    2.3k Posts 517 Posters 3.0m Views 522 Watching
    • C
      Christel Chenot
      Thanks to Fredo6 for the sending solution 🙂 - Solved
      Merci à @fredo6 pour la solution qui m'a été envoyée 🙂 - Résolu
        Mvmcneil
        Hi I just purchased the 8 bundle licenses. But for some reason, when I go to activate Roundcorner with the downloaded license file, the plug-in doesn't see the file. It was doing the same with JointPushpull but then the file showed up for that plug-in but still not for Roundcorner. Any tips to make this read the file? I downloaded the license files several times and unblocked them.
          Are you sure you are trying to activate RoundCorner and not Fredo Corner?
          M 1 Reply Last reply
            Mvmcneil @Dave R
            @Dave-R
            Ah yes my bad. It was Fredo Corner not RoundCorner.
            Dave RD 1 Reply Last reply 👍
              Dave R @Mvmcneil
              @Mvmcneil ahh ... Good that you got it sorted. Two different extensions and two different licenses. Both a good to have, though.
              • B
                bentaclas
                i need to buy license for animator.....how to purchase it...please reply me
                G 1 Reply Last reply
                • G
                  Gábor @bentaclas
                  @bentaclas Log in to SketchUcation.com. Go to URL: https://sketchucation.com/purchase-smart.php?plugin=Animator
                  Press the "Buy Now" button
                    alexnegru1234
                    Hello can someone help me with solving this error please?
                      First you need to update your extensions because License Version 6.4a-74 is outdated.
                      Please upgrade Sketchucation Tools: https://sketchucation.com/plugin/696-sketchucationtools
                      Please upgrade Libfredo: https://sketchucation.com/pluginstore?pln=LibFredo6
                      Regarding your error message you need to whitelist *.sketchucation.com on your network or switch to a less strict network.
                        DWH88
                        [Success] How to purchase and activate the Animator SCF License in SketchUp Make 2017
                        Hi everyone,
                        I just wanted to share a quick guide for anyone still using SketchUp Make 2017. I successfully purchased and activated the SCF License for Animator. Since the "Purchase" button isn't always easy to find on the website, here is the method that worked for me:
                        Prerequisites:
                        Make sure you have the latest versions of SketchUcation Tools, LibFredo6, and Animator installed.
                        Step 1: Purchase the License via SketchUp (Recommended)
                        This method is the safest because it redirects you to the exact correct page in the shop.
                        Install the plugins mentioned above.
                        Open SketchUp 2017.
                        Go to the menu: Tools > Fredo6 Collection > Animator > License...
                        In the window that opens, click the button "Obtain License".
                        This will open your web browser directly to the correct purchase page for the plugin.
                        Purchase the license and download the .scflicense file to your computer.
                        Step 2: Activate the License
                        Now connect the downloaded file to the plugin in SketchUp.
                        Open SketchUp 2017 again.
                        Go to Tools > Fredo6 Collection > Animator > License...
                        (Note: If the "License..." menu item is missing, your LibFredo6 or SketchUcation Tools version is likely outdated).
                        Click on "Validate License".
                        Browse for the .scflicense file you downloaded in Step 1 and select it.
                        The system will do a quick online check. Afterwards, you should see a green checkmark with the status "Active".
                        I hope this helps other Make 2017 users!
                        • K
                          kavi priyan Newcomers
                          can you give me the trail pack of curviloft
                            Dave R @kavi priyan
                            @kavi-priyan install the Sketchucation ExtensionStore and use it to search for and install LibFredo6 and Curviloft. There's a 30-day trial period for Curviloft. After the 30 days you can purchase the license if you wish to continue using it.
                            • Z
                              ZMD
                              hi, i purchased the roundcorner perpetual liscense about two years ago. I am getting pop ups when i try to use it now stating that my trial period is over. Ive been going in circles trying to verify/update to the latest version of sketchucation with no clear path/luck. in my extension manager, the fredo 6 round corner extension ios signed and enabled....
                              HELP A BROTHA OUT 🙂
                                @zmd make sure all your extensions are the latest releases.
                                If they are please share the error messages you are getting so we have something to chew on
                                  @zmd
                                  Also make sure you have the latest SketchUcation toolset installed for the licensing etc [>=5.0.5], it's version is shown in the top bar of its dialog.
                                  If you update it restart SketchUp to sync everything...
                                  As well as the latest versions of Fredo's extensions ensure you have his latest LibFredo6 too...
                                  PS. Don't confuse Fredo's RoundCorner and FredoCorner extensions, they are separate tools, each needing their own license...
                                  PPS. The current toolset requires >v2017 - what's yours ?
                                  • ntxdaveN
                                    ntxdave
                                    I keep getting this message
                                    If I go to the Extension Manager here is what I see:
                                    If I go to the SketchUcation Tools here is what I see:
                                    Notice item 13.
                                    NOt sure whatr I need to do to get the license updated.
                                    Press F1...thank me later
                                      Go to https://sketchucation.com/webshop/my-licences.php
                                      Download your license file
                                      Open SketchUp
                                      Go to Tools > Fredo Collection > FredoSketch > License
                                      Click Activate and pick your downloaded license file
                                      • ntxdaveN
                                        ntxdave
                                        OK, When I go to the licenses link you provided, I am not seeing the FredoSketch license so I cannot download it.
                                          Dave R @ntxdave
                                          @ntxdave said in SCFLicense: Extension Licensing on Sketchucation:
                                          Did you purchase a license for FredoSketch?
                                          ntxdaveN 1 Reply Last reply
                                          • ntxdaveN
                                            ntxdave @Dave R
                                            @Dave-R I thought so and have had it installed for a while. If you look at this screen shot you will see that I had it placed on my toolbar.
                                            Also, If you look at the image from the SketchUp Extension Manager, you will see that I had a license.
                                            • 108
                                            • 109
                                            • 110
                                            • 111
                                            • 112
                                            • 115
                                            • 116
                                            • 110 / 116
