    Personal test
    renderpluginsextensions
    37 Posts 6 Posters 22.4k Views 6 Watching
    • F Offline
      faust07
      A nice example. It also shows, how complex simple animations can be. Sure you can apply the copy function for the individual sections well. Tricky it is when you have to animate the individual wheels of a 3D car properly for each curve.
      A "Path Following" feature would be very helpful. Then would have to be determined an independent path move for the car and for each wheel...
      • F Offline
        faust07
        Thanks! 👍
        • emerald15E Offline
          emerald15
          which animation programme is this please?
            Animator by Fredo 6! 😉
              Must works also for components! 😉
              • chriC Offline
                chri
                @fredo6 said:
                hi
                How will you manage to screw the two objects around the same axis?
                The trajectory of the 2 objects starts well, finished well, but has a weird trajectory!
                Chri
                In fact, I have to think about it. Screw mode does not allow you to choose the pivot point, which is the center of gravity of each selected group.
                So 2 problems:
                1. change the center of rotation, especially when the solid is not 'centered' naturally.
                2. Decide what one does for a set of objects. Either an individual screw or a screw grouped with respect to the center of gravity of all objects.
                --Comment t'y prendrai-tu pour visser les 2 objets autour d'un même axe ?
                La trajectoire des 2 objets débute bien , fini bien , mais a une trajectoire bizarre !
                Chri
                En fait, il faut que j'y réfléchisse. Le mode Screw ne permet pas de choisir le point pivot, qui est le centre de gravité de chaque groupe sélectionné.
                Donc 2 problèmes:
                1. changer le centre de rotation, en particulier quand les solide sont non 'centré' naturellement.
                2. Decider ce qu'on fait pour un ensemble d'objets. Soit un screw individuel, soit un screw groupé par rapport au centre de gravité de tous les objects.
                %(#0000FF)[For non symmetrical parts and meanwhile here is a manipulation to simulate the screwing.
                Create a symmetry on the blue piece and hide it.
                Pour les pièces non symétriques et en attendant voici une manip pour simuler le vissage .
                Créer une symétrie sur la pièce bleue et la masquer .]
                Chri
                TEST SCREW02.skp
                • chriC Offline
                  chri
                  • chriC Offline
                    chri
                    Here , step by step , how to do a combined movement.
                    [highlight=#ffff40:11mopzv6]Click on the pictures to animate them[/highlight:11mopzv6]
                    Picture 0: general presentation
                    Picture 1: translation of the yellow cube
                    Picture 2: rotation of the yellow cube
                    Picture 3: rotation of the gray cube / yellow cube
                    Picture 4: modification of the timeline (rotation of the gray cube during the whole movement of the yellow)
                    Picture 5: rotation of the blue cube / gray cube and modification of the "timeline"
                    Voici étape par étape la réalisation d'un mouvement combiné.
                    [highlight=#ffff40:11mopzv6]Cliquer sur les images pour les animer[/highlight:11mopzv6]
                    image 0 : présentation generale
                    image 1 : translation du cube jaune
                    image 2 : rotation du cube jaune
                    image 3 : rotation du cube gris/cube jaune
                    image 4 : modification de la "timeline" ( rotation du cube gris pendant tout le déplacement du jaune )
                    image 5 : rotation du cube bleu/cube gris et modification de la "timeline"
                    Chri
                    MOUVEMENTS COMBINES2.skp
                    • chriC Offline
                      chri
                      Hi Fredo
                      There is something wrong in my workflow ... but what ?
                      click on the following pictures to anim.
                      Il y a quelque chose qui cloche dans ma manip, mais quoi ?
                      Cliquer sur les images pour les animer.
                      Chri
                      MOUVEMENTS COMBINES.skp
                      MOUVEMENTS COMBINES.7z
                      • chriC Offline
                        chri
                        Hi Fredo
                        New problem with SCREW and group
                        Autre probleme avec SCREW et groupe
                        Chri
                        TEST SCREW02.skp
                        • chriC Offline
                          chri
                          Please find attached , a short tutorial to show how to do an assembly / disassembly animation with ANIMATOR.
                          On the basis of a mounted assembly consisting of groups,
                          1 - Moves the objects in the disassembly order
                          2 - make à raz ( timeline to 0)
                          3 - Save the ANIMATOR sequence
                          4 - Choose "Play the clip From End to Start"
                          5 - Start the animation and ... miracle, the job is done!
                          [highlight=#ffff40:2g2lmq7k]Click on images to animate[/highlight:2g2lmq7k]
                          Recall:
                          A click suspends an animation - a double click restart.
                          Thank you Fredo
                          Bonjour
                          Veuillez trouver ci-joint un petit tuto pour montrer comment réaliser une animation MONTAGE/DEMONTAGE avec ANIMATOR.
                          Sur la base d'un ensemble monté constitué de groupes , on :
                          1 - déplace les objets dans l'ordre du démontage
                          2 - On met à 0.
                          3 - on enregistre la séquence ANIMATOR
                          4 - on choisi l'option "Play the clip From End to Start"
                          ( jouer le clip depuis la fin jusqu’à son début )
                          5 - On lance l'animation et ... miracle , le job est fait !
                          [highlight=#ffff40:2g2lmq7k]Cliquer sur les images pour animer[/highlight:2g2lmq7k]
                          Rappel:
                          un clic suspend une animation - un double clic , la relance.
                          Merci Fredo
                          Chri
                          MONTAGE KIOSQUE.skp
                          MONTAGE KIOSQUE.rar
                          • 2 / 2
