    Personal test
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    37 Posts 6 Posters 20.9k Views 6 Watching
      Cool to see measures change! 😎
      • chriC Offline
        chri
        hi
        Here are my tests about Dim Factor/Pursue/repeat which allows to precisely adjust/pursue/repeat a movement.
        Note that the Dim Factor value is a percentage of the movement.
        It can be positive or negative
        The first example is about Translation , the second one about Rotation.
        (0.16666 allows rotation of 1/6 turn)
        (0.5 allows rotation of 1/2 turn)
        Clic on the pictures to anim
        Bonjour
        Voici mes tests a propos de "Dim Factor/Pursue/repeat" qui permet d'ajuster / poursuivre / répéter un déplacement.
        Notez que la valeur de "Dim Factor" est un pourcentage du mouvement.
        Elle peut ĂȘtre positive ou nĂ©gative
        Le premier exemple concerne la translation , le second , la rotation.
        ( 0.16666 permet la rotation de 1/6 de tour )
        ( 0.5 permet la rotation de 1/2 de tour )
        Cliquer sur les images pour les animer.
        Chri
        PERSONAL TEST DIM FACTOR1.skp
        PERSONAL TEST DIM FACTOR2.skp
        • chriC Offline
          chri
          a new test
            There is a new function "Follow path" ? Or it's just several manual start-end ?
            • chriC Offline
              chri
              Not a follow path fonction
              Each color is a different movement .
              Chri
                So the hell! 😉
                I believe that is the more important function to implement! đŸ€“
                Surely not easy!
                • F Offline
                  faust07
                  A nice example. It also shows, how complex simple animations can be. Sure you can apply the copy function for the individual sections well. Tricky it is when you have to animate the individual wheels of a 3D car properly for each curve.
                  A "Path Following" feature would be very helpful. Then would have to be determined an independent path move for the car and for each wheel...
                  • F Offline
                    faust07
                    Thanks! 👍
                    • emerald15E Offline
                      emerald15
                      which animation programme is this please?
                        Animator by Fredo 6! 😉
                          Must works also for components! 😉
                          • chriC Offline
                            chri
                            @fredo6 said:
                            hi
                            How will you manage to screw the two objects around the same axis?
                            The trajectory of the 2 objects starts well, finished well, but has a weird trajectory!
                            Chri
                            In fact, I have to think about it. Screw mode does not allow you to choose the pivot point, which is the center of gravity of each selected group.
                            So 2 problems:
                            1. change the center of rotation, especially when the solid is not 'centered' naturally.
                            2. Decide what one does for a set of objects. Either an individual screw or a screw grouped with respect to the center of gravity of all objects.
                              Fredo
                            --Comment t'y prendrai-tu pour visser les 2 objets autour d'un mĂȘme axe ?
                            La trajectoire des 2 objets débute bien , fini bien , mais a une trajectoire bizarre !
                            Chri
                            En fait, il faut que j'y réfléchisse. Le mode Screw ne permet pas de choisir le point pivot, qui est le centre de gravité de chaque groupe sélectionné.
                            Donc 2 problĂšmes:
                            1. changer le centre de rotation, en particulier quand les solide sont non 'centré' naturellement.
                            2. Decider ce qu'on fait pour un ensemble d'objets. Soit un screw individuel, soit un screw groupé par rapport au centre de gravité de tous les objects.
                              Fredo
                            %(#0000FF)[For non symmetrical parts and meanwhile here is a manipulation to simulate the screwing.
                            Create a symmetry on the blue piece and hide it.
                            Pour les piÚces non symétriques et en attendant voici une manip pour simuler le vissage .
                            Créer une symétrie sur la piÚce bleue et la masquer .]
                            Chri
                            TEST SCREW02.skp
                            • chriC Offline
                              chri
                              • chriC Offline
                                chri
                                Here , step by step , how to do a combined movement.
                                [highlight=#ffff40:11mopzv6]Click on the pictures to animate them[/highlight:11mopzv6]
                                Picture 0: general presentation
                                Picture 1: translation of the yellow cube
                                Picture 2: rotation of the yellow cube
                                Picture 3: rotation of the gray cube / yellow cube
                                Picture 4: modification of the timeline (rotation of the gray cube during the whole movement of the yellow)
                                Picture 5: rotation of the blue cube / gray cube and modification of the "timeline"
                                Voici étape par étape la réalisation d'un mouvement combiné.
                                [highlight=#ffff40:11mopzv6]Cliquer sur les images pour les animer[/highlight:11mopzv6]
                                image 0 : présentation generale
                                image 1 : translation du cube jaune
                                image 2 : rotation du cube jaune
                                image 3 : rotation du cube gris/cube jaune
                                image 4 : modification de la "timeline" ( rotation du cube gris pendant tout le déplacement du jaune )
                                image 5 : rotation du cube bleu/cube gris et modification de la "timeline"
                                Chri
                                MOUVEMENTS COMBINES2.skp
                                • chriC Offline
                                  chri
                                  Hi Fredo
                                  There is something wrong in my workflow ... but what ?
                                  click on the following pictures to anim.
                                  Il y a quelque chose qui cloche dans ma manip, mais quoi ?
                                  Chri
                                  MOUVEMENTS COMBINES.skp
                                  MOUVEMENTS COMBINES.7z
                                  • chriC Offline
                                    chri
                                    Hi Fredo
                                    New problem with SCREW and group
                                    Autre probleme avec SCREW et groupe
                                    Chri
                                    TEST SCREW02.skp
                                    • chriC Offline
                                      chri
                                      Please find attached , a short tutorial to show how to do an assembly / disassembly animation with ANIMATOR.
                                      On the basis of a mounted assembly consisting of groups,
                                      1 - Moves the objects in the disassembly order
                                      2 - make Ă  raz ( timeline to 0)
                                      3 - Save the ANIMATOR sequence
                                      4 - Choose "Play the clip From End to Start"
                                      5 - Start the animation and ... miracle, the job is done!
                                      [highlight=#ffff40:2g2lmq7k]Click on images to animate[/highlight:2g2lmq7k]
                                      Recall:
                                      A click suspends an animation - a double click restart.
                                      Thank you Fredo
                                      Bonjour
                                      Veuillez trouver ci-joint un petit tuto pour montrer comment réaliser une animation MONTAGE/DEMONTAGE avec ANIMATOR.
                                      Sur la base d'un ensemble monté constitué de groupes , on :
                                      1 - déplace les objets dans l'ordre du démontage
                                      2 - On met Ă  0.
                                      3 - on enregistre la séquence ANIMATOR
                                      4 - on choisi l'option "Play the clip From End to Start"
                                      ( jouer le clip depuis la fin jusqu’à son dĂ©but )
                                      5 - On lance l'animation et ... miracle , le job est fait !
                                      [highlight=#ffff40:2g2lmq7k]Cliquer sur les images pour animer[/highlight:2g2lmq7k]
                                      Rappel:
                                      un clic suspend une animation - un double clic , la relance.
                                      Merci Fredo
                                      Chri
                                      MONTAGE KIOSQUE.skp
                                      MONTAGE KIOSQUE.rar
                                      • 2 / 2
