    Rayscaper New Releases
    rayscaperrender
    743 Posts 14 Posters 312.7k Views 15 Watching
    • KrassK
      Krass
      And I feel compelled to emphasize—for users of true path-tracing renderers—that the denoiser really compromises image quality. You only have to test it yourself: even though Rayscaper’s denoiser is excellent, a 1080p render won't be particularly sharp or detailed. Paradoxically, simply increasing the render resolution actually saves time in the end; once displayed at a smaller size or downsampled, the result is far superior to simply increasing the samples per pixel (spp) at a lower resolution.
      Krass
      • KrassK
        Krass
        hello Pixelcruncher,
        I tryied to edit a sketchup material of a shrub in photoshop and saved it, save the model and rayscaper did this. Any idea or solution? Thanjs
        Krass
        • pixelcruncherP
          @krass - That means Rayscaper can't find the image after you edited it in Photoshop. Did you happen to save it under a different filename?
          As a workaround, try reloading this material to see if it works.
          I will have a fix in the next release, which will land shortly.
          Regards,
          Thomas
          • KrassK
            Krass
            yes thanks Thomas, I made a copy ok the texture file in a other folder, and it works. It Keeps UV's
            Krass
            • KrassK
              Krass
              One of the options I’d like to have in Rayscaper is the ability to adjust the colors and values ​​of a photo texture for a PBR material.
              Krass
              • KrassK
                Krass
                the Hide assets function is great !
                Krass
                • KrassK
                  Krass
                  I set the HDRI map resolution to the maximum, but it's quite blurry.
                  Krass
                  • KrassK
                    Krass
                    I reloaded the HDRI from Polyhaven. Here are some views with the latest version of Rayscaper. For a bird's eye view chat GPT only produced the context, the background.
                    Krass
                    • pixelcruncherP
                      Hey, Rayscaper users!
                      Rayscaper 0.9.96 Beta is available. You can get it via:
                      • The SketchUcation store.
                      • Direct download: Rayscaper_Win_0.9.96_Beta.rbz.
                      I recommend upgrading to the latest version. This release is all about water and light 🌊💡
                      New: Water Material
                      Rayscaper now has a dedicated Water material for pools, ponds, lakes and spas. Assign it to a single face or a closed box, pick a preset, and you're done.
                      • Realistic waves: layered swell and fine ripples, with direction, size and strength controls.
                      • Depth you can see: water gets darker and more tinted as it gets deeper, so a pool's deep end actually looks deep.
                      • Controllable reflections: from crisp mirror-like water at sunset to soft, choppy reflections.
                      Clarity controls how far you can see into the water:
                      It ships with presets to get you started, including the new Tropical, Reflecting Pool and Spa.
                      New: IES Light Profiles for Spotlights
                      Spotlights can now use IES profiles for realistic, architectural light patterns: batwing, wall wash, narrow and medium spot, wide flood and elliptical beam. The light editor shows a preview of each distribution so you can see what you're picking.
                      Other Improvements
                      • Add procedural material previews, so material thumbnails render faster and no longer hang.
                      • Select newly placed lights automatically and show the active light tool in the toolbar.
                      • Refresh the user interface with a consistent set of toolbar icons, sharper icon scaling, clearer list selection, and a tidier settings layout.
                      Fixes
                      • Fix textures rendering cyan after editing a texture image in an external editor, saving, and reopening the model.
                      • Fix vignette falloff at high strength.
                      Full release notes: rayscaper.com/manual/release-notes
                      Help Me Build the Community 👍
                      If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating
                      and helps me showcase its capabilities to new users.
                      Follow me on X.
                      Happy Rendering!
                      Thomas
                      • KrassK
                        Krass
                        Great, thanks Thomas. I needed water materials this morning and you granted my wish tonight...!
                        Krass
                        • pixelcruncherP
                          @Krass I will be waiting for those awesome renders!
                          • KrassK
                            Krass
                            rayscayper pool with water material
                            Krass
                            • pixelcruncherP
                              @Krass Nice!
                              • KrassK
                                Krass
                                I really like the two buttons for hiding the settings and assets—you can quickly switch to a large-scale view of the render—and the minimalist icon design.
                                And this time, it successfully loaded the HDRI map at full resolution
                                for this render, which features actual waves in the geometry.
                                Krass
                                  Sharp, I am missing the splash where my ex jumped in to create the waves though.......
                                  • KrassK
                                    Krass
                                    yes, but 3D splash is very hy skill !
                                    The pool on the screen is an "infinity pool"; I wouldn't have the patience right now to model that in SketchUp... then again, maybe I would? But AI does it in a couple of quick moves.
                                    And if you send me a photo of your ex, she (he) will be in the image!
                                    Krass
                                      I tried but the camera broke, or I had a tree in the way. Not sure which.
                                      Either way fangs for the memories is about as far as I go these days. It is a fine Mr Kipling image tho'.
                                      • pixelcruncherP
                                        pixelcruncher Extension Creator @Mike Amos
                                        @Mike-Amos, I'm working on that feature. Exes are tricky, though...
                                          Thankfully, exes are his tory. I know, a laboured joke.
                                          • KrassK
                                            Krass
                                            here same rayscaper render and Qwen image AI model to generate vegetation outside the property. I used ZPIX, a free and simple AI image tool for computer desktop (no need to be connected after downloading the models) Link to zpix https://github.com/SamuelTallet/ZPix
                                            before:
                                            after:
                                            Krass
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 37
                                            • 38
                                            • 24 / 38
