    Personal test
    renderpluginsextensions
    37 Posts 6 Posters 20.9k Views 6 Watching
      I am right if i want object invisible during this little sequence?
      • ntxdaveN Offline
        ntxdave
        Yes, you can do it. See below:
        Click to play
        However, if there is going to be an overlap, you will need to capture the layer visibility at the beginning and end of each sequence.
        Hope this helps........
        Press F1...thank me later
        • chriC Offline
          chri
          [attachment=2:23mm6v40]<!-- ia2 -->no_visibility.jpg<!-- ia2 -->[/attachment:23mm6v40]
          Same as ntxave
          • ntxdaveN Offline
            ntxdave
            Chris, our responses overlapped. If you look at mine, you will see that you can also do it the way Pilou was asking about as long as there is no overlay with other visibilities.
            BTW: You and Pilou have give me some feedback on another thread where I was trying to rotate and object (garage door) but I still cannot find a way in that situation that works correctly (where panels follow the "track" for the garage door). See this thread: How to rotate better
              I have clicked this last icon first! 😳
                Cool to see measures change! 😎
                • chriC Offline
                  chri
                  hi
                  Here are my tests about Dim Factor/Pursue/repeat which allows to precisely adjust/pursue/repeat a movement.
                  Note that the Dim Factor value is a percentage of the movement.
                  It can be positive or negative
                  The first example is about Translation , the second one about Rotation.
                  (0.16666 allows rotation of 1/6 turn)
                  (0.5 allows rotation of 1/2 turn)
                  Clic on the pictures to anim
                  Bonjour
                  Voici mes tests a propos de "Dim Factor/Pursue/repeat" qui permet d'ajuster / poursuivre / répéter un déplacement.
                  Notez que la valeur de "Dim Factor" est un pourcentage du mouvement.
                  Elle peut être positive ou négative
                  Le premier exemple concerne la translation , le second , la rotation.
                  ( 0.16666 permet la rotation de 1/6 de tour )
                  ( 0.5 permet la rotation de 1/2 de tour )
                  Cliquer sur les images pour les animer.
                  Chri
                  PERSONAL TEST DIM FACTOR1.skp
                  PERSONAL TEST DIM FACTOR2.skp
                  • chriC Offline
                    chri
                    a new test
                      There is a new function "Follow path" ? Or it's just several manual start-end ?
                      • chriC Offline
                        chri
                        Not a follow path fonction
                        Each color is a different movement .
                        Chri
                          So the hell! 😉
                          I believe that is the more important function to implement! 🤓
                          Surely not easy!
                          • F Offline
                            faust07
                            A nice example. It also shows, how complex simple animations can be. Sure you can apply the copy function for the individual sections well. Tricky it is when you have to animate the individual wheels of a 3D car properly for each curve.
                            A "Path Following" feature would be very helpful. Then would have to be determined an independent path move for the car and for each wheel...
                            • F Offline
                              faust07
                              Thanks! 👍
                              • emerald15E Offline
                                emerald15
                                which animation programme is this please?
                                  Animator by Fredo 6! 😉
                                    Must works also for components! 😉
                                    • chriC Offline
                                      chri
                                      @fredo6 said:
                                      hi
                                      How will you manage to screw the two objects around the same axis?
                                      The trajectory of the 2 objects starts well, finished well, but has a weird trajectory!
                                      Chri
                                      In fact, I have to think about it. Screw mode does not allow you to choose the pivot point, which is the center of gravity of each selected group.
                                      So 2 problems:
                                      1. change the center of rotation, especially when the solid is not 'centered' naturally.
                                      2. Decide what one does for a set of objects. Either an individual screw or a screw grouped with respect to the center of gravity of all objects.
                                      --Comment t'y prendrai-tu pour visser les 2 objets autour d'un même axe ?
                                      La trajectoire des 2 objets débute bien , fini bien , mais a une trajectoire bizarre !
                                      Chri
                                      En fait, il faut que j'y réfléchisse. Le mode Screw ne permet pas de choisir le point pivot, qui est le centre de gravité de chaque groupe sélectionné.
                                      Donc 2 problèmes:
                                      1. changer le centre de rotation, en particulier quand les solide sont non 'centré' naturellement.
                                      2. Decider ce qu'on fait pour un ensemble d'objets. Soit un screw individuel, soit un screw groupé par rapport au centre de gravité de tous les objects.
                                      %(#0000FF)[For non symmetrical parts and meanwhile here is a manipulation to simulate the screwing.
                                      Create a symmetry on the blue piece and hide it.
                                      Pour les pièces non symétriques et en attendant voici une manip pour simuler le vissage .
                                      Créer une symétrie sur la pièce bleue et la masquer .]
                                      Chri
                                      TEST SCREW02.skp
                                      • chriC Offline
                                        chri
                                        • chriC Offline
                                          chri
                                          Here , step by step , how to do a combined movement.
                                          [highlight=#ffff40:11mopzv6]Click on the pictures to animate them[/highlight:11mopzv6]
                                          Picture 0: general presentation
                                          Picture 1: translation of the yellow cube
                                          Picture 2: rotation of the yellow cube
                                          Picture 3: rotation of the gray cube / yellow cube
                                          Picture 4: modification of the timeline (rotation of the gray cube during the whole movement of the yellow)
                                          Picture 5: rotation of the blue cube / gray cube and modification of the "timeline"
                                          Voici étape par étape la réalisation d'un mouvement combiné.
                                          [highlight=#ffff40:11mopzv6]Cliquer sur les images pour les animer[/highlight:11mopzv6]
                                          image 0 : présentation generale
                                          image 1 : translation du cube jaune
                                          image 2 : rotation du cube jaune
                                          image 3 : rotation du cube gris/cube jaune
                                          image 4 : modification de la "timeline" ( rotation du cube gris pendant tout le déplacement du jaune )
                                          image 5 : rotation du cube bleu/cube gris et modification de la "timeline"
                                          Chri
                                          MOUVEMENTS COMBINES2.skp
                                          • chriC Offline
                                            chri
                                            Hi Fredo
                                            There is something wrong in my workflow ... but what ?
                                            click on the following pictures to anim.
                                            Il y a quelque chose qui cloche dans ma manip, mais quoi ?
                                            Chri
                                            MOUVEMENTS COMBINES.skp
                                            MOUVEMENTS COMBINES.7z
                                            • 2 / 2
