    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 731.8k Views 151 Watching
      @persepolis said:
      So I also need a new version of Sketchucation? Would have been nice if there was some notification for this.
      @persepolis said:
      I checked for a new version and installed it and the FredoCorner menu disappeared. Have tried uninstalling it and reinstalling it. License status says signed.
      FredoCorner shows up under Tools>Fredo6 Collection. It has done so for a long time.
      • E
        Elosegui
        Hello, I have problems buying the license. It allows me to pay by card, everything is ok but I don't receive the email with the license.
        thanks for the help
        • newnoobN
          newnoob
          Wow, that's annoying when Fredo plugins stop working from time to time and I'm forced to do some serious and confusing manual reading, clicking through warning messages, downloading and reinstalling this and that before the plugin is working again.
            @newnoob said:
            and then and I'm forced to read and click through a bunch of stuff, download, un- and reinstall, open and close this and that before the plugin works again.
            You're not being forced to do that. Why not take the easy route and let the ExtensionStore tool update those extensions that need it automatically?
            Are you still using an ancient Pre-2013 version of SketchUp as your profile indicates?
            • P
              Persepolis
              FredoCorner is now back in my tools menu as it should be. Thanks for the help Dave, my LibFredo6 was out of date, but it wasn't being caught when I used the Fredo6 check update tool. Lesson learned to check everything more carefully.
                You’re welcome.
                @persepolis said:
                …but it wasn't being caught when I used the Fredo6 check update tool.
                If you use the Sketchucation tool to install extensions from Sketchucation, you can use it to check for updates and install them when they are released. In the case of Fredo’s extensions it’s not uncommon that LibFredo6 gets an update around the same time his various tools get updated. The Sketchucation tool will install any updates that are available.
                • newnoobN
                  newnoob
                  I'm using SketchUp 2021, it's been a while since I updated my profile.
                  At the start I didn't even know that I have and need ExtensionStore tools, only until after I installed fredospline and tried to use it a warning popped and up informing me that I needed to update it.
                  Well now everything is working again, thanks for listen to my update pain. 😢 😎
                    Yes. It most certainly has been a while. Please update it now. That information helps us help you.
                    The SCF Extension Store tool has been required from the first point when Fredo's extensions became commercial. Really you should have been using it for years as it makes searching for and installing extensions from Sketchucation so much easier. It also makes it much easier when it comes time to udate to the next version of SketchUp. You can install the SCF tool first and use it to install your bundle of SCF extensions without having to search for them all.
                    You're welcome.
                      rv1974
                      Hello Fredo,
                      1. Is it possible to keep the new offset faces selectedafter the command is finished?
                      2. When geometry selected is it possible to filter out the hard edges* and process only edges laying on 'inner' faces?
                        *- I assume some extra 'angle between faces' parameter would be needed.
                      • F
                        Filippidi
                        Well,
                        my Fredo Corner plugin has expired and I upgrade it via sketchupucation to the latest version, but it does not work. I also upgrate LibFredo6 to the latest version v13.7a. I tried all the posibble intallation methods but still says that this version of fredo corner has expired. Please upgrade to the latest version.
                        Can anyone help me please?
                          Have you purchased the license for RoundCorner? Are you still using SketchUp 2016 Pro as indicated in your forum profile?
                            mamzzou
                            Hi everyone !
                            I made all the update needed (i have the latest version of fredo lib6 v13.7a and the latest version of sketchucation tools v4.3.0)
                            and the pluggin doesn work, i close sketchup many times, i shut down my computer many times and nothing works..
                            i cannot use the fredo tools joint push pull too...
                            Can someone help me pleaaaaaaase ?
                            I checked my license and i have perpetual license so everything's okay...
                              Go to...
                              https://i.imgur.com/VQBGaYg.png
                              https://i.imgur.com/LMJ7ugP.png
                              Copy text and paste it here
                                Are you still using the version of SketchUp listed in your profile?
                                  If you haven't got a version >=2017 nothing will work !
                                    Dunnys
                                    Hi Fredo...
                                    Great plugin!!! I do have an issue at the moment with a object that I trying to get the corners / edges rounded on. one of the edges causes an ruby error "undefined method `[]' for nil:NilClass" that sound to me like a pointer issue some where, here is the log from ruby.
                                    i'm running SU2021 pro. and have latest version of plugin and fredolib installed. I have attachet screenshot and sketchup model
                                    Again thx. for this great plugin.
                                    Regards
                                    Michael
                                    Date: 25-Jan-23 13:29:08
                                    An error occurred in FredoCorner
                                    An error occured in the Ruby code
                                    fredocorneralgo.rbe: 2618 -- chemin_analyze_crossing
                                    fredocorneralgo.rbe: 2421 -- brane_intersect_chemins
                                    fredocorneralgo.rbe: 2060 -- block in catena_process_branes_protected
                                    fredocorneralgo.rbe: 2047 -- each
                                    fredocorneralgo.rbe: 2047 -- catena_process_branes_protected
                                    fredocorneralgo.rbe: 2009 -- block in catena_process_branes
                                    fredocorneralgo.rbe: 2008 -- catch
                                    fredocorneralgo.rbe: 2008 -- catena_process_branes
                                    fredocorneralgo.rbe: 965 -- block in solid_construct_branes
                                    fredocorneralgo.rbe: 964 -- each
                                    fredocorneralgo.rbe: 964 -- solid_construct_branes
                                    fredocorneralgo.rbe: 919 -- block in solid_reconstruction
                                    fredocorneralgo.rbe: 918 -- each
                                    fredocorneralgo.rbe: 918 -- solid_reconstruction
                                    fredocorneralgo.rbe: 883 -- solid_add_remove_edges
                                    fredocornertool.rbe: 1840 -- selection_change
                                    fredocornertool.rbe: 1828 -- selection_add_remove_edges
                                    fredocornertool.rbe: 1851 -- selection_set
                                    fredocornertool.rbe: 1533 -- block in preselection_instantiate
                                    fredocornertool.rbe: 1530 -- each
                                    fredocornertool.rbe: 1530 -- preselection_instantiate
                                    fredocornertool.rbe: 1525 -- preselection_analyze
                                    fredocornertool.rbe: 761 -- true_activate
                                    fredocornertool.rbe: 746 -- block in activate
                                    lib6plugin.rbe: 1758 -- tem_context
                                    fredocornertool.rbe: 746 -- activate
                                    fredocornertool.rbe: 194 -- select_tool
                                    fredocornertool.rbe: 194 -- launch
                                    fredocornertool.rbe: 176 -- action__mapping
                                    data6.rb: 65 -- call
                                    data6.rb: 65 -- launch_action
                                    lib6plugin.rbe: 240 -- launch_action
                                    bootstrap_fredocorner.rbe: 103 -- launch_action
                                    bootstrap_fredocorner.rbe: 118 -- block in startup
                                    lib6plugin.rbe: 1469 -- command_invoke
                                    lib6plugin.rbe: 1449 -- block (2 levels) in build_config_commands
                                    lib6traductor.rbe: 1385 -- block in add_command
                                    controller_lordofthetoolbars.rbe: 133 -- block in new
                                    fredo_corners.zip
                                    • B
                                      brad_jessicamay
                                      Plugin no longer works with sketchup
                                        Some more info would help us help you.
                                        Are your Sketchucation Tools updated to 4.3.0?
                                        Sketchucation Tools | SketchUcation
                                        (sketchucation.com)
                                        Is your Libfredo up to date?
                                        SketchUp Plugins | PluginStore | SketchUcation
                                        SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                                        (sketchucation.com)
                                        Same for FredoCorner?
                                          That is not a very helpful post !
                                          Please explain how it doesn't work, SketchUp version, all error messages, Ruby Console output etc, and confirm that you have the latest versions of the extension, and LibFredo6, and the SketchUcation toolset installed [for the licensing] and that you have restarted SketchUp to sync everything.
                                            satori0904 Newcomers
                                            nice to meet you
                                            I bought the app the other day
                                            An error occurred in the app and I can no longer use it.
                                            sketchup2022
                                            fred corner 2.6
                                            LibFredo6 13.7
                                            Sketch Ucation 4.3.0
                                            is using
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 18 / 23
