    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.2k Posts 583 Posters 9.0m Views 585 Watching
    • ntxdaveN
      ntxdave
      I did a quick test on an old Animator file and it looks like we now can use perspective and generate a video.
      Press F1...thank me later
      ntxdaveN 1 Reply Last reply
      • G
        GavinG @fredo6
        @fredo6 - I have tried to uninstall and reinstall, no luck, I have just installed the plugin as indicated below in the next reply, still nothing working. I still get the TRIAL PRERIOD EXPIRED window
        fredo6F 1 Reply Last reply
        • fredo6F
          fredo6 @GavinG
          @GavinG
          When you get the expiration message, did you try to click on the button 'Manage License' and revalidate the license (using the file you received by email when you purchased the license)?
          If you do not have the license file, you can retrieve it and download it at https://sketchucation.com/webshop/my-licences.php. Just sign in.
          • ntxdaveN
            ntxdave @ntxdave
            said in [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26:
            Well, I also tried to generate a video with the Animator file that has both perspective and parallel and the generation stopped when it switched from parallel to perspective. So, if the file has all scenes with the camera set the same way (either perspective or parallel) it works fine but having both options in the same file will not generate the video.
            Just thought I would pass this along but maybe you already knew that.
              roxanmusni Newcomers @GavinG
              @GavinG this is also my problem now. Can someone help me fix this?
                Rich O Brien Moderator @roxanmusni
                @roxanmusni said in [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26:
                If you have a license and experience issues please update extensions to recent releases
                • P
                  polosan
                  is it still available for skp 2021?
                  • fredo6F
                    fredo6 @polosan
                    @polosan said in [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26:
                    yes.
                      The current LibFredo6 works with all recent versions of Sketchup.
                      There is also a legacy version in the PluginStore for older versions - i.e. <= v2016
                        rmsnmz
                        today, all of a sudden, my Fredo plug ins stop working with error messages saying that a subfolder was missing. I reinstalled them all but now the Fredo library is failing to install. I tried uninstalling and installing again several times but same issue each time. These is the error log:
                        Extension Errors Report
                        SketchUp: 26.0.429
                        OS: Windows 11
                        Ruby: 3.2.2
                        Extension: Fredo6 LibFredo6 (15.8e - 15 Feb 26)
                        Error: NoMethodError (undefined method split' for ["Animator"]:Array) c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:942:in block in super_flatten'
                        c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:942:in each' c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:942:in super_flatten'
                        c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:865:in load_from_config' c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1261:in block in load_all_plugins'
                        c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1261:in each' c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1261:in load_all_plugins'
                        c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:331:in startup' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:in process'
                        C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:in <module:LibFredo6_Loader>' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
                        <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require'
                        C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/ROB_Axyz.rb:52:in <module:Fredo6>' C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/ROB_Axyz.rb:28:in <top (required)>'
                          rmsnmz
                          anyone is experiencing similar issues? Anyway to fix it?
                          • fredo6F
                            1. What is the message about the subfolder missing? I don't see it
                            2. Which plugins of mine do you have installed?
                            3. If you can start Sketchup with LibFredo6, could you invoke the menu Window > LibFredo6 Settings > Fredo6 Plugins Information for Sketchucation Support... and send me the output text which is displayed in the Ruby console.
                              rmsnmz
                              I probably have all your extensions but only a few shows up now because of the library is failing to install. As for the "sub folder" missing error message, that was the first error message i received and I basically reinstalled all extensions after that. Now, i dont get that message but just the message above regarding the fredo library part. Here is what i see in the Fredo6 Plugins Information for Sketchucation Support:
                              Fredo6 Plugins Information on 2026-03-16 16:38:02 -0700
                              • Sketchup: 26.0.429
                              • LibFredo6: v15.8e
                              • LibFredo6 Binary loaded
                              • Sketchucation ExtensionStore: 5.0.6
                              • SCFLicense: v7.1a - 74
                              • Fredo6 Plugins
                                Signature File: 2026-03-04 15:47:33 -0800
                                Curviloft: 2026-03-11 09:53:17 -0700
                                FredoScale: 2026-03-11 09:56:25 -0700
                                rmsnmz
                                I also see these ruby console messages when I opened the SU:
                                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb) was blocked because it is currently preregistered.
                                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Curviloft.rb) was blocked because it is currently preregistered.
                                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoConnect.rb) was blocked because it is currently preregistered.
                                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoCorner.rb) was blocked because it is currently preregistered.
                                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoScale.rb) was blocked because it is currently preregistered.
                                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSketch.rb) was blocked because it is currently preregistered.
                                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSpline.rb) was blocked because it is currently preregistered.
                                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoTools.rb) was blocked because it is currently preregistered.
                                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_JointPushPull.rb) was blocked because it is currently preregistered.
                                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_MoveAlignMe.rb) was blocked because it is currently preregistered.
                                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_RoundCorner.rb) was blocked because it is currently preregistered.
                                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ThruPaint.rb) was blocked because it is currently preregistered.
                                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb) was blocked because it is currently preregistered.
                                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_TopoShaper.rb) was blocked because it is currently preregistered.
                                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_VisuHole.rb) was blocked because it is currently preregistered.
                                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/jhs01_powerbar.rb) was blocked because it is currently preregistered.
                                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/bezierspline.rb) was blocked because it is currently preregistered.
                                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/habitat_site_context.rb) was blocked because it is currently preregistered.
                                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_bezier.rb) was blocked because it is currently preregistered.
                                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_dynamiccomponents.rb) was blocked because it is currently preregistered.
                                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_sandbox.rb) was blocked because it is currently preregistered.
                                finished reading language file
                                tb_mode,single
                                tb_Settingout,true
                                tb_Draw,true
                                tb_Edit,true
                                tb_Array,true
                                tb_Wall,true
                                tb_Staircase,true
                                tb_Win,true
                                tb_Roof,true
                                tb_Site,true
                                tb_Structure,true
                                point_on_face,true
                                divide,true
                                align,true
                                perpendicular_line,true
                                fonplane,true
                                bestface,true
                                extrude1,true
                                extrude2,true
                                move_vertex,true
                                fillet,true
                                chamfer,true
                                extend,true
                                offset_edge,true
                                hline_faces,true
                                slopeedges,true
                                linear_array,true
                                rect_array,true
                                polar_array,true
                                path_array,true
                                wallsctrl,true
                                opening,true
                                hgroove,true
                                escalator,true
                                wframe,true
                                dframe,true
                                paneldivide,true
                                screen1,true
                                hlouvres,true
                                vlouvres,true
                                joists,true
                                roof1,true
                                hiproof,true
                                revsurf,true
                                mdeck,true
                                stairsctrl,true
                                profiles_on_plane,true
                                cutfill,true
                                siteb,true
                                fndctrl,true
                                columnctrl,true
                                contour,true
                                setlayer,true
                                mergelayer,true
                                framesel,true
                                scale,true
                                center1,true
                                ptsinfo,true
                                extrude3,true
                                profiles3d,true
                                extrude0,true
                                loading 1001bit pro menu >> true
                                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6
                                !LibFredo6.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Curviloft.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoConnect.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoCorner.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoScale.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSketch.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSpline.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoTools.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_JointPushPull.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_MoveAlignMe.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_RoundCorner.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ThruPaint.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_TopoShaper.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_VisuHole.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/jhs01_powerbar.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                warning: key "Select large image en"... not found for locale en-US (AE::LargeImageSplitter::Translate)
                                C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/ae_large_image_splitter/core.rb:475:in create_command' Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/bezierspline.rb can not be loaded because an extension loader file with the same name was previously loaded. "RubyEncoder loader: C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/curic_face_array/rgloader/rgloader32.mingw.x64.so" c:/programdata/sketchup/sketchup 2026/sketchup/plugins/curic_reset_rotation/cr_rotation_main.rbe:39: warning: string literal in condition a5a0decb-544d-41ba-866c-b0054a7b529e Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/habitat_site_context.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_bezier.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_dynamiccomponents.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_sandbox.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Curviloft.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoConnect.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoCorner.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoScale.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSketch.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSpline.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoTools.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_JointPushPull.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_MoveAlignMe.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_RoundCorner.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ThruPaint.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_TopoShaper.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_VisuHole.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/_jhs01_powerbar.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/bezierspline.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/habitat_site_context.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_bezier.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_dynamiccomponents.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_sandbox.rb can not be loaded because an extension loader file with the same name was previously loaded. #<NoMethodError: undefined method split' for ["Animator"]:Array>
                                !libfredo6/lib6core.rbe:942:in block in super_flatten' c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:942:in each'
                                !libfredo6/lib6core.rbe:942:in super_flatten' c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:865:in load_from_config'
                                !libfredo6/lib6core.rbe:1261:in block in load_all_plugins' c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1261:in each'
                                !libfredo6/lib6core.rbe:1261:in load_all_plugins' c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:331:in startup'
                                C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:in process' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:in module:LibFredo6_Loader'
                                C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>' <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require'
                                <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/ROB_Axyz.rb:52:in module:Fredo6'
                                C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/ROB_Axyz.rb:28:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                                C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in <top (required)>' <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require'
                                <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Animator.rb:52:in module:Fredo6'
                                C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Animator.rb:28:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                                <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Curvizard.rb:47:in module:Fredo6'
                                C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Curvizard.rb:26:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                                <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ElevationProfile.rb:47:in module:Fredo6'
                                C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ElevationProfile.rb:26:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                                <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoBatch.rb:52:in module:Fredo6'
                                C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoBatch.rb:28:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                                <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoGuides.rb:47:in module:Fredo6'
                                C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoGuides.rb:26:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                                <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoPortrait.rb:47:in module:Fredo6'
                                C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoPortrait.rb:26:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                                <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSection.rb:52:in module:Fredo6'
                                C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSection.rb:28:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                                <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_GhostComp.rb:47:in module:Fredo6'
                                C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_GhostComp.rb:26:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                                <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_MatSim.rb:52:in module:Fredo6'
                                C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_MatSim.rb:28:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                                <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Pic2Shape.rb:52:in module:Fredo6'
                                C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Pic2Shape.rb:28:in `<top (required)>'
                                "Can not load Curic Helpper!"
                                  rmsnmz
                                  I suspect this has to the updated skecthucation toolbar. I now have two active plugins folder all of a sudden.
                                  1-C:\ProgramData\SketchUp\SketchUp 2026\SketchUp
                                  2-C:\Users\MSonmez\AppData\Roaming\SketchUp\SketchUp 2026\SketchUp
                                  I think this has been causing all the issues. I tried renaming the plugin folder (the one under C:\Users\MSonmez\AppData\Roaming\SketchUp\SketchUp 2026\SketchUp) to something different and now the plugins are loading.....
                                    All of the previously loaded' error-messages suggest that somehow you have duplicates of those extensions installed in different locations, both of which SketchUp loads from.
                                    Several of those causing errors are by other authors and are from other sources than SCF, and even some su_ shipped-extensions...
                                    How are you installing your extensions ?
                                    If you are copying files from one SketchUp version's Plugins folder into another. then it's a recipe for chaos.
                                    If you download them from our PluginStore as RBZs and then use the Extension Manager to install them, then they automatically install in your default Plugins folder, from which SketchUp loads any extension .RB files it finds at startup. In your case it's
                                    If you use the ExtensionStore's dialog to auto-install them, that works without the need for the RBZ step, but they default to install in the same default Plugins folder.
                                    However, you can opt to have your own personal destination folder, chosen and remembered with the ExtensionStore's Settings > Paths option. It's really only useful for those with a centralized folder used across SketchUp versions - you need to set up this alternative path using Fredo's AdditionalPluginsFolder tool.
                                    An alternative path offered might be the Plugins folder in the ProgramData path, but this is only used for extensions shared between several users on the same computer, unlike your own user's Plugins folder personal to your login: it's typically used by more complex extensions like renderers etc. It does load its .RB files before the default Plugins folder so it could explain the duplication, but why all of your extensions seem to have arrived in there is a very unlikely mystery. It's not normally listed unless some previous installation [like a renderer] has made the Plugins folder for its .RB and subfolder...
                                    If you can check for multiple Plugins folders and their duplicated contents it will help. Try to ensure only one version of each .RB and it's matching subfolder exist in any likely-to-be-loading Plugins folder.
                                    Running this text in the Ruby Console will give you a list of all file-paths that are loaded from - BUT only the default ../AppData../Plugings would be normally listed in the ExtensionStore's Paths, never put extensions into another of these folders, unless you are really sure of what you are doing -
                                    $LOAD_PATH
                                    Please report back...
                                      anuragfoa6767 Newcomers
                                      Thank you for informing me. I understand that, as a new user, my post will remain in the queue until it is reviewed and approved by the moderation team. I appreciate your efforts to maintain the quality of the forum.
                                      • fredo6F
                                        NEW RELEASE: LibFredo6 v15.9a - 25 Mar 26
                                        LibFredo6 15.9a is a major release. It includes changes related to:
                                        • FredoBend v1.2a (new plugin)
                                        • Bug Fixing
                                          Slimdog
                                          Good day, I made a donation back in 2018. Can't remember if Fredo had paid plugins back then. I have recently updated my LibFredo6 and my round corner plugin no longer works, and is telling me that my trial version for LibFredo6 is expired. I am still on Sketchup version 2018. Please confirm I need to purchase round corners again.
                                          • fredo6F
                                            fredo6 @Slimdog
                                            You have no license registered for any of my plugins, at least under the username Slimdog.
                                            So, you need to purchase one.
                                            S 1 Reply Last reply
                                            • 109
                                            • 110
                                            • 111
                                            • 112
                                            • 113
                                            • 111 / 113
