                                        @satori0904
                                        Based on the picture you posted, it seems that this is not a problem of installation, but a problem while using the plugin.
                                        Not sure, because your screenshot does not show the button palette, but it is likely that you have the Edge Filter not properly set.
                                          Hello
                                          thank you all
                                          After reinstalling Sketchup, it worked.
                                          Thank you very much!
                                          • 8 Offline
                                            8 perf 0 Newcomers
                                            Ok, I guess add me to the list of users who can no longer use Fredo plugins. Running 2017 Make, on mac os 10.14. All the newest sketchucation/ fredo dependencies installed.
                                            Every last Fredo plugin now comes up with a license error as having expired back in early February.
                                            Am I to understand that there are absolutely NO free options on these plugins anymore? Even the ones I have donated to and been using with zero problems for over 5 years? No other plugins downloaded from Sketchucation seem to have this issue. What changed and why?
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 18 / 23
