    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
      Mae50 Newcomers
      @Rich-O-Brien
      I just try the second option
      Or go to C:/Users/julie/AppData/Local/LIBFREDO6_DATA_Dir and delete the LibFredo6_all_defaults.dat file and start SketchUp
      and it's ok.
      Thank you very very much for your support
      • N
        NetJaro
        Hi!
        I think I found bug.
        Sometimes, when I rotate my element i change dimensons there is a error with area of my component.
        Look at this video: 2025-03-11 16 06 21.mp4
        Someone can help me?
        Marcin.
        • fredo6F
          I would need to have the model to understand, especially because the video is unclear about what exactly you do to the cube with the rotation.
          Also, can you turn on 'Show Hidden geometry', just in case there are hidden elements in the group.
          N 1 Reply Last reply
          • F
            FlorinAp
            Box Stretching options has a bug - it does correctly only the first level of components nesting, starting with the second level, it doesn't make unique on the first run (it messes up all your components in the model.!), and if you hit Ctrl+Z (only ONCE.!) it reverses the modification, and after that they remain unique and you can modify...
            Very disturbing.!
            Curic Stretch works flawlessly, but it is not so handy and fast to use, so is the last option. I use it only when what I want to modify is much too heavy (loaded with many faces and edges... usually organic shapes, but also cabinets with more then 3 drawers because it freezes calculating) because it can handle much more amount of geometry, in these situations, Fredo Scale does only half the job and you end up seeing that only a few pieces have been modified.
            • N
              NetJaro @fredo6
              [@fredo6 thanks for your answer and thank you for what you do for Sketchup 🙂
              I include my model.
              One object (on the left) is original, second object (on the right) is after rotate by Sketchup official rotate function.
              The bug doesn't show always in first time - try rotate left object, when its good (without bug) - use "undo" and try again.
              bug.skp
              Thanks for you help!
              Regards,
              Marcin
              • fredo6F
                What is the relation with FredoScale then?
                Note that I tried to rotate both objects, with Undo and try again. I did not find any issue
                • N
                  NetJaro @fredo6
                  @fredo6 Hi!
                  The problem with area of the object is only when I use a FredoScale.
                  Below I include a longer video with problem.
                  Image 002.mp4
                  E 1 Reply Last reply
                  • fredo6F
                    I cannot reproduce the issue with the Stretch tool followed by a SU Rotate.
                    Do you have it on any object or just this one ?
                    By the way, it looks like you component is a Dynamic component, or at least was a dynamic component.
                    • N
                      noseno002
                      Bundle of 8 plugins are compatible with SketchUp 2025?
                      I'm interested in the Fredo scale, RoundCorner, and others.
                      Dave RD 1 Reply Last reply
                        Dave R @noseno002
                        @noseno002 yes. They all work with SketchUp 2025.
                        • E
                          elfis @NetJaro
                          I'm using this plugin for ears, but this has always been the case. It's not a big problem—when the cursor highlights the edge like in your video, just press it, and the bounding box will align.
                          @NetJaro said in [Plugin][$] FredoScale - v3.6a - 01 Apr 24:
                          @fredo6 Hi!
                          Image 002.mp4
                          • E
                            elfis
                            I have problem, divide do not work on sketchup 2025 I'm alone with this ?
                            Are you planning to make any changes, upgrades, or new features?
                            • A new UI, like the Flip tool
                            • Displaying the size of the selected object when the tool is active
                            • Upgrading the stretch target
                            • Holding proportions when scaling
                              Dave R @elfis
                              @elfis said in [Plugin][$] FredoScale - v3.6a - 01 Apr 24:
                              Well, it works for me in SketchUp 2025.
                              Reply Quote 2
                              • K
                                kaas
                                Question;
                                I use a custom quick menu and I would like to launch FredoScale-boxstretch. On this webpage (documentation section) the suggestion is to use this ruby command. See https://sketchucation.com/plugin/1169-fredoscale
                                F6_FredoScale.launch_action(action_code)
                                my action would be :StretchB
                                so the command is
                                F6_FredoScale.launch_action(:StretchB)
                                I'm getting an error though
                                #<NameError: uninitialized constant F6_FredoScale::StretchBTool>
                                (eval):1:in `launch'
                                etc etc.
                                Any thing I'm missing? Code has changed?
                                I'm using
                                Platform: x64-mswin64_140 - Ruby: 3.2.2, Sketchup: 25.0.634, LibFredo6: v15.1a, LibFredo6 Binary loaded, SCFLicense: v6.4a - 74, FredoScale v3.6a - licensed FULL
                                • fredo6F
                                  Use :Stretch_B
                                  EXTERNAL API to launch FredoScale menus
                                  Action code must be passed as a symbol
                                  - :Scale_B --> Scale - Box mode
                                  - :Scale_T --> Scale - Target mode
                                  - :Taper_B --> Taper - Box mode
                                  - :Taper_T --> Scale - Target mode
                                  - :PlanarShear_B --> Planar Shear - Box mode
                                  - :PlanarShear_T --> Planar Shear - Target mode
                                  - :PlanarShear_A --> Planar Shear - Free mode
                                  - :Stretch_B --> Stretch - Box mode
                                  - :Stretch_T --> Stretch - Target mode
                                  - :Twist_B --> Twist - Box mode
                                  - :Rotate_B --> Rotate - Box mode
                                  - :Rotate_A --> Rotate - Free mode
                                  - :RadialBend_A --> Radial Bending - Free mode
                                  - :MakeUnique_U --> Make Unique - Utility
                                  K 1 Reply Last reply
                                  • K
                                    kaas @fredo6
                                    @fredo6 thanks Fredo, that works nicely
                                    • B
                                      bedavisdesign
                                      Hi Fredo. I've used so many of your creations over the years. I want to say I've used SU on and off since at least 2006. I just purchased SU2025 Pro and I'm also a member here on Sketchucation, though my membership here is of the free variety. I'm getting ready to purchase the Fredo6Bundle2022 through Sketchucation, but I want to make sure I'm good to go ahead and purchase. Under the "Requirements" you mention "Usage: Paid, Licensed under Sketchucation SCFLicense". I want to understand if this means I need to be a "Paid" member here on Sketchucation, or am I reading too much into that? I hope my inquiries are clear enough and thanks in advance for any clarifications you can provide. EDIT*: Or if anyone else can answer this question if Fredo isn't available, that we be great. THX!
                                        Rich O Brien Moderator @bedavisdesign
                                        @bedavisdesign
                                        You can purchase using your free account. SCFLicense is packed into Sketchucation Tools which is also free.
                                        • B
                                          bedavisdesign
                                          @Rich-O-Brien Thank you so much for your reply and info.
                                            Mattshiggins
                                            Hi in SketchUp 2026 you need to tap tab multiple times to bring up the dimensions box. This appears to only happen on Windows, Mac is working as it should. Is there a workaround or fix?
                                            Thanks.
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 59
                                            • 57 / 59
