    [Plugin] SketchUV - now free
    176 Posts 62 Posters 161.8k Views 62 Watching
    • FrederikF Offline
      Frederik
      It even looks great when rendered... 😄
      Cheers
      Kim Frederik
      • FrederikF Offline
        Frederik
        My pleasure... 😄
        Cheers
        Kim Frederik
          jamenloh
          Hey man, thanks for the plugin ! It solves so many problems we are facing ! I just downloaded it to try , am facing an issue with your plug in.
          I've followed the tutorial by clicking the surface , the iconbar , align the angles and select the context menu planar surface - but it doesn't apply the UV map ... it just applis my last texture.
          Have tried it many times to no avail.
          Any idea what happened ?
          • ToboboT Offline
            Tobobo
            That's great 😄
            Thanks mate!
            Toby
            Philippians 4:13
            • Z Offline
              Zacchia
              Many thanks for this nice plugin!!
              • romboutR Offline
                rombout
                I got a question. Ive read somewhere when import a obj mesh which gets triangulated at normal size (for me metric) better use a smaller import size. Im using meter in blender and than import it as inch into SU, cm still gives triangles and mm cuts holes.
                what scale do i need to use to set it back to meter. Im searching google but im not sure what keywords i need to use. Im non english person so bit harder for correct translation.
                Doing my own tests i came around 39.35% when i use the scale tool in SU, im still a bit off. Anyone here who knows the exact scale method
                • romboutR Offline
                  rombout
                  After checking again and using a simple cube i found that 39.37% scale is exact. I could also use the tape measure ofcourse, i totally forgot about that function. Measuring the down scaled part and than simply typing the exact number.
                  Now i wonder why the scale is such awkward number, any know familiar with this 😄
                  • Z Offline
                    Zacchia
                    This is because 1 m is about 39.37 inches I think...
                      AcesHigh
                      I suppose this is not the place... or maybe it is... but I followed the Roadkill SketchUV road mapping tutorial and it didn´t work at all.
                      The problem was that my road had a more complex triangulation and when I started pulling the border vertexes arond at RoadKill, Roadkill did not know how to deal with the vertexes in the middle of the road... it resulted in a bad mess, specially when I would pull the right vertexes to the right side of the map... there were triangles jumping all over the place inside Roadkill 😕
                        dacastror
                        mistakes like this are appearing on the console
                        Error: #<NameError: uninitialized constant DM_SketchUV::DM_UVTool::Set>
                        I'm using Sketchup 2015. When you use version 1.0 works fine, but there are flaws in version 1.0.1
                        • W Offline
                          Whaat
                          Thanks for the report - I'll look into it. Are you sure you have the latest version installed?
                          • BSquared18B Offline
                            BSquared18
                            **Hello Dale,
                            I started a thread titled "Need Help Using SketchUV for UV mapping" at:
                            http://sketchucation.com/forums/viewtopic.php?f=80%26amp;t=63227%26amp;p=578909#p578909
                            In short, I am trying to UV-map the texture from a .png file to a SketchUp 3D model of an aircraft instrument panel. The details are in the above-mentioned thread.
                            I've gone through the steps listed in your tutorials, except that instead of applying a texture from SU's Paint Bucket palette, I have tried to import it using SU's Import Texture feature.
                            But after applying it and trying to export it using Marginal's SU2XP plugin, I do not get the desired effect.
                            Do you have any suggestions?
                            Thank you,
                            Bill**
                            • H Offline
                              hsrhdrehre5654654
                              Great tool. Just one question.. im trying to export the uvs. Here is the problem, i set the extraction path in, for example d:/ , then i go to options - export uvs, and a msg appear saying that the uvs have been exported. Well, i cant find the obj file anywhere. And since in the msg box there is not info about the path itself, im totally lost. My guess is it is exporting the uvs to the default folder instead. So, what is the default folder where the uvs are exported?
                              • H Offline
                                hsrhdrehre5654654
                                Oh well. NVM. It turns out i was "saving" the uvs, not exporting rofl!!! sorry my bad.
                                • dereiD Offline
                                  derei
                                  Can't export UVs. The error is "Unable to export UVs" and after a quick inspection in the console, it seems the default export path doesn't exist anymore (indeed, the folder was renamed). The problem is that I have no idea how I can convince the plugin to export somewhere else...
                                  Please help!
                                  • dereiD Offline
                                    derei
                                    Please help!
                                    Solved - I deleted the REG entry. Nonetheless, should address the issue in a better manner (if path not found, to prompt for a new path).
                                    Cheers!
                                    • sicksickisckS Offline
                                      sicksickisck
                                      • W Offline
                                        Whaat
                                        @sicksickisck said:
                                        [attachment=1:2ohepcgx]<!-- ia1 -->EXPORT UV.JPG<!-- ia1 -->[/attachment:2ohepcgx]
                                        EXPORT UV, BUG SKP 2016[attachment=0:2ohepcgx]<!-- ia0 -->VER.JPG<!-- ia0 -->[/attachment:2ohepcgx]
                                        Do you have the entire ruby output available?
                                        I'm guessing you might have a conflicting plugin.
                                          kubap
                                          Hi, sketchup says that this plugin is unidentified (doesn't have digital signature) and therefore may be risky to use. I don't have this issue with other plugins.
                                          • W Offline
                                            Whaat
                                            Thanks for the note - the current version on the EW might not have a signature. I'll have to fix that.
                                            • 8 / 9
