    Personal test
    renderpluginsextensions
    37 Posts 6 Posters 21.9k Views 6 Watching
    • chriC Offline
      chri
      @pilou said:
      I am right if i want object invisible during this little sequence?
      [attachment=2:23mm6v40]<!-- ia2 -->no_visibility.jpg<!-- ia2 -->[/attachment:23mm6v40]
      Same as ntxave
      • ntxdaveN Offline
        ntxdave
        Chris, our responses overlapped. If you look at mine, you will see that you can also do it the way Pilou was asking about as long as there is no overlay with other visibilities.
        BTW: You and Pilou have give me some feedback on another thread where I was trying to rotate and object (garage door) but I still cannot find a way in that situation that works correctly (where panels follow the "track" for the garage door). See this thread: How to rotate better
        Press F1...thank me later
          I have clicked this last icon first! 😳
            Cool to see measures change! 😎
            • chriC Offline
              chri
              hi
              Here are my tests about Dim Factor/Pursue/repeat which allows to precisely adjust/pursue/repeat a movement.
              Note that the Dim Factor value is a percentage of the movement.
              It can be positive or negative
              The first example is about Translation , the second one about Rotation.
              (0.16666 allows rotation of 1/6 turn)
              (0.5 allows rotation of 1/2 turn)
              Clic on the pictures to anim
              Bonjour
              Voici mes tests a propos de "Dim Factor/Pursue/repeat" qui permet d'ajuster / poursuivre / répéter un déplacement.
              Notez que la valeur de "Dim Factor" est un pourcentage du mouvement.
              Elle peut être positive ou négative
              Le premier exemple concerne la translation , le second , la rotation.
              ( 0.16666 permet la rotation de 1/6 de tour )
              ( 0.5 permet la rotation de 1/2 de tour )
              Cliquer sur les images pour les animer.
              Chri
              PERSONAL TEST DIM FACTOR1.skp
              PERSONAL TEST DIM FACTOR2.skp
              • chriC Offline
                chri
                a new test
                  There is a new function "Follow path" ? Or it's just several manual start-end ?
                  • chriC Offline
                    chri
                    Not a follow path fonction
                    Each color is a different movement .
                    Chri
                      So the hell! 😉
                      I believe that is the more important function to implement! 🤓
                      Surely not easy!
                      • F Offline
                        faust07
                        A nice example. It also shows, how complex simple animations can be. Sure you can apply the copy function for the individual sections well. Tricky it is when you have to animate the individual wheels of a 3D car properly for each curve.
                        A "Path Following" feature would be very helpful. Then would have to be determined an independent path move for the car and for each wheel...
                        • F Offline
                          faust07
                          Thanks! 👍
                          • emerald15E Offline
                            emerald15
                            which animation programme is this please?
                              Animator by Fredo 6! 😉
                                Must works also for components! 😉
                                • chriC Offline
                                  chri
                                  @fredo6 said:
                                  hi
                                  How will you manage to screw the two objects around the same axis?
                                  The trajectory of the 2 objects starts well, finished well, but has a weird trajectory!
                                  Chri
                                  In fact, I have to think about it. Screw mode does not allow you to choose the pivot point, which is the center of gravity of each selected group.
                                  So 2 problems:
                                  1. change the center of rotation, especially when the solid is not 'centered' naturally.
                                  2. Decide what one does for a set of objects. Either an individual screw or a screw grouped with respect to the center of gravity of all objects.
                                  --Comment t'y prendrai-tu pour visser les 2 objets autour d'un même axe ?
                                  La trajectoire des 2 objets débute bien , fini bien , mais a une trajectoire bizarre !
                                  Chri
                                  En fait, il faut que j'y réfléchisse. Le mode Screw ne permet pas de choisir le point pivot, qui est le centre de gravité de chaque groupe sélectionné.
                                  Donc 2 problèmes:
                                  1. changer le centre de rotation, en particulier quand les solide sont non 'centré' naturellement.
                                  2. Decider ce qu'on fait pour un ensemble d'objets. Soit un screw individuel, soit un screw groupé par rapport au centre de gravité de tous les objects.
                                  %(#0000FF)[For non symmetrical parts and meanwhile here is a manipulation to simulate the screwing.
                                  Create a symmetry on the blue piece and hide it.
                                  Pour les pièces non symétriques et en attendant voici une manip pour simuler le vissage .
                                  Créer une symétrie sur la pièce bleue et la masquer .]
                                  Chri
                                  TEST SCREW02.skp
                                  • chriC Offline
                                    chri
                                    • chriC Offline
                                      chri
                                      Here , step by step , how to do a combined movement.
                                      [highlight=#ffff40:11mopzv6]Click on the pictures to animate them[/highlight:11mopzv6]
                                      Picture 0: general presentation
                                      Picture 1: translation of the yellow cube
                                      Picture 2: rotation of the yellow cube
                                      Picture 3: rotation of the gray cube / yellow cube
                                      Picture 4: modification of the timeline (rotation of the gray cube during the whole movement of the yellow)
                                      Picture 5: rotation of the blue cube / gray cube and modification of the "timeline"
                                      Voici étape par étape la réalisation d'un mouvement combiné.
                                      [highlight=#ffff40:11mopzv6]Cliquer sur les images pour les animer[/highlight:11mopzv6]
                                      image 0 : présentation generale
                                      image 1 : translation du cube jaune
                                      image 2 : rotation du cube jaune
                                      image 3 : rotation du cube gris/cube jaune
                                      image 4 : modification de la "timeline" ( rotation du cube gris pendant tout le déplacement du jaune )
                                      image 5 : rotation du cube bleu/cube gris et modification de la "timeline"
                                      Chri
                                      MOUVEMENTS COMBINES2.skp
                                      • chriC Offline
                                        chri
                                        Hi Fredo
                                        There is something wrong in my workflow ... but what ?
                                        click on the following pictures to anim.
                                        Il y a quelque chose qui cloche dans ma manip, mais quoi ?
                                        Chri
                                        MOUVEMENTS COMBINES.skp
                                        MOUVEMENTS COMBINES.7z
                                        • chriC Offline
                                          chri
                                          Hi Fredo
                                          New problem with SCREW and group
                                          Autre probleme avec SCREW et groupe
                                          Chri
                                          TEST SCREW02.skp
                                          • chriC Offline
                                            chri
                                            Please find attached , a short tutorial to show how to do an assembly / disassembly animation with ANIMATOR.
                                            On the basis of a mounted assembly consisting of groups,
                                            1 - Moves the objects in the disassembly order
                                            2 - make à raz ( timeline to 0)
                                            3 - Save the ANIMATOR sequence
                                            4 - Choose "Play the clip From End to Start"
                                            5 - Start the animation and ... miracle, the job is done!
                                            [highlight=#ffff40:2g2lmq7k]Click on images to animate[/highlight:2g2lmq7k]
                                            Recall:
                                            A click suspends an animation - a double click restart.
                                            Thank you Fredo
                                            Bonjour
                                            Veuillez trouver ci-joint un petit tuto pour montrer comment réaliser une animation MONTAGE/DEMONTAGE avec ANIMATOR.
                                            Sur la base d'un ensemble monté constitué de groupes , on :
                                            1 - déplace les objets dans l'ordre du démontage
                                            2 - On met à 0.
                                            3 - on enregistre la séquence ANIMATOR
                                            4 - on choisi l'option "Play the clip From End to Start"
                                            ( jouer le clip depuis la fin jusqu’à son début )
                                            5 - On lance l'animation et ... miracle , le job est fait !
                                            [highlight=#ffff40:2g2lmq7k]Cliquer sur les images pour animer[/highlight:2g2lmq7k]
                                            Rappel:
                                            un clic suspend une animation - un double clic , la relance.
                                            Merci Fredo
                                            Chri
                                            MONTAGE KIOSQUE.skp
                                            MONTAGE KIOSQUE.rar
                                            • 2 / 2
