    [Plugin Library] LibFredo6 - v16.1a - 31 Aug 26
    2.2k Posts 580 Posters 6.6m Views 582 Watching
      Dave R @GavinG
      @GavinG do you have the latest version of the Sketchucation Extension Store installed?
        GavinG
        I think so, I have 3 new icons on my ribbon ( see attached). This is where I get directed when looking for Sketchucation Extension Store
          GavinG
          • fredo6F Offline
            First, when you have a problem of license, do not try to reinstall. Just check you have the latest versions.
            Also, if you get the message of expiration, try first to revalidate the license. It won't count for a new seat.
            Does it work in your case?
            G 1 Reply Last reply Reply Quote 0
            • fredo6F Offline
              NEW RELEASE: LibFredo6 v15.8e - 15 Feb 26
              LibFredo6 15.8e is a maintenance release. It includes changes related to:
              • Bug Fixing
              • Future compatibility
              • ntxdaveN Offline
                ntxdave @fredo6
                @fredo6 Is there any place where we can find out what the bug fixes are?
                Press F1...thank me later
                • ntxdaveN Offline
                  ntxdave
                  I did a quick test on an old Animator file and it looks like we now can use perspective and generate a video.
                    GavinG @fredo6
                    @fredo6 - I have tried to uninstall and reinstall, no luck, I have just installed the plugin as indicated below in the next reply, still nothing working. I still get the TRIAL PRERIOD EXPIRED window
                    fredo6F 1 Reply Last reply Reply Quote 0
                    • fredo6F Offline
                      fredo6 @GavinG
                      @GavinG
                      When you get the expiration message, did you try to click on the button 'Manage License' and revalidate the license (using the file you received by email when you purchased the license)?
                      If you do not have the license file, you can retrieve it and download it at https://sketchucation.com/webshop/my-licences.php. Just sign in.
                      • ntxdaveN Offline
                        ntxdave @ntxdave
                        said in [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26:
                        Well, I also tried to generate a video with the Animator file that has both perspective and parallel and the generation stopped when it switched from parallel to perspective. So, if the file has all scenes with the camera set the same way (either perspective or parallel) it works fine but having both options in the same file will not generate the video.
                        Just thought I would pass this along but maybe you already knew that.
                          roxanmusni Newcomers @GavinG
                          @GavinG this is also my problem now. Can someone help me fix this?
                            Rich O Brien Moderator @roxanmusni
                            @roxanmusni said in [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26:
                            If you have a license and experience issues please update extensions to recent releases
                              polosan
                              is it still available for skp 2021?
                              • fredo6F Offline
                                fredo6 @polosan
                                @polosan said in [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26:
                                yes.
                                  The current LibFredo6 works with all recent versions of Sketchup.
                                  There is also a legacy version in the PluginStore for older versions - i.e. <= v2016
                                    rmsnmz
                                    today, all of a sudden, my Fredo plug ins stop working with error messages saying that a subfolder was missing. I reinstalled them all but now the Fredo library is failing to install. I tried uninstalling and installing again several times but same issue each time. These is the error log:
                                    Extension Errors Report
                                    SketchUp: 26.0.429
                                    OS: Windows 11
                                    Ruby: 3.2.2
                                    Extension: Fredo6 LibFredo6 (15.8e - 15 Feb 26)
                                    Error: NoMethodError (undefined method split' for ["Animator"]:Array) c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:942:in block in super_flatten'
                                    c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:942:in each' c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:942:in super_flatten'
                                    c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:865:in load_from_config' c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1261:in block in load_all_plugins'
                                    c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1261:in each' c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1261:in load_all_plugins'
                                    c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:331:in startup' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:in process'
                                    C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:in <module:LibFredo6_Loader>' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
                                    <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require'
                                    C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/ROB_Axyz.rb:52:in <module:Fredo6>' C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/ROB_Axyz.rb:28:in <top (required)>'
                                      rmsnmz
                                      anyone is experiencing similar issues? Anyway to fix it?
                                      • fredo6F Offline
                                        1. What is the message about the subfolder missing? I don't see it
                                        2. Which plugins of mine do you have installed?
                                        3. If you can start Sketchup with LibFredo6, could you invoke the menu Window > LibFredo6 Settings > Fredo6 Plugins Information for Sketchucation Support... and send me the output text which is displayed in the Ruby console.
                                          rmsnmz
                                          I probably have all your extensions but only a few shows up now because of the library is failing to install. As for the "sub folder" missing error message, that was the first error message i received and I basically reinstalled all extensions after that. Now, i dont get that message but just the message above regarding the fredo library part. Here is what i see in the Fredo6 Plugins Information for Sketchucation Support:
                                          Fredo6 Plugins Information on 2026-03-16 16:38:02 -0700
                                          • Sketchup: 26.0.429
                                          • LibFredo6: v15.8e
                                          • LibFredo6 Binary loaded
                                          • Sketchucation ExtensionStore: 5.0.6
                                          • SCFLicense: v7.1a - 74
                                          • Fredo6 Plugins
                                            Signature File: 2026-03-04 15:47:33 -0800
                                            Curviloft: 2026-03-11 09:53:17 -0700
                                            FredoScale: 2026-03-11 09:56:25 -0700
                                            rmsnmz
                                            I also see these ruby console messages when I opened the SU:
                                            Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb) was blocked because it is currently preregistered.
                                            Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Curviloft.rb) was blocked because it is currently preregistered.
                                            Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoConnect.rb) was blocked because it is currently preregistered.
                                            Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoCorner.rb) was blocked because it is currently preregistered.
                                            Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoScale.rb) was blocked because it is currently preregistered.
                                            Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSketch.rb) was blocked because it is currently preregistered.
                                            Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSpline.rb) was blocked because it is currently preregistered.
                                            Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoTools.rb) was blocked because it is currently preregistered.
                                            Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_JointPushPull.rb) was blocked because it is currently preregistered.
                                            Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_MoveAlignMe.rb) was blocked because it is currently preregistered.
                                            Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_RoundCorner.rb) was blocked because it is currently preregistered.
                                            Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ThruPaint.rb) was blocked because it is currently preregistered.
                                            Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb) was blocked because it is currently preregistered.
                                            Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_TopoShaper.rb) was blocked because it is currently preregistered.
                                            Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_VisuHole.rb) was blocked because it is currently preregistered.
                                            Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/jhs01_powerbar.rb) was blocked because it is currently preregistered.
                                            Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/bezierspline.rb) was blocked because it is currently preregistered.
                                            Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/habitat_site_context.rb) was blocked because it is currently preregistered.
                                            Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_bezier.rb) was blocked because it is currently preregistered.
                                            Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_dynamiccomponents.rb) was blocked because it is currently preregistered.
                                            Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_sandbox.rb) was blocked because it is currently preregistered.
                                            finished reading language file
                                            tb_mode,single
                                            tb_Settingout,true
                                            tb_Draw,true
                                            tb_Edit,true
                                            tb_Array,true
                                            tb_Wall,true
                                            tb_Staircase,true
                                            tb_Win,true
                                            tb_Roof,true
                                            tb_Site,true
                                            tb_Structure,true
                                            point_on_face,true
                                            divide,true
                                            align,true
                                            perpendicular_line,true
                                            fonplane,true
                                            bestface,true
                                            extrude1,true
                                            extrude2,true
                                            move_vertex,true
                                            fillet,true
                                            chamfer,true
                                            extend,true
                                            offset_edge,true
                                            hline_faces,true
                                            slopeedges,true
                                            linear_array,true
                                            rect_array,true
                                            polar_array,true
                                            path_array,true
                                            wallsctrl,true
                                            opening,true
                                            hgroove,true
                                            escalator,true
                                            wframe,true
                                            dframe,true
                                            paneldivide,true
                                            screen1,true
                                            hlouvres,true
                                            vlouvres,true
                                            joists,true
                                            roof1,true
                                            hiproof,true
                                            revsurf,true
                                            mdeck,true
                                            stairsctrl,true
                                            profiles_on_plane,true
                                            cutfill,true
                                            siteb,true
                                            fndctrl,true
                                            columnctrl,true
                                            contour,true
                                            setlayer,true
                                            mergelayer,true
                                            framesel,true
                                            scale,true
                                            center1,true
                                            ptsinfo,true
                                            extrude3,true
                                            profiles3d,true
                                            extrude0,true
                                            loading 1001bit pro menu >> true
                                            Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6
                                            !LibFredo6.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                            Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Curviloft.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                            Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoConnect.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                            Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoCorner.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                            Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoScale.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                            Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSketch.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                            Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSpline.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                            Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoTools.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                            Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_JointPushPull.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                            Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_MoveAlignMe.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                            Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_RoundCorner.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                            Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ThruPaint.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                            Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                            Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_TopoShaper.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                            Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_VisuHole.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                            Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/jhs01_powerbar.rb can not be loaded because an extension loader file with the same name was previously loaded.
                                            warning: key "Select large image en"... not found for locale en-US (AE::LargeImageSplitter::Translate)
                                            C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/ae_large_image_splitter/core.rb:475:in create_command' Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/bezierspline.rb can not be loaded because an extension loader file with the same name was previously loaded. "RubyEncoder loader: C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/curic_face_array/rgloader/rgloader32.mingw.x64.so" c:/programdata/sketchup/sketchup 2026/sketchup/plugins/curic_reset_rotation/cr_rotation_main.rbe:39: warning: string literal in condition a5a0decb-544d-41ba-866c-b0054a7b529e Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/habitat_site_context.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_bezier.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_dynamiccomponents.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_sandbox.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Curviloft.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoConnect.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoCorner.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoScale.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSketch.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSpline.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoTools.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_JointPushPull.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_MoveAlignMe.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_RoundCorner.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ThruPaint.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_TopoShaper.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_VisuHole.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/_jhs01_powerbar.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/bezierspline.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/habitat_site_context.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_bezier.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_dynamiccomponents.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_sandbox.rb can not be loaded because an extension loader file with the same name was previously loaded. #<NoMethodError: undefined method split' for ["Animator"]:Array>
                                            !libfredo6/lib6core.rbe:942:in block in super_flatten' c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:942:in each'
                                            !libfredo6/lib6core.rbe:942:in super_flatten' c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:865:in load_from_config'
                                            !libfredo6/lib6core.rbe:1261:in block in load_all_plugins' c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1261:in each'
                                            !libfredo6/lib6core.rbe:1261:in load_all_plugins' c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:331:in startup'
                                            C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:in process' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:in module:LibFredo6_Loader'
                                            C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>' <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require'
                                            <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/ROB_Axyz.rb:52:in module:Fredo6'
                                            C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/ROB_Axyz.rb:28:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                                            C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in <top (required)>' <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require'
                                            <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Animator.rb:52:in module:Fredo6'
                                            C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Animator.rb:28:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                                            <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Curvizard.rb:47:in module:Fredo6'
                                            C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Curvizard.rb:26:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                                            <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ElevationProfile.rb:47:in module:Fredo6'
                                            C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ElevationProfile.rb:26:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                                            <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoBatch.rb:52:in module:Fredo6'
                                            C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoBatch.rb:28:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                                            <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoGuides.rb:47:in module:Fredo6'
                                            C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoGuides.rb:26:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                                            <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoPortrait.rb:47:in module:Fredo6'
                                            C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoPortrait.rb:26:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                                            <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSection.rb:52:in module:Fredo6'
                                            C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSection.rb:28:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                                            <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_GhostComp.rb:47:in module:Fredo6'
                                            C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_GhostComp.rb:26:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                                            <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_MatSim.rb:52:in module:Fredo6'
                                            C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_MatSim.rb:28:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                                            <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Pic2Shape.rb:52:in module:Fredo6'
                                            C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Pic2Shape.rb:28:in `<top (required)>'
                                            "Can not load Curic Helpper!"
                                            • 108
                                            • 109
                                            • 110
                                            • 111
                                            • 112
                                            • 110 / 112
