    [Plugin] SketchUV - now free
    176 Posts 62 Posters 150.2k Views 62 Watching
      That look about right to me.
      Tri's and poles are hard for any mapping method.
      • ToboboT Offline
        Tobobo
        I'm not so fussed about Antarctica but Greenland isn't quite all there.
        Toby
        Philippians 4:13
          this might be better....
          ....but it'll pinch at poles...
          • ToboboT Offline
            Tobobo
            That does look better Rich, as always with this sort of thing the client wants it to be triangular faces. πŸ˜’
            Toby
            Philippians 4:13
              You can have tris but that shape is hard to resolve
              • ToboboT Offline
                Tobobo
                Ok thanks Rich πŸ˜„ , I will try and sort it
                Toby
                Philippians 4:13
                • FrederikF Offline
                  Frederik
                  Not sure if you can use this, but that paper globe model is available for free at model+model... πŸ˜‰
                  I downloaded the OBJ and imported it to SketchUp and got this result...
                  Cheers
                  Kim Frederik
                    A hipoly lo poly version.
                    • FrederikF Offline
                      Frederik
                      It even looks great when rendered... πŸ˜„
                      Cheers
                      Kim Frederik
                      • FrederikF Offline
                        Frederik
                        My pleasure... πŸ˜„
                        Cheers
                        Kim Frederik
                          jamenloh
                          Hey man, thanks for the plugin ! It solves so many problems we are facing ! I just downloaded it to try , am facing an issue with your plug in.
                          I've followed the tutorial by clicking the surface , the iconbar , align the angles and select the context menu planar surface - but it doesn't apply the UV map ... it just applis my last texture.
                          Have tried it many times to no avail.
                          Any idea what happened ?
                          • ToboboT Offline
                            Tobobo
                            That's great πŸ˜„
                            Thanks mate!
                            Toby
                            Philippians 4:13
                            • Z Offline
                              Zacchia
                              Many thanks for this nice plugin!!
                              • romboutR Offline
                                rombout
                                I got a question. Ive read somewhere when import a obj mesh which gets triangulated at normal size (for me metric) better use a smaller import size. Im using meter in blender and than import it as inch into SU, cm still gives triangles and mm cuts holes.
                                what scale do i need to use to set it back to meter. Im searching google but im not sure what keywords i need to use. Im non english person so bit harder for correct translation.
                                Doing my own tests i came around 39.35% when i use the scale tool in SU, im still a bit off. Anyone here who knows the exact scale method
                                • romboutR Offline
                                  rombout
                                  After checking again and using a simple cube i found that 39.37% scale is exact. I could also use the tape measure ofcourse, i totally forgot about that function. Measuring the down scaled part and than simply typing the exact number.
                                  Now i wonder why the scale is such awkward number, any know familiar with this πŸ˜„
                                  • Z Offline
                                    Zacchia
                                    This is because 1 m is about 39.37 inches I think...
                                      AcesHigh
                                      I suppose this is not the place... or maybe it is... but I followed the Roadkill SketchUV road mapping tutorial and it didnΒ΄t work at all.
                                      The problem was that my road had a more complex triangulation and when I started pulling the border vertexes arond at RoadKill, Roadkill did not know how to deal with the vertexes in the middle of the road... it resulted in a bad mess, specially when I would pull the right vertexes to the right side of the map... there were triangles jumping all over the place inside Roadkill πŸ˜•
                                        dacastror
                                        mistakes like this are appearing on the console
                                        Error: #<NameError: uninitialized constant DM_SketchUV::DM_UVTool::Set>
                                        I'm using Sketchup 2015. When you use version 1.0 works fine, but there are flaws in version 1.0.1
                                        • W Offline
                                          Whaat
                                          Thanks for the report - I'll look into it. Are you sure you have the latest version installed?
                                          • BSquared18B Offline
                                            BSquared18
                                            **Hello Dale,
                                            I started a thread titled "Need Help Using SketchUV for UV mapping" at:
                                            http://sketchucation.com/forums/viewtopic.php?f=80%26amp;t=63227%26amp;p=578909#p578909
                                            In short, I am trying to UV-map the texture from a .png file to a SketchUp 3D model of an aircraft instrument panel. The details are in the above-mentioned thread.
                                            I've gone through the steps listed in your tutorials, except that instead of applying a texture from SU's Paint Bucket palette, I have tried to import it using SU's Import Texture feature.
                                            But after applying it and trying to export it using Marginal's SU2XP plugin, I do not get the desired effect.
                                            Do you have any suggestions?
                                            Thank you,
                                            Bill**
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 8 / 9
