    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 687.0k Views 151 Watching
      mamzzou
      Hi everyone !
      I made all the update needed (i have the latest version of fredo lib6 v13.7a and the latest version of sketchucation tools v4.3.0)
      and the pluggin doesn work, i close sketchup many times, i shut down my computer many times and nothing works..
      i cannot use the fredo tools joint push pull too...
      Can someone help me pleaaaaaaase ?
      I checked my license and i have perpetual license so everything's okay...
        Go to...
        https://i.imgur.com/VQBGaYg.png
        https://i.imgur.com/LMJ7ugP.png
        Copy text and paste it here
          Are you still using the version of SketchUp listed in your profile?
            If you haven't got a version >=2017 nothing will work !
              Dunnys
              Hi Fredo...
              Great plugin!!! I do have an issue at the moment with a object that I trying to get the corners / edges rounded on. one of the edges causes an ruby error "undefined method `[]' for nil:NilClass" that sound to me like a pointer issue some where, here is the log from ruby.
              i'm running SU2021 pro. and have latest version of plugin and fredolib installed. I have attachet screenshot and sketchup model
              Again thx. for this great plugin.
              Regards
              Michael
              Date: 25-Jan-23 13:29:08
              An error occurred in FredoCorner
              An error occured in the Ruby code
              fredocorneralgo.rbe: 2618 -- chemin_analyze_crossing
              fredocorneralgo.rbe: 2421 -- brane_intersect_chemins
              fredocorneralgo.rbe: 2060 -- block in catena_process_branes_protected
              fredocorneralgo.rbe: 2047 -- each
              fredocorneralgo.rbe: 2047 -- catena_process_branes_protected
              fredocorneralgo.rbe: 2009 -- block in catena_process_branes
              fredocorneralgo.rbe: 2008 -- catch
              fredocorneralgo.rbe: 2008 -- catena_process_branes
              fredocorneralgo.rbe: 965 -- block in solid_construct_branes
              fredocorneralgo.rbe: 964 -- each
              fredocorneralgo.rbe: 964 -- solid_construct_branes
              fredocorneralgo.rbe: 919 -- block in solid_reconstruction
              fredocorneralgo.rbe: 918 -- each
              fredocorneralgo.rbe: 918 -- solid_reconstruction
              fredocorneralgo.rbe: 883 -- solid_add_remove_edges
              fredocornertool.rbe: 1840 -- selection_change
              fredocornertool.rbe: 1828 -- selection_add_remove_edges
              fredocornertool.rbe: 1851 -- selection_set
              fredocornertool.rbe: 1533 -- block in preselection_instantiate
              fredocornertool.rbe: 1530 -- each
              fredocornertool.rbe: 1530 -- preselection_instantiate
              fredocornertool.rbe: 1525 -- preselection_analyze
              fredocornertool.rbe: 761 -- true_activate
              fredocornertool.rbe: 746 -- block in activate
              lib6plugin.rbe: 1758 -- tem_context
              fredocornertool.rbe: 746 -- activate
              fredocornertool.rbe: 194 -- select_tool
              fredocornertool.rbe: 194 -- launch
              fredocornertool.rbe: 176 -- action__mapping
              data6.rb: 65 -- call
              data6.rb: 65 -- launch_action
              lib6plugin.rbe: 240 -- launch_action
              bootstrap_fredocorner.rbe: 103 -- launch_action
              bootstrap_fredocorner.rbe: 118 -- block in startup
              lib6plugin.rbe: 1469 -- command_invoke
              lib6plugin.rbe: 1449 -- block (2 levels) in build_config_commands
              lib6traductor.rbe: 1385 -- block in add_command
              controller_lordofthetoolbars.rbe: 133 -- block in new
              fredo_corners.zip
                brad_jessicamay
                Plugin no longer works with sketchup
                  Some more info would help us help you.
                  Are your Sketchucation Tools updated to 4.3.0?
                  Sketchucation Tools | SketchUcation
                  (sketchucation.com)
                  Is your Libfredo up to date?
                  SketchUp Plugins | PluginStore | SketchUcation
                  SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                  (sketchucation.com)
                  Same for FredoCorner?
                    That is not a very helpful post !
                    Please explain how it doesn't work, SketchUp version, all error messages, Ruby Console output etc, and confirm that you have the latest versions of the extension, and LibFredo6, and the SketchUcation toolset installed [for the licensing] and that you have restarted SketchUp to sync everything.
                      satori0904 Newcomers
                      nice to meet you
                      I bought the app the other day
                      An error occurred in the app and I can no longer use it.
                      sketchup2022
                      fred corner 2.6
                      LibFredo6 13.7
                      Sketch Ucation 4.3.0
                      is using
                        nice to meet you
                        sketchup2022
                        fred corner 2.6
                        LibFredo6 13.7
                        is using
                        • fredo6F Offline
                          Could you upgrade to LibFredo6 v13.9. This should solve the problem.
                            Hello
                            upgrade LibFredo6 v13.9
                            I tried it, but it didn't improve.
                              Your profile says you are using SketchUp 2017 Make on Mac. Is that correct? What version of Mac OS?
                              • fredo6F Offline
                                @satori0904
                                Based on the picture you posted, it seems that this is not a problem of installation, but a problem while using the plugin.
                                Not sure, because your screenshot does not show the button palette, but it is likely that you have the Edge Filter not properly set.
                                  Hello
                                  thank you all
                                  After reinstalling Sketchup, it worked.
                                  Thank you very much!
                                  • 8 Offline
                                    8 perf 0 Newcomers
                                    Ok, I guess add me to the list of users who can no longer use Fredo plugins. Running 2017 Make, on mac os 10.14. All the newest sketchucation/ fredo dependencies installed.
                                    Every last Fredo plugin now comes up with a license error as having expired back in early February.
                                    Am I to understand that there are absolutely NO free options on these plugins anymore? Even the ones I have donated to and been using with zero problems for over 5 years? No other plugins downloaded from Sketchucation seem to have this issue. What changed and why?
                                      @8 perf said:
                                      Every last Fredo plugin now comes up with a license error as having expired back in early February ...
                                      ... What changed and why?
                                      Not all of Fredo's extensions require a paid license but a few of them do. FredoCorner became a "paid" extension quite a while back. Some others became "paid" extensions as of March 1st of 2022. There are loas of other extensions from Fredo6 as well as others that are still available at no charge. Fredo puts a lot of effort into keeping his extensions up to date and fixing things. The amount he's charging for the licenses is trivial. You certainly can choose to use other extensions if you don't find it worthwhile investing anything into your hobby.
                                      • N Offline
                                        NEKOEMPIRE
                                        hey, this is extreamly useful but for some reason a window pops up saying "an error occured in the ruby code"
                                        how do i fix that?
                                        Ruby Code issue
                                          Share the .skp file so we can see your model and help you sort out the issue.
                                          • 8 Offline
                                            8 perf 0 Newcomers
                                            To be specific, Curviloft, Joint Push Pull and the original Round Corner are the ones I use or used to use. All three were developed and running just fine, for my uses anyway, long before SU 2017. I was using them without issue just 6 months ago, still on SU 2017.
                                            Ever since Trimble took over from Google and switched to a subscription model, a lot of us hobbyists felt left behind. I dont use it professionally, and only now a few times a month for personal projects, so a high subscription price is out of the question. Anyone still using 2017 now no longer has access to the extension warehouse or the 3d warehouse via the app. This hurts. Something about a security flaw prompted this but I can still visit the website. I get it.
                                            The three plugins I mentioned work just fine on 2017 but i understand the development of newer/ better to keep pace with the upgrades in the master program are necessary. What I dont understand is cutting off access to the older, less sophisticated versions for the older version of SU 2017. Having donated back in the day for plugins designed for a free program, now being asked to buy a license to keep using them, hurts. A lot.
                                            What's so wrong with a free/ hobbyist license? Treat the hobbyists right and maybe when they decide to go pro, they bring you and your programs with them to the commercial licensed platforms.
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 18 / 23
