    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 586.6k Views 102 Watching
      In my scripts that use arrows keys I use this
      if RUBY_PLATFORM=~/mswin32/ ### PC
        KALXMINUS = 37          # Arrow Left Key
        KARXPLUS  = 39          # Arrow Right Key
        KAUYPLUS  = 38          # Arrow Up Key
        KADYMINUS = 40          # Arrow Down Key
        KSHIFT    = 16          # Shift Key
      else### MAC
        KALXMINUS = 63234       # Arrow Left Key
        KARXPLUS  = 63235       # Arrow Right Key
        KAUYPLUS  = 63232       # Arrow Up Key
        KADYMINUS = 63233       # Arrow Down Key
        KSHIFT    = 131072      # Shift Key
      end#if
      and then test key-down events etc against these 'constants'
        > else### MAC
        > end#if
        Why don't you use the built in constants? They should be reflecting the correct value based on the current OS. When you do it manually you have to keep updating it....
        • fredo6F Offline
          fredo6
          @Thomthom: I agree with you and my scripts do use the built-in constants for Arrow (and Shift, Ctrl). This is why I don't understand why it does not work. I was just wondering why the VK_constants for Oxer where in the range 123-126 whereas on the Mac I can have access to there are in the range of 63232... One possibility is that another script redefines the constants VK_.... because as far as I know, there is only a single Mac release of Sketchup, and therefore of the Ruby API (unless the Ruby API check itself the version of Mac OS).
          @TIG: the values you show are correct for the Mac, as far as I knew them.
          Fredo
            I assumed that SketchUp got the key code values from the system when it initialized the Ruby interpreter and abstracted them into these system-safe constants...
              redog
              for me u are a genius in sketchup you can now manage the textures in an intelligent way. thanks fridoooooo. grazie 😍 πŸ‘ πŸ‘ 😍
                moghamdi
                This is the result in the Ruby Console:
                I have Sketchup 8 Pro
                • fredo6F Offline
                  fredo6
                  NEW RELEASE: ThruPaint v1.2a - 08 May 12
                  This update fixes some bugs and introduces 2 functional evolutions
                  1) Painting of components / groups, text labels and dimensions
                  This is a new option in the palette, very similar to the native SU Paint tool. Originally, ThruPaint was painting faces within the boundaries of containers. There are however cases where you wish to assign a material to the component or group itself. This material becomes then the default material for the faces of the component
                  2) Modifier for Sampler
                  If you press Shift key, the cursor changes to sampling instead of painting. In the native SU Paint tool, this feature is covered by the Alt key (on Windows), but this is not possible in Ruby.
                  See main post of this thread for more information on ThruPaint.
                  See main post of FredoTools thread for download of FredoTools, which includes the ThruPaint script.
                  Fredo
                  • fredo6F Offline
                    fredo6
                    NEW RELEASE: ThruPaint v1.0n - 21 Apr 12
                    This update introduces 2 functional evolutions
                    1) Painting of a preselection of faces or edges
                    If you select faces or edges before launching ThruPaint, the painted faces or edges will be those of the preselection whenever you mouse over them (regardless of the face selection settings in the palette).
                    • When the material is a color or for edge painting, the painting applies to the whole pre-selection
                    • When the material is a texture, you have to paint by groups of faces in the preselection
                    2) Remembering of last scaling and rotation factors by material.
                    This is inspired from a request by Pherim
                    If you apply a textured material to a face and then scale it and/or rotate it, the scaling and rotation factors will be remembered the next time you apply this material.
                    Likewise, the sampling of material within the model also copy the scaling and rotation factors.
                    See main post of FredoTools thread for download of FredoTools, which includes the script.
                    Fredo
                      tomislavm
                      Thank You.
                      • N Offline
                        numerobis
                        Really a fantastic plugin! I have to say it again! Thanks a lot!
                        But i have noticed a problem with exporting textured object for rendering, maxwell in my case...
                        The problem is that the exporter writes a seperated material and texture for each face! So with a complex gepmetry this results in thousands of textures and materials.
                        My question is now, is it possible to avoid this behavior? I'm painting as QuadMesh.
                        Or is this problem maxwell related? I noticed the same thing when i use photomatch for texturing.
                        Can anyone say how this works with vray?
                        edit: ok, problem solved... disabling texture distortions in maxwell uv export options did it. I thought this would result in distorted mapping but for now it works.
                        Thanks again for this incredible tool, Fredo!!!
                        Trimble should buy this from you as standart mapping method! 😎
                          shri
                          many many thanks for your great tool.. πŸ‘
                          • majidM Offline
                            majid
                            unique genius Fredeo!!!!! many many thank you, this is greaaat
                            • pietervP Offline
                              pieterv
                              Hey Fredo,
                              Thanks a lot for the great plugin! You are a hero.
                              I have a slight problem tho. I used your plugin and in sketchup it looks like this
                              http://www.citypixels.be/wp-content/uploads/2012/10/sketchup-thrupaint-01.png
                              but when I render it in Maxwell Render it looks like this:
                              http://www.citypixels.be/wp-content/uploads/2012/10/simpel-huis-render-017.jpg
                              The yellow stones in the little wall have become much smaller and the middle part of the street has become darker. Do you have an idea what the problem could be?
                              Thanks!
                              Pieter
                              This is my website:
                              Citypixels - 3d Visualisatie Architectuur
                                Check if the two surfaces have the material applied in a different way.
                                I suspect that one has the material applied to the face itself while the other has the material applied to the 'container' [group/component-instance] - check this by using 'Entity Info' and selecting the actual faces in each case - the 'mapping' cannot persist into exported formats when applied to a container rather than the face itself... Of course it might be a Maxwell issue with it mis-handing the UVmapping ?
                                  Contact Maxwell support - as this is their render engine that doesn't properly process the UV mapping.
                                  • pietervP Offline
                                    pieterv
                                    I have checked, and the two materials are axactly the same. I have the free version of Maxwell Render, so I'll repost this under "extensions & applications". Thanks for answering!
                                    This is my website:
                                      I'd still recommend you contact Maxwell - as this would then be something that presumably affects all users. Reporting issues to the developers is important - otherwise it'll never get fixed.
                                        cadmunkey
                                        Is this plugin for premium members only? If I click the download icon I get a banner.png.
                                        • massimoM Offline
                                          massimo Moderator
                                          ThruPaint is installed as part of FredoTools.. It requires LibFredo6 4.4 or above.
                                          See the main post for this plugin for Installation of FredoTools
                                          So you have to go to Fredo tools thread to download the plugin. Scroll down the page and you'll find it below the "download" icon.
                                            cadmunkey
                                            Cheers!
                                            • 6
                                            • 7
                                            • 16
                                            • 17
                                            • 5 / 17
