    ⚠️ Important | Libfredo 15.6a introduces important bugfixes for Fredo's Extensions Update
    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.3m Views 342 Watching
    • N Offline
      NetJaro @fredo6
      [@fredo6 thanks for your answer and thank you for what you do for Sketchup 🙂
      I include my model.
      One object (on the left) is original, second object (on the right) is after rotate by Sketchup official rotate function.
      The bug doesn't show always in first time - try rotate left object, when its good (without bug) - use "undo" and try again.
      bug.skp
      Thanks for you help!
      Regards,
      Marcin
      • fredo6F Offline
        fredo6
        What is the relation with FredoScale then?
        Note that I tried to rotate both objects, with Undo and try again. I did not find any issue
        N 1 Reply Last reply Reply Quote 0
        • N Offline
          NetJaro @fredo6
          @fredo6 Hi!
          The problem with area of the object is only when I use a FredoScale.
          Below I include a longer video with problem.
          Image 002.mp4
          Thanks!
          E 1 Reply Last reply Reply Quote 0
          • fredo6F Offline
            fredo6
            I cannot reproduce the issue with the Stretch tool followed by a SU Rotate.
            Do you have it on any object or just this one ?
            By the way, it looks like you component is a Dynamic component, or at least was a dynamic component.
            • N Offline
              noseno002
              Bundle of 8 plugins are compatible with SketchUp 2025?
              I'm interested in the Fredo scale, RoundCorner, and others.
                Dave R @noseno002
                @noseno002 yes. They all work with SketchUp 2025.
                • E Offline
                  elfis @NetJaro
                  I'm using this plugin for ears, but this has always been the case. It's not a big problem—when the cursor highlights the edge like in your video, just press it, and the bounding box will align.
                  @NetJaro said in [Plugin][$] FredoScale - v3.6a - 01 Apr 24:
                  @fredo6 Hi!
                  Image 002.mp4
                  Thanks!
                  • E Offline
                    elfis
                    I have problem, divide do not work on sketchup 2025 I'm alone with this ?
                    Are you planning to make any changes, upgrades, or new features?
                    • A new UI, like the Flip tool
                    • Displaying the size of the selected object when the tool is active
                    • Upgrading the stretch target
                    • Holding proportions when scaling
                      Dave R @elfis
                      @elfis said in [Plugin][$] FredoScale - v3.6a - 01 Apr 24:
                      Well, it works for me in SketchUp 2025.
                      • K Offline
                        kaas
                        Question;
                        I use a custom quick menu and I would like to launch FredoScale-boxstretch. On this webpage (documentation section) the suggestion is to use this ruby command. See https://sketchucation.com/plugin/1169-fredoscale
                        F6_FredoScale.launch_action(action_code)
                        my action would be :StretchB
                        so the command is
                        F6_FredoScale.launch_action(:StretchB)
                        I'm getting an error though
                        #<NameError: uninitialized constant F6_FredoScale::StretchBTool>
                        (eval):1:in `launch'
                        etc etc.
                        Any thing I'm missing? Code has changed?
                        I'm using
                        Platform: x64-mswin64_140 - Ruby: 3.2.2, Sketchup: 25.0.634, LibFredo6: v15.1a, LibFredo6 Binary loaded, SCFLicense: v6.4a - 74, FredoScale v3.6a - licensed FULL
                        • fredo6F Offline
                          fredo6
                          Use :Stretch_B
                          EXTERNAL API to launch FredoScale menus
                          Action code must be passed as a symbol
                          - :Scale_B --> Scale - Box mode
                          - :Scale_T --> Scale - Target mode
                          - :Taper_B --> Taper - Box mode
                          - :Taper_T --> Scale - Target mode
                          - :PlanarShear_B --> Planar Shear - Box mode
                          - :PlanarShear_T --> Planar Shear - Target mode
                          - :PlanarShear_A --> Planar Shear - Free mode
                          - :Stretch_B --> Stretch - Box mode
                          - :Stretch_T --> Stretch - Target mode
                          - :Twist_B --> Twist - Box mode
                          - :Rotate_B --> Rotate - Box mode
                          - :Rotate_A --> Rotate - Free mode
                          - :RadialBend_A --> Radial Bending - Free mode
                          - :MakeUnique_U --> Make Unique - Utility
                          K 1 Reply Last reply Reply Quote 1
                          • K Offline
                            kaas @fredo6
                            @fredo6 thanks Fredo, that works nicely
                              bedavisdesign
                              Hi Fredo. I've used so many of your creations over the years. I want to say I've used SU on and off since at least 2006. I just purchased SU2025 Pro and I'm also a member here on Sketchucation, though my membership here is of the free variety. I'm getting ready to purchase the Fredo6Bundle2022 through Sketchucation, but I want to make sure I'm good to go ahead and purchase. Under the "Requirements" you mention "Usage: Paid, Licensed under Sketchucation SCFLicense". I want to understand if this means I need to be a "Paid" member here on Sketchucation, or am I reading too much into that? I hope my inquiries are clear enough and thanks in advance for any clarifications you can provide. EDIT*: Or if anyone else can answer this question if Fredo isn't available, that we be great. THX!
                              • Rich O BrienR Online
                                Rich O Brien Moderator @bedavisdesign
                                @bedavisdesign
                                You can purchase using your free account. SCFLicense is packed into Sketchucation Tools which is also free.
                                  bedavisdesign
                                  @Rich-O-Brien Thank you so much for your reply and info.
                                    Mattshiggins
                                    Hi in SketchUp 2026 you need to tap tab multiple times to bring up the dimensions box. This appears to only happen on Windows, Mac is working as it should. Is there a workaround or fix?
                                    Thanks.
                                      @Mattshiggins
                                      You can right click and choose Enter Dimensions
                                      But the TAB not firing on first click suggests something else is grabbing focus. That could be from a myriad of reasons like a dialog open or you clicked something in the tray.
                                      I've not experienced myself on Windows but have seen a few mention it.
                                      pilgerP 1 Reply Last reply Reply Quote 0
                                      • pilgerP Offline
                                        pilger @Rich O Brien
                                        @Rich-O-Brien @Mattshiggins
                                        I'm having the same issue here. I've tried uninstalling all other extensions and plugins and running Sketchup without any other apps in the background and I still get the same thing.
                                        Is there a way to check what is getting focused when I press tab, maybe? To try and find what's stealing the focus?
                                        EDIT: or maybe change that tab key to something else that doesn't cause the issue?
                                        EDIT 2: updates here: https://community.sketchucation.com/post/1617927
                                        • 53
                                        • 54
                                        • 55
                                        • 56
                                        • 57
                                        • 57 / 57
