[Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
@fredo6 - I have tried to uninstall and reinstall, no luck, I have just installed the plugin as indicated below in the next reply, still nothing working. I still get the TRIAL PRERIOD EXPIRED window
@GavinG
When you get the expiration message, did you try to click on the button 'Manage License' and revalidate the license (using the file you received by email when you purchased the license)?If you do not have the license file, you can retrieve it and download it at https://sketchucation.com/webshop/my-licences.php. Just sign in.
said in [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26:
I did a quick test on an old Animator file and it looks like we now can use perspective and generate a video.
Well, I also tried to generate a video with the Animator file that has both perspective and parallel and the generation stopped when it switched from parallel to perspective. So, if the file has all scenes with the camera set the same way (either perspective or parallel) it works fine but having both options in the same file will not generate the video.
Just thought I would pass this along but maybe you already knew that.
@GavinG this is also my problem now. Can someone help me fix this?
@roxanmusni said in [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26:
If you have a license and experience issues please update extensions to recent releases
is it still available for skp 2021?
@polosan said in [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26:
yes.
The current LibFredo6 works with all recent versions of Sketchup.
There is also a legacy version in the PluginStore for older versions - i.e. <= v2016 -
today, all of a sudden, my Fredo plug ins stop working with error messages saying that a subfolder was missing. I reinstalled them all but now the Fredo library is failing to install. I tried uninstalling and installing again several times but same issue each time. These is the error log:
Extension Errors Report
SketchUp: 26.0.429
OS: Windows 11
Ruby: 3.2.2Extension: Fredo6 LibFredo6 (15.8e - 15 Feb 26)
Error: NoMethodError (undefined methodsplit' for ["Animator"]:Array) c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:942:inblock in super_flatten'
c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:942:ineach' c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:942:insuper_flatten'
c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:865:inload_from_config' c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1261:inblock in load_all_plugins'
c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1261:ineach' c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1261:inload_all_plugins'
c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:331:instartup' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:inprocess'
C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:in<module:LibFredo6_Loader>' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in<top (required)>'
<internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:inrequire' <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:inrequire'
C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/ROB_Axyz.rb:52:in<module:Fredo6>' C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/ROB_Axyz.rb:28:in<top (required)>' -
anyone is experiencing similar issues? Anyway to fix it?
What is the message about the subfolder missing? I don't see it
Which plugins of mine do you have installed?
If you can start Sketchup with LibFredo6, could you invoke the menu Window > LibFredo6 Settings > Fredo6 Plugins Information for Sketchucation Support... and send me the output text which is displayed in the Ruby console.
I probably have all your extensions but only a few shows up now because of the library is failing to install. As for the "sub folder" missing error message, that was the first error message i received and I basically reinstalled all extensions after that. Now, i dont get that message but just the message above regarding the fredo library part. Here is what i see in the Fredo6 Plugins Information for Sketchucation Support:
Fredo6 Plugins Information on 2026-03-16 16:38:02 -0700
- Platform: x64-mswin64_140 - Ruby: 3.2.2
- Sketchup: 26.0.429
- LibFredo6: v15.8e
- LibFredo6 Binary loaded
- Sketchucation ExtensionStore: 5.0.6
- SCFLicense: v7.1a - 74
- Fredo6 Plugins
- SCFLicense directory present
Signature File: 2026-03-04 15:47:33 -0800
Curviloft: 2026-03-11 09:53:17 -0700
FredoScale: 2026-03-11 09:56:25 -0700
I also see these ruby console messages when I opened the SU:
Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb) was blocked because it is currently preregistered.
Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Curviloft.rb) was blocked because it is currently preregistered.
Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoConnect.rb) was blocked because it is currently preregistered.
Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoCorner.rb) was blocked because it is currently preregistered.
Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoScale.rb) was blocked because it is currently preregistered.
Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSketch.rb) was blocked because it is currently preregistered.
Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSpline.rb) was blocked because it is currently preregistered.
Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoTools.rb) was blocked because it is currently preregistered.
Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_JointPushPull.rb) was blocked because it is currently preregistered.
Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_MoveAlignMe.rb) was blocked because it is currently preregistered.
Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_RoundCorner.rb) was blocked because it is currently preregistered.
Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ThruPaint.rb) was blocked because it is currently preregistered.
Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb) was blocked because it is currently preregistered.
Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_TopoShaper.rb) was blocked because it is currently preregistered.
Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_VisuHole.rb) was blocked because it is currently preregistered.
Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/jhs01_powerbar.rb) was blocked because it is currently preregistered.
Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/bezierspline.rb) was blocked because it is currently preregistered.
Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/habitat_site_context.rb) was blocked because it is currently preregistered.
Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_bezier.rb) was blocked because it is currently preregistered.
Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_dynamiccomponents.rb) was blocked because it is currently preregistered.
Preregistration of extension with loader file (C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_sandbox.rb) was blocked because it is currently preregistered.
finished reading language file
tb_mode,single
tb_Settingout,true
tb_Draw,true
tb_Edit,true
tb_Array,true
tb_Wall,true
tb_Staircase,true
tb_Win,true
tb_Roof,true
tb_Site,true
tb_Structure,true
point_on_face,true
divide,true
align,true
perpendicular_line,true
fonplane,true
bestface,true
extrude1,true
extrude2,true
move_vertex,true
fillet,true
chamfer,true
extend,true
offset_edge,true
hline_faces,true
slopeedges,true
linear_array,true
rect_array,true
polar_array,true
path_array,true
wallsctrl,true
opening,true
hgroove,true
escalator,true
wframe,true
dframe,true
paneldivide,true
screen1,true
hlouvres,true
vlouvres,true
joists,true
roof1,true
hiproof,true
revsurf,true
mdeck,true
stairsctrl,true
profiles_on_plane,true
cutfill,true
siteb,true
fndctrl,true
columnctrl,true
contour,true
setlayer,true
mergelayer,true
framesel,true
scale,true
center1,true
ptsinfo,true
extrude3,true
profiles3d,true
extrude0,true
loading 1001bit pro menu >> true
Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6!LibFredo6.rb can not be loaded because an extension loader file with the same name was previously loaded.
Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Curviloft.rb can not be loaded because an extension loader file with the same name was previously loaded.
Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoConnect.rb can not be loaded because an extension loader file with the same name was previously loaded.
Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoCorner.rb can not be loaded because an extension loader file with the same name was previously loaded.
Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoScale.rb can not be loaded because an extension loader file with the same name was previously loaded.
Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSketch.rb can not be loaded because an extension loader file with the same name was previously loaded.
Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSpline.rb can not be loaded because an extension loader file with the same name was previously loaded.
Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoTools.rb can not be loaded because an extension loader file with the same name was previously loaded.
Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_JointPushPull.rb can not be loaded because an extension loader file with the same name was previously loaded.
Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_MoveAlignMe.rb can not be loaded because an extension loader file with the same name was previously loaded.
Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_RoundCorner.rb can not be loaded because an extension loader file with the same name was previously loaded.
Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ThruPaint.rb can not be loaded because an extension loader file with the same name was previously loaded.
Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb can not be loaded because an extension loader file with the same name was previously loaded.
Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_TopoShaper.rb can not be loaded because an extension loader file with the same name was previously loaded.
Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_VisuHole.rb can not be loaded because an extension loader file with the same name was previously loaded.
Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/jhs01_powerbar.rb can not be loaded because an extension loader file with the same name was previously loaded.
warning: key "Select large image en"... not found for locale en-US (AE::LargeImageSplitter::Translate)
C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/ae_large_image_splitter/core.rb:475:increate_command' Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/bezierspline.rb can not be loaded because an extension loader file with the same name was previously loaded. "RubyEncoder loader: C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/curic_face_array/rgloader/rgloader32.mingw.x64.so" c:/programdata/sketchup/sketchup 2026/sketchup/plugins/curic_reset_rotation/cr_rotation_main.rbe:39: warning: string literal in condition a5a0decb-544d-41ba-866c-b0054a7b529e Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/habitat_site_context.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_bezier.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_dynamiccomponents.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_sandbox.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Curviloft.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoConnect.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoCorner.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoScale.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSketch.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSpline.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoTools.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_JointPushPull.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_MoveAlignMe.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_RoundCorner.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ThruPaint.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_TopoShaper.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_VisuHole.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/_jhs01_powerbar.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/bezierspline.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/habitat_site_context.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_bezier.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_dynamiccomponents.rb can not be loaded because an extension loader file with the same name was previously loaded. Extension loader file C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/su_sandbox.rb can not be loaded because an extension loader file with the same name was previously loaded. #<NoMethodError: undefined methodsplit' for ["Animator"]:Array>
c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6!libfredo6/lib6core.rbe:942:inblock in super_flatten' c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:942:ineach'
c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6!libfredo6/lib6core.rbe:942:insuper_flatten' c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:865:inload_from_config'
c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6!libfredo6/lib6core.rbe:1261:inblock in load_all_plugins' c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1261:ineach'
c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6!libfredo6/lib6core.rbe:1261:inload_all_plugins' c:/users/msonmez/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:331:instartup'
C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:inprocess' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:inmodule:LibFredo6_Loader'
C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in<top (required)>' <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:inrequire'
<internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:inrequire' C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/ROB_Axyz.rb:52:inmodule:Fredo6'
C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/ROB_Axyz.rb:28:in<top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in-'
C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in<top (required)>' <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:inrequire'
<internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:inrequire' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Animator.rb:52:inmodule:Fredo6'
C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Animator.rb:28:in<top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in-'
<internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:inrequire' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Curvizard.rb:47:inmodule:Fredo6'
C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Curvizard.rb:26:in<top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in-'
<internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:inrequire' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ElevationProfile.rb:47:inmodule:Fredo6'
C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_ElevationProfile.rb:26:in<top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in-'
<internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:inrequire' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoBatch.rb:52:inmodule:Fredo6'
C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoBatch.rb:28:in<top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in-'
<internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:inrequire' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoGuides.rb:47:inmodule:Fredo6'
C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoGuides.rb:26:in<top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in-'
<internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:inrequire' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoPortrait.rb:47:inmodule:Fredo6'
C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoPortrait.rb:26:in<top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in-'
<internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:inrequire' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSection.rb:52:inmodule:Fredo6'
C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_FredoSection.rb:28:in<top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in-'
<internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:inrequire' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_GhostComp.rb:47:inmodule:Fredo6'
C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_GhostComp.rb:26:in<top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in-'
<internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:inrequire' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_MatSim.rb:52:inmodule:Fredo6'
C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_MatSim.rb:28:in<top (required)>' #<TypeError: can't convert NilClass into an exact number> C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:86:in-'
<internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:inrequire' C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Pic2Shape.rb:52:inmodule:Fredo6'
C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_Pic2Shape.rb:28:in `<top (required)>'
"Can not load Curic Helpper!" -
I suspect this has to the updated skecthucation toolbar. I now have two active plugins folder all of a sudden.
1-C:\ProgramData\SketchUp\SketchUp 2026\SketchUp
2-C:\Users\MSonmez\AppData\Roaming\SketchUp\SketchUp 2026\SketchUpI think this has been causing all the issues. I tried renaming the plugin folder (the one under C:\Users\MSonmez\AppData\Roaming\SketchUp\SketchUp 2026\SketchUp) to something different and now the plugins are loading.....
All of the previously loaded' error-messages suggest that somehow you have duplicates of those extensions installed in different locations, both of which SketchUp loads from.
Several of those causing errors are by other authors and are from other sources than SCF, and even some su_ shipped-extensions...How are you installing your extensions ?
If you are copying files from one SketchUp version's Plugins folder into another. then it's a recipe for chaos.
If you download them from our PluginStore as RBZs and then use the Extension Manager to install them, then they automatically install in your default Plugins folder, from which SketchUp loads any extension .RB files it finds at startup. In your case it's
C:/Users/MSonmez/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/PluginsIf you use the ExtensionStore's dialog to auto-install them, that works without the need for the RBZ step, but they default to install in the same default Plugins folder.
However, you can opt to have your own personal destination folder, chosen and remembered with the ExtensionStore's Settings > Paths option. It's really only useful for those with a centralized folder used across SketchUp versions - you need to set up this alternative path using Fredo's AdditionalPluginsFolder tool.An alternative path offered might be the Plugins folder in the ProgramData path, but this is only used for extensions shared between several users on the same computer, unlike your own user's Plugins folder personal to your login: it's typically used by more complex extensions like renderers etc. It does load its .RB files before the default Plugins folder so it could explain the duplication, but why all of your extensions seem to have arrived in there is a very unlikely mystery. It's not normally listed unless some previous installation [like a renderer] has made the Plugins folder for its .RB and subfolder...
If you can check for multiple Plugins folders and their duplicated contents it will help. Try to ensure only one version of each .RB and it's matching subfolder exist in any likely-to-be-loading Plugins folder.
Running this text in the Ruby Console will give you a list of all file-paths that are loaded from - BUT only the default
../AppData../Plugingswould be normally listed in the ExtensionStore's Paths, never put extensions into another of these folders, unless you are really sure of what you are doing -
$LOAD_PATH
Please report back... -
Thank you for informing me. I understand that, as a new user, my post will remain in the queue until it is reviewed and approved by the moderation team. I appreciate your efforts to maintain the quality of the forum.
NEW RELEASE: LibFredo6 v15.9a - 25 Mar 26
LibFredo6 15.9a is a major release. It includes changes related to:
- FredoBend v1.2a (new plugin)
- Bug Fixing
Good day, I made a donation back in 2018. Can't remember if Fredo had paid plugins back then. I have recently updated my LibFredo6 and my round corner plugin no longer works, and is telling me that my trial version for LibFredo6 is expired. I am still on Sketchup version 2018. Please confirm I need to purchase round corners again.
@fredo6 Thanks for the response. I just had to install sketchucation tools and it works now.
