    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 731.8k Views 151 Watching
    • F
      Filippidi
      Well,
      my Fredo Corner plugin has expired and I upgrade it via sketchupucation to the latest version, but it does not work. I also upgrate LibFredo6 to the latest version v13.7a. I tried all the posibble intallation methods but still says that this version of fredo corner has expired. Please upgrade to the latest version.
      Can anyone help me please?
        Have you purchased the license for RoundCorner? Are you still using SketchUp 2016 Pro as indicated in your forum profile?
          mamzzou
          Hi everyone !
          I made all the update needed (i have the latest version of fredo lib6 v13.7a and the latest version of sketchucation tools v4.3.0)
          and the pluggin doesn work, i close sketchup many times, i shut down my computer many times and nothing works..
          i cannot use the fredo tools joint push pull too...
          Can someone help me pleaaaaaaase ?
          I checked my license and i have perpetual license so everything's okay...
            Go to...
            https://i.imgur.com/VQBGaYg.png
            https://i.imgur.com/LMJ7ugP.png
            Copy text and paste it here
              Are you still using the version of SketchUp listed in your profile?
                If you haven't got a version >=2017 nothing will work !
                  Dunnys
                  Hi Fredo...
                  Great plugin!!! I do have an issue at the moment with a object that I trying to get the corners / edges rounded on. one of the edges causes an ruby error "undefined method `[]' for nil:NilClass" that sound to me like a pointer issue some where, here is the log from ruby.
                  i'm running SU2021 pro. and have latest version of plugin and fredolib installed. I have attachet screenshot and sketchup model
                  Again thx. for this great plugin.
                  Regards
                  Michael
                  Date: 25-Jan-23 13:29:08
                  An error occurred in FredoCorner
                  An error occured in the Ruby code
                  fredocorneralgo.rbe: 2618 -- chemin_analyze_crossing
                  fredocorneralgo.rbe: 2421 -- brane_intersect_chemins
                  fredocorneralgo.rbe: 2060 -- block in catena_process_branes_protected
                  fredocorneralgo.rbe: 2047 -- each
                  fredocorneralgo.rbe: 2047 -- catena_process_branes_protected
                  fredocorneralgo.rbe: 2009 -- block in catena_process_branes
                  fredocorneralgo.rbe: 2008 -- catch
                  fredocorneralgo.rbe: 2008 -- catena_process_branes
                  fredocorneralgo.rbe: 965 -- block in solid_construct_branes
                  fredocorneralgo.rbe: 964 -- each
                  fredocorneralgo.rbe: 964 -- solid_construct_branes
                  fredocorneralgo.rbe: 919 -- block in solid_reconstruction
                  fredocorneralgo.rbe: 918 -- each
                  fredocorneralgo.rbe: 918 -- solid_reconstruction
                  fredocorneralgo.rbe: 883 -- solid_add_remove_edges
                  fredocornertool.rbe: 1840 -- selection_change
                  fredocornertool.rbe: 1828 -- selection_add_remove_edges
                  fredocornertool.rbe: 1851 -- selection_set
                  fredocornertool.rbe: 1533 -- block in preselection_instantiate
                  fredocornertool.rbe: 1530 -- each
                  fredocornertool.rbe: 1530 -- preselection_instantiate
                  fredocornertool.rbe: 1525 -- preselection_analyze
                  fredocornertool.rbe: 761 -- true_activate
                  fredocornertool.rbe: 746 -- block in activate
                  lib6plugin.rbe: 1758 -- tem_context
                  fredocornertool.rbe: 746 -- activate
                  fredocornertool.rbe: 194 -- select_tool
                  fredocornertool.rbe: 194 -- launch
                  fredocornertool.rbe: 176 -- action__mapping
                  data6.rb: 65 -- call
                  data6.rb: 65 -- launch_action
                  lib6plugin.rbe: 240 -- launch_action
                  bootstrap_fredocorner.rbe: 103 -- launch_action
                  bootstrap_fredocorner.rbe: 118 -- block in startup
                  lib6plugin.rbe: 1469 -- command_invoke
                  lib6plugin.rbe: 1449 -- block (2 levels) in build_config_commands
                  lib6traductor.rbe: 1385 -- block in add_command
                  controller_lordofthetoolbars.rbe: 133 -- block in new
                  fredo_corners.zip
                  • B
                    brad_jessicamay
                    Plugin no longer works with sketchup
                      Some more info would help us help you.
                      Are your Sketchucation Tools updated to 4.3.0?
                      Sketchucation Tools | SketchUcation
                      (sketchucation.com)
                      Is your Libfredo up to date?
                      SketchUp Plugins | PluginStore | SketchUcation
                      SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                      (sketchucation.com)
                      Same for FredoCorner?
                        That is not a very helpful post !
                        Please explain how it doesn't work, SketchUp version, all error messages, Ruby Console output etc, and confirm that you have the latest versions of the extension, and LibFredo6, and the SketchUcation toolset installed [for the licensing] and that you have restarted SketchUp to sync everything.
                          satori0904 Newcomers
                          nice to meet you
                          I bought the app the other day
                          An error occurred in the app and I can no longer use it.
                          sketchup2022
                          fred corner 2.6
                          LibFredo6 13.7
                          Sketch Ucation 4.3.0
                          is using
                            nice to meet you
                            sketchup2022
                            fred corner 2.6
                            LibFredo6 13.7
                            is using
                            • fredo6F
                              Could you upgrade to LibFredo6 v13.9. This should solve the problem.
                                Hello
                                upgrade LibFredo6 v13.9
                                I tried it, but it didn't improve.
                                  Your profile says you are using SketchUp 2017 Make on Mac. Is that correct? What version of Mac OS?
                                  • fredo6F
                                    @satori0904
                                    Based on the picture you posted, it seems that this is not a problem of installation, but a problem while using the plugin.
                                    Not sure, because your screenshot does not show the button palette, but it is likely that you have the Edge Filter not properly set.
                                      Hello
                                      thank you all
                                      After reinstalling Sketchup, it worked.
                                      Thank you very much!
                                        8 perf 0 Newcomers
                                        Ok, I guess add me to the list of users who can no longer use Fredo plugins. Running 2017 Make, on mac os 10.14. All the newest sketchucation/ fredo dependencies installed.
                                        Every last Fredo plugin now comes up with a license error as having expired back in early February.
                                        Am I to understand that there are absolutely NO free options on these plugins anymore? Even the ones I have donated to and been using with zero problems for over 5 years? No other plugins downloaded from Sketchucation seem to have this issue. What changed and why?
                                          @8 perf said:
                                          Every last Fredo plugin now comes up with a license error as having expired back in early February ...
                                          ... What changed and why?
                                          Not all of Fredo's extensions require a paid license but a few of them do. FredoCorner became a "paid" extension quite a while back. Some others became "paid" extensions as of March 1st of 2022. There are loas of other extensions from Fredo6 as well as others that are still available at no charge. Fredo puts a lot of effort into keeping his extensions up to date and fixing things. The amount he's charging for the licenses is trivial. You certainly can choose to use other extensions if you don't find it worthwhile investing anything into your hobby.
                                          • N
                                            NEKOEMPIRE
                                            hey, this is extreamly useful but for some reason a window pops up saying "an error occured in the ruby code"
                                            how do i fix that?
                                            Ruby Code issue
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 18 / 23
