    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 662.3k Views 151 Watching
      @newnoob said:
      and then and I'm forced to read and click through a bunch of stuff, download, un- and reinstall, open and close this and that before the plugin works again.
      You're not being forced to do that. Why not take the easy route and let the ExtensionStore tool update those extensions that need it automatically?
      Are you still using an ancient Pre-2013 version of SketchUp as your profile indicates?
        Persepolis
        FredoCorner is now back in my tools menu as it should be. Thanks for the help Dave, my LibFredo6 was out of date, but it wasn't being caught when I used the Fredo6 check update tool. Lesson learned to check everything more carefully.
          You’re welcome.
          @persepolis said:
          …but it wasn't being caught when I used the Fredo6 check update tool.
          If you use the Sketchucation tool to install extensions from Sketchucation, you can use it to check for updates and install them when they are released. In the case of Fredo’s extensions it’s not uncommon that LibFredo6 gets an update around the same time his various tools get updated. The Sketchucation tool will install any updates that are available.
          • newnoobN Offline
            newnoob
            I'm using SketchUp 2021, it's been a while since I updated my profile.
            At the start I didn't even know that I have and need ExtensionStore tools, only until after I installed fredospline and tried to use it a warning popped and up informing me that I needed to update it.
            Well now everything is working again, thanks for listen to my update pain. 😢 😎
              Yes. It most certainly has been a while. Please update it now. That information helps us help you.
              The SCF Extension Store tool has been required from the first point when Fredo's extensions became commercial. Really you should have been using it for years as it makes searching for and installing extensions from Sketchucation so much easier. It also makes it much easier when it comes time to udate to the next version of SketchUp. You can install the SCF tool first and use it to install your bundle of SCF extensions without having to search for them all.
              You're welcome.
                rv1974
                Hello Fredo,
                1. Is it possible to keep the new offset faces selectedafter the command is finished?
                2. When geometry selected is it possible to filter out the hard edges* and process only edges laying on 'inner' faces?
                  *- I assume some extra 'angle between faces' parameter would be needed.
                • F Offline
                  Filippidi
                  Well,
                  my Fredo Corner plugin has expired and I upgrade it via sketchupucation to the latest version, but it does not work. I also upgrate LibFredo6 to the latest version v13.7a. I tried all the posibble intallation methods but still says that this version of fredo corner has expired. Please upgrade to the latest version.
                  Can anyone help me please?
                    Have you purchased the license for RoundCorner? Are you still using SketchUp 2016 Pro as indicated in your forum profile?
                      mamzzou
                      Hi everyone !
                      I made all the update needed (i have the latest version of fredo lib6 v13.7a and the latest version of sketchucation tools v4.3.0)
                      and the pluggin doesn work, i close sketchup many times, i shut down my computer many times and nothing works..
                      i cannot use the fredo tools joint push pull too...
                      Can someone help me pleaaaaaaase ?
                      I checked my license and i have perpetual license so everything's okay...
                        Go to...
                        https://i.imgur.com/VQBGaYg.png
                        https://i.imgur.com/LMJ7ugP.png
                        Copy text and paste it here
                          Are you still using the version of SketchUp listed in your profile?
                            If you haven't got a version >=2017 nothing will work !
                              Dunnys
                              Hi Fredo...
                              Great plugin!!! I do have an issue at the moment with a object that I trying to get the corners / edges rounded on. one of the edges causes an ruby error "undefined method `[]' for nil:NilClass" that sound to me like a pointer issue some where, here is the log from ruby.
                              i'm running SU2021 pro. and have latest version of plugin and fredolib installed. I have attachet screenshot and sketchup model
                              Again thx. for this great plugin.
                              Regards
                              Michael
                              Date: 25-Jan-23 13:29:08
                              An error occurred in FredoCorner
                              An error occured in the Ruby code
                              fredocorneralgo.rbe: 2618 -- chemin_analyze_crossing
                              fredocorneralgo.rbe: 2421 -- brane_intersect_chemins
                              fredocorneralgo.rbe: 2060 -- block in catena_process_branes_protected
                              fredocorneralgo.rbe: 2047 -- each
                              fredocorneralgo.rbe: 2047 -- catena_process_branes_protected
                              fredocorneralgo.rbe: 2009 -- block in catena_process_branes
                              fredocorneralgo.rbe: 2008 -- catch
                              fredocorneralgo.rbe: 2008 -- catena_process_branes
                              fredocorneralgo.rbe: 965 -- block in solid_construct_branes
                              fredocorneralgo.rbe: 964 -- each
                              fredocorneralgo.rbe: 964 -- solid_construct_branes
                              fredocorneralgo.rbe: 919 -- block in solid_reconstruction
                              fredocorneralgo.rbe: 918 -- each
                              fredocorneralgo.rbe: 918 -- solid_reconstruction
                              fredocorneralgo.rbe: 883 -- solid_add_remove_edges
                              fredocornertool.rbe: 1840 -- selection_change
                              fredocornertool.rbe: 1828 -- selection_add_remove_edges
                              fredocornertool.rbe: 1851 -- selection_set
                              fredocornertool.rbe: 1533 -- block in preselection_instantiate
                              fredocornertool.rbe: 1530 -- each
                              fredocornertool.rbe: 1530 -- preselection_instantiate
                              fredocornertool.rbe: 1525 -- preselection_analyze
                              fredocornertool.rbe: 761 -- true_activate
                              fredocornertool.rbe: 746 -- block in activate
                              lib6plugin.rbe: 1758 -- tem_context
                              fredocornertool.rbe: 746 -- activate
                              fredocornertool.rbe: 194 -- select_tool
                              fredocornertool.rbe: 194 -- launch
                              fredocornertool.rbe: 176 -- action__mapping
                              data6.rb: 65 -- call
                              data6.rb: 65 -- launch_action
                              lib6plugin.rbe: 240 -- launch_action
                              bootstrap_fredocorner.rbe: 103 -- launch_action
                              bootstrap_fredocorner.rbe: 118 -- block in startup
                              lib6plugin.rbe: 1469 -- command_invoke
                              lib6plugin.rbe: 1449 -- block (2 levels) in build_config_commands
                              lib6traductor.rbe: 1385 -- block in add_command
                              controller_lordofthetoolbars.rbe: 133 -- block in new
                              fredo_corners.zip
                                brad_jessicamay
                                Plugin no longer works with sketchup
                                  Some more info would help us help you.
                                  Are your Sketchucation Tools updated to 4.3.0?
                                  https://sketchucation.com/plugin/696-sketchucationtools
                                  Is your Libfredo up to date?
                                  https://sketchucation.com/pluginstore?pln=LibFredo6
                                  Same for FredoCorner?
                                    That is not a very helpful post !
                                    Please explain how it doesn't work, SketchUp version, all error messages, Ruby Console output etc, and confirm that you have the latest versions of the extension, and LibFredo6, and the SketchUcation toolset installed [for the licensing] and that you have restarted SketchUp to sync everything.
                                      satori0904 Newcomers
                                      nice to meet you
                                      I bought the app the other day
                                      An error occurred in the app and I can no longer use it.
                                      sketchup2022
                                      fred corner 2.6
                                      LibFredo6 13.7
                                      Sketch Ucation 4.3.0
                                      is using
                                        nice to meet you
                                        sketchup2022
                                        fred corner 2.6
                                        LibFredo6 13.7
                                        is using
                                        • fredo6F Offline
                                          Could you upgrade to LibFredo6 v13.9. This should solve the problem.
                                            Hello
                                            upgrade LibFredo6 v13.9
                                            I tried it, but it didn't improve.
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 18 / 23
