    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.0m Views 345 Watching
      Dave R @elfis
      @elfis said in [Plugin][$] FredoScale - v3.6a - 01 Apr 24:
      divide do not work on sketchup 2025 I'm alone with this ?
      Well, it works for me in SketchUp 2025.
        kaas
        Question;
        I use a custom quick menu and I would like to launch FredoScale-boxstretch. On this webpage (documentation section) the suggestion is to use this ruby command. See https://sketchucation.com/plugin/1169-fredoscale
        F6_FredoScale.launch_action(action_code)
        my action would be :StretchB
        so the command is
        F6_FredoScale.launch_action(:StretchB)
        I'm getting an error though
        #<NameError: uninitialized constant F6_FredoScale::StretchBTool>
        (eval):1:in `launch'
        etc etc.
        Any thing I'm missing? Code has changed?
        I'm using
        Platform: x64-mswin64_140 - Ruby: 3.2.2, Sketchup: 25.0.634, LibFredo6: v15.1a, LibFredo6 Binary loaded, SCFLicense: v6.4a - 74, FredoScale v3.6a - licensed FULL
        • fredo6F Offline
          Use :Stretch_B
          EXTERNAL API to launch FredoScale menus
          Action code must be passed as a symbol
          - :Scale_B --> Scale - Box mode
          - :Scale_T --> Scale - Target mode
          - :Taper_B --> Taper - Box mode
          - :Taper_T --> Scale - Target mode
          - :PlanarShear_B --> Planar Shear - Box mode
          - :PlanarShear_T --> Planar Shear - Target mode
          - :PlanarShear_A --> Planar Shear - Free mode
          - :Stretch_B --> Stretch - Box mode
          - :Stretch_T --> Stretch - Target mode
          - :Twist_B --> Twist - Box mode
          - :Rotate_B --> Rotate - Box mode
          - :Rotate_A --> Rotate - Free mode
          - :RadialBend_A --> Radial Bending - Free mode
          - :MakeUnique_U --> Make Unique - Utility
          K 1 Reply Last reply Reply Quote 1
            kaas @fredo6
            @fredo6 thanks Fredo, that works nicely
              bedavisdesign
              Hi Fredo. I've used so many of your creations over the years. I want to say I've used SU on and off since at least 2006. I just purchased SU2025 Pro and I'm also a member here on Sketchucation, though my membership here is of the free variety. I'm getting ready to purchase the Fredo6Bundle2022 through Sketchucation, but I want to make sure I'm good to go ahead and purchase. Under the "Requirements" you mention "Usage: Paid, Licensed under Sketchucation SCFLicense". I want to understand if this means I need to be a "Paid" member here on Sketchucation, or am I reading too much into that? I hope my inquiries are clear enough and thanks in advance for any clarifications you can provide. EDIT*: Or if anyone else can answer this question if Fredo isn't available, that we be great. THX!
                Rich O Brien Moderator @bedavisdesign
                @bedavisdesign
                You can purchase using your free account. SCFLicense is packed into Sketchucation Tools which is also free.
                  bedavisdesign
                  @Rich-O-Brien Thank you so much for your reply and info.
                    Mattshiggins
                    Hi in SketchUp 2026 you need to tap tab multiple times to bring up the dimensions box. This appears to only happen on Windows, Mac is working as it should. Is there a workaround or fix?
                    Thanks.
                      @Mattshiggins
                      You can right click and choose Enter Dimensions
                      But the TAB not firing on first click suggests something else is grabbing focus. That could be from a myriad of reasons like a dialog open or you clicked something in the tray.
                      I've not experienced myself on Windows but have seen a few mention it.
                      pilgerP 1 Reply Last reply Reply Quote 0
                      • pilgerP Offline
                        pilger @Rich O Brien
                        @Rich-O-Brien @Mattshiggins
                        I'm having the same issue here. I've tried uninstalling all other extensions and plugins and running Sketchup without any other apps in the background and I still get the same thing.
                        Is there a way to check what is getting focused when I press tab, maybe? To try and find what's stealing the focus?
                        EDIT: or maybe change that tab key to something else that doesn't cause the issue?
                        EDIT 2: updates here: https://community.sketchucation.com/post/1617927
                        • F Offline
                          fimo
                          Hello to all, after reading all 57 pages of this topic I have yet to find a solution to my issue with the box stretching function.
                          I have attached 3 images showing a simple paneled door that stretches all groups in the horizontal direction but only the frame in the vertical direction.
                          The door component consists of 11 different groups, What am I missing here ?
                            Rich O Brien Moderator @fimo
                            @fimo said in [Plugin][$] FredoScale - v3.6a - 01 Apr 24:
                            Upload the file please so we can test
                            • F Offline
                              fimo
                              Sorry posted wrong door, try this one.
                              Door glass panelled.skp
                                Explode the 'glass' groups and group them into a single group then stretch
                                • F Offline
                                  fimo
                                  Many thanks Rich, that certainly works, my lack of lateral thinking on show right there.
                                  But is this a workaround for a non functionality in the extension or is it by design ? Just seems odd that it works in one plane and not the other.
                                    @fimo
                                    Dunno... it does behave correctly Left/Right. Just not Up/Down.
                                    In this video you can see it working as expected. Maybe @fredo6 knows more?
                                    • fredo6F Offline
                                      NEW RELEASE: FredoScale v3.7a - 09 Jul 26
                                      Requirements:
                                      • LibFredo6 v15.9d.
                                      • Sketchucation PluginStore v5.0.7.
                                      FredoScale 3.7a includes changes for:
                                      • Bug fixing and adjustment for Dimension dialog box
                                      Home Page of FredoScale for information and Download.
                                      Main post of this FredoScale thread.
                                      • pep75P Offline
                                        pep75
                                        I've installed the latest version of FredoScale, and I'm not sure it's really an improvement, at least not for me. Also, the fact that I have to manually turn off "Uniform" every single time is very irritating. Is there a way to change this so that Uniform is disabled by default?
                                        fredo6F 1 Reply Last reply Reply Quote 0
                                        • fredo6F Offline
                                          fredo6 @pep75
                                          Improvement on what? There was a bug which was fixed so that it works as designed.
                                          • pep75P Offline
                                            pep75
                                            Well, it seems to me that the user interface has changed, or am I completely mistaken?
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 59
                                            • 57 / 59
