    [Plugin Library] LibFredo6 - v16.1a - 31 Aug 26
    2.2k Posts 580 Posters 6.6m Views 582 Watching
      The current LibFredo6 works with all recent versions of Sketchup.
      There is also a legacy version in the PluginStore for older versions - i.e. <= v2016
        rmsnmz
        today, all of a sudden, my Fredo plug ins stop working with error messages saying that a subfolder was missing. I reinstalled them all but now the Fredo library is failing to install. I tried uninstalling and installing again several times but same issue each time. These is the error log:
        Extension Errors Report
        SketchUp: 26.0.429
        OS: Windows 11
        Ruby: 3.2.2
        Extension: Fredo6 LibFredo6 (15.8e - 15 Feb 26)
        Error: NoMethodError (undefined method split' for ["Animator"]:Array) c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:942:in block in super_flatten'
        c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:942:in each' c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:942:in super_flatten'
        c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:865:in load_from_config' c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1261:in block in load_all_plugins'
        c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1261:in each' c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1261:in load_all_plugins'
        c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:331:in startup' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:in process'
        C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:in <module:LibFredo6_Loader>' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
        <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require'
        C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/ROB_Axyz.rb:52:in <module:Fredo6>' C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/ROB_Axyz.rb:28:in <top (required)>'
          rmsnmz
          anyone is experiencing similar issues? Anyway to fix it?
          • fredo6F Offline
            1. What is the message about the subfolder missing? I don't see it
            2. Which plugins of mine do you have installed?
            3. If you can start Sketchup with LibFredo6, could you invoke the menu Window > LibFredo6 Settings > Fredo6 Plugins Information for Sketchucation Support... and send me the output text which is displayed in the Ruby console.
              rmsnmz
              I probably have all your extensions but only a few shows up now because of the library is failing to install. As for the "sub folder" missing error message, that was the first error message i received and I basically reinstalled all extensions after that. Now, i dont get that message but just the message above regarding the fredo library part. Here is what i see in the Fredo6 Plugins Information for Sketchucation Support:
              Fredo6 Plugins Information on 2026-03-16 16:38:02 -0700
              • Sketchup: 26.0.429
              • LibFredo6: v15.8e
              • LibFredo6 Binary loaded
              • Sketchucation ExtensionStore: 5.0.6
              • SCFLicense: v7.1a - 74
              • Fredo6 Plugins
                Signature File: 2026-03-04 15:47:33 -0800
                Curviloft: 2026-03-11 09:53:17 -0700
                FredoScale: 2026-03-11 09:56:25 -0700
                rmsnmz
                I also see these ruby console messages when I opened the SU:
                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb) was blocked because it is currently preregistered.
                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Curviloft.rb) was blocked because it is currently preregistered.
                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoConnect.rb) was blocked because it is currently preregistered.
                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoCorner.rb) was blocked because it is currently preregistered.
                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoScale.rb) was blocked because it is currently preregistered.
                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSketch.rb) was blocked because it is currently preregistered.
                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSpline.rb) was blocked because it is currently preregistered.
                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoTools.rb) was blocked because it is currently preregistered.
                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_JointPushPull.rb) was blocked because it is currently preregistered.
                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_MoveAlignMe.rb) was blocked because it is currently preregistered.
                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_RoundCorner.rb) was blocked because it is currently preregistered.
                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ThruPaint.rb) was blocked because it is currently preregistered.
                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb) was blocked because it is currently preregistered.
                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_TopoShaper.rb) was blocked because it is currently preregistered.
                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_VisuHole.rb) was blocked because it is currently preregistered.
                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/jhs01_powerbar.rb) was blocked because it is currently preregistered.
                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/bezierspline.rb) was blocked because it is currently preregistered.
                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/habitat_site_context.rb) was blocked because it is currently preregistered.
                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_bezier.rb) was blocked because it is currently preregistered.
                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_dynamiccomponents.rb) was blocked because it is currently preregistered.
                Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_sandbox.rb) was blocked because it is currently preregistered.
                finished reading language file
                tb_mode,single
                tb_Settingout,true
                tb_Draw,true
                tb_Edit,true
                tb_Array,true
                tb_Wall,true
                tb_Staircase,true
                tb_Win,true
                tb_Roof,true
                tb_Site,true
                tb_Structure,true
                point_on_face,true
                divide,true
                align,true
                perpendicular_line,true
                fonplane,true
                bestface,true
                extrude1,true
                extrude2,true
                move_vertex,true
                fillet,true
                chamfer,true
                extend,true
                offset_edge,true
                hline_faces,true
                slopeedges,true
                linear_array,true
                rect_array,true
                polar_array,true
                path_array,true
                wallsctrl,true
                opening,true
                hgroove,true
                escalator,true
                wframe,true
                dframe,true
                paneldivide,true
                screen1,true
                hlouvres,true
                vlouvres,true
                joists,true
                roof1,true
                hiproof,true
                revsurf,true
                mdeck,true
                stairsctrl,true
                profiles_on_plane,true
                cutfill,true
                siteb,true
                fndctrl,true
                columnctrl,true
                contour,true
                setlayer,true
                mergelayer,true
                framesel,true
                scale,true
                center1,true
                ptsinfo,true
                extrude3,true
                profiles3d,true
                extrude0,true
                loading 1001bit pro menu >> true
                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6
                !LibFredo6.rb can not be loaded because an extension loader file with the same name was previously loaded.
                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Curviloft.rb can not be loaded because an extension loader file with the same name was previously loaded.
                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoConnect.rb can not be loaded because an extension loader file with the same name was previously loaded.
                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoCorner.rb can not be loaded because an extension loader file with the same name was previously loaded.
                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoScale.rb can not be loaded because an extension loader file with the same name was previously loaded.
                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSketch.rb can not be loaded because an extension loader file with the same name was previously loaded.
                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSpline.rb can not be loaded because an extension loader file with the same name was previously loaded.
                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoTools.rb can not be loaded because an extension loader file with the same name was previously loaded.
                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_JointPushPull.rb can not be loaded because an extension loader file with the same name was previously loaded.
                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_MoveAlignMe.rb can not be loaded because an extension loader file with the same name was previously loaded.
                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_RoundCorner.rb can not be loaded because an extension loader file with the same name was previously loaded.
                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ThruPaint.rb can not be loaded because an extension loader file with the same name was previously loaded.
                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb can not be loaded because an extension loader file with the same name was previously loaded.
                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_TopoShaper.rb can not be loaded because an extension loader file with the same name was previously loaded.
                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_VisuHole.rb can not be loaded because an extension loader file with the same name was previously loaded.
                Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/jhs01_powerbar.rb can not be loaded because an extension loader file with the same name was previously loaded.
                warning: key "Select large image en"... not found for locale en-US (AE::LargeImageSplitter::Translate)
                C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/ae_large_image_splitter/core.rb:475:in create_command' Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/bezierspline.rb can not be loaded because an extension loader file with the same name was previously loaded. "RubyEncoder loader: C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/curic_face_array/rgloader/rgloader32.mingw.x64.so" c:/programdata/sketchup/sketchup 2026/sketchup/plugins/curic_reset_rotation/cr_rotation_main.rbe:39: warning: string literal in condition a5a0decb-544d-41ba-866c-b0054a7b529e Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/habitat_site_context.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_bezier.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_dynamiccomponents.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_sandbox.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Curviloft.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoConnect.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoCorner.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoScale.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSketch.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSpline.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoTools.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_JointPushPull.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_MoveAlignMe.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_RoundCorner.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ThruPaint.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_TopoShaper.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_VisuHole.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/_jhs01_powerbar.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/bezierspline.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/habitat_site_context.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_bezier.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_dynamiccomponents.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_sandbox.rb can not be loaded because an extension loader file with the same name was previously loaded. #<NoMethodError: undefined method split' for ["Animator"]:Array>
                !libfredo6/lib6core.rbe:942:in block in super_flatten' c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:942:in each'
                !libfredo6/lib6core.rbe:942:in super_flatten' c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:865:in load_from_config'
                !libfredo6/lib6core.rbe:1261:in block in load_all_plugins' c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1261:in each'
                !libfredo6/lib6core.rbe:1261:in load_all_plugins' c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:331:in startup'
                C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:in process' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:in module:LibFredo6_Loader'
                C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>' <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require'
                <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/ROB_Axyz.rb:52:in module:Fredo6'
                C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/ROB_Axyz.rb:28:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in <top (required)>' <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require'
                <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Animator.rb:52:in module:Fredo6'
                C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Animator.rb:28:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Curvizard.rb:47:in module:Fredo6'
                C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Curvizard.rb:26:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ElevationProfile.rb:47:in module:Fredo6'
                C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ElevationProfile.rb:26:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoBatch.rb:52:in module:Fredo6'
                C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoBatch.rb:28:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoGuides.rb:47:in module:Fredo6'
                C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoGuides.rb:26:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoPortrait.rb:47:in module:Fredo6'
                C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoPortrait.rb:26:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSection.rb:52:in module:Fredo6'
                C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSection.rb:28:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_GhostComp.rb:47:in module:Fredo6'
                C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_GhostComp.rb:26:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_MatSim.rb:52:in module:Fredo6'
                C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_MatSim.rb:28:in <top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in -'
                <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Pic2Shape.rb:52:in module:Fredo6'
                C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Pic2Shape.rb:28:in `<top (required)>'
                "Can not load Curic Helpper!"
                  rmsnmz
                  I suspect this has to the updated skecthucation toolbar. I now have two active plugins folder all of a sudden.
                  1-C:\ProgramData\SketchUp\SketchUp 2026\SketchUp
                  2-C:\Users\MSonmez\AppData\Roaming\SketchUp\SketchUp 2026\SketchUp
                  I think this has been causing all the issues. I tried renaming the plugin folder (the one under C:\Users\MSonmez\AppData\Roaming\SketchUp\SketchUp 2026\SketchUp) to something different and now the plugins are loading.....
                    All of the previously loaded' error-messages suggest that somehow you have duplicates of those extensions installed in different locations, both of which SketchUp loads from.
                    Several of those causing errors are by other authors and are from other sources than SCF, and even some su_ shipped-extensions...
                    How are you installing your extensions ?
                    If you are copying files from one SketchUp version's Plugins folder into another. then it's a recipe for chaos.
                    If you download them from our PluginStore as RBZs and then use the Extension Manager to install them, then they automatically install in your default Plugins folder, from which SketchUp loads any extension .RB files it finds at startup. In your case it's
                    If you use the ExtensionStore's dialog to auto-install them, that works without the need for the RBZ step, but they default to install in the same default Plugins folder.
                    However, you can opt to have your own personal destination folder, chosen and remembered with the ExtensionStore's Settings > Paths option. It's really only useful for those with a centralized folder used across SketchUp versions - you need to set up this alternative path using Fredo's AdditionalPluginsFolder tool.
                    An alternative path offered might be the Plugins folder in the ProgramData path, but this is only used for extensions shared between several users on the same computer, unlike your own user's Plugins folder personal to your login: it's typically used by more complex extensions like renderers etc. It does load its .RB files before the default Plugins folder so it could explain the duplication, but why all of your extensions seem to have arrived in there is a very unlikely mystery. It's not normally listed unless some previous installation [like a renderer] has made the Plugins folder for its .RB and subfolder...
                    If you can check for multiple Plugins folders and their duplicated contents it will help. Try to ensure only one version of each .RB and it's matching subfolder exist in any likely-to-be-loading Plugins folder.
                    Running this text in the Ruby Console will give you a list of all file-paths that are loaded from - BUT only the default ../AppData../Plugings would be normally listed in the ExtensionStore's Paths, never put extensions into another of these folders, unless you are really sure of what you are doing -
                    $LOAD_PATH
                    Please report back...
                      anuragfoa6767 Newcomers
                      Thank you for informing me. I understand that, as a new user, my post will remain in the queue until it is reviewed and approved by the moderation team. I appreciate your efforts to maintain the quality of the forum.
                      • fredo6F Offline
                        NEW RELEASE: LibFredo6 v15.9a - 25 Mar 26
                        LibFredo6 15.9a is a major release. It includes changes related to:
                        • FredoBend v1.2a (new plugin)
                        • Bug Fixing
                          Slimdog
                          Good day, I made a donation back in 2018. Can't remember if Fredo had paid plugins back then. I have recently updated my LibFredo6 and my round corner plugin no longer works, and is telling me that my trial version for LibFredo6 is expired. I am still on Sketchup version 2018. Please confirm I need to purchase round corners again.
                          fredo6F 1 Reply Last reply Reply Quote 0
                          • fredo6F Offline
                            fredo6 @Slimdog
                            You have no license registered for any of my plugins, at least under the username Slimdog.
                            So, you need to purchase one.
                            S 1 Reply Last reply Reply Quote 0
                              Slimdog @fredo6
                              @fredo6 Thanks for the response. I just had to install sketchucation tools and it works now.
                              • fredo6F Offline
                                NEW RELEASE: LibFredo6 v15.9b - 21 Apr 26
                                LibFredo6 15.9b is a major release. It includes changes related to:
                                • Future compatibility
                                • Bug Fixing
                                  Tpdart
                                  Hi- I've been using Libfredo tools for a while but recently had a hardware issue with one of my drives unrelated to the SU install or the additional folders location. Basically SU graaaaduaalllyy froze along with my PC and I had to force a hardware shut down. On replacing the hardware and starting up SU again, I'm getting errors pop up- "You must install Libfredo6 or above"; I have manually reinstalled this via SU from the additional folders location but it didn't work on reopening of SU with the same message. This is the followed by load errors of the extensions including libfredo etc.
                                  Weirdly, in SU extension manager I tried disabling the libfredo extensions, saving changes, closing SU, reopening and the extensions are still enabled!!! Any thoughts on a resolution please? Thanks
                                  • fredo6F Offline
                                    It would be helpful that you indicate which version of SU you reinstalled, and which of my plugin you were also trying to install.
                                    Also, please quote the error message correctly.
                                    Are you also saying that you use AdditionalPluginFolders plugin to install plugins in an alternative directory?
                                      Tpdart
                                      Hi- manged to delete the original post so restated with additional info requested (!) I've been using Libfredo tools for a while but recently had a hardware issue with one of my drives unrelated to the SU 2023 (on win 11) install or the additional folders location. Basically SU graaaaduaalllyy froze along with my PC and I had to force a hardware shut down. On replacing the hardware and starting up SU again, I'm getting errors pop up- "You must install Libfredo6 or above"; I have manually reinstalled libfredo 6v_15.9 via SU from the additional folders location but it didn't work on reopening of SU with the same message. This is the followed by load errors of the extensions including libfredo, curviloft, fredoscale, fredospline, fredotools, fredocorner etc. Not getting licencing reports (presumably as they haven't loaded).
                                      Dave RD T 2 Replies Last reply Reply Quote 0
                                        Dave R @Tpdart
                                        First update to SketchUp 2026. You must have an up to date SketchUp subscription since you are using SketchUp 2023 so you can update to 2026 at no additional charge.
                                        Next, make sure SketchUp is installed correctly so that Windows 11 grants the required permissions to allow SketchUp to write the files it needs. Correct installation involves right clicking on the downloaded installer and selecting Run as administrator.
                                        Make sure you have the latest version of the Sketchucation ExtensionStore installed and use it to install LibFredo6 and the other extensions.
                                          Tpdart @Tpdart
                                          All working now- thanks
                                          TIGT 1 Reply Last reply Reply Quote 0
                                            TIG Moderator @Tpdart
                                            @Tpdart
                                            Explaining how you fixed things helps others reading this, and gives useful feedback to moderators and experienced users who might be 'advising'...
                                            • 108
                                            • 109
                                            • 110
                                            • 111
                                            • 112
                                            • 111 / 112
