    2.3k Posts 515 Posters 2.1m Views 520 Watching
      Rich O Brien Moderator @Christel Chenot
      @Christel-Chenot said in SCFLicense: Extension Licensing on Sketchucation:
      Is it possible to contact Fredo06?
      @fredo6 gets his attention.
      C 1 Reply Last reply 👍 Reply Quote 0
      • fredo6F Offline
        Sorry, there may be a problem.
        Could you give more information on your set up. Just invoke the menu Window > LibFredo6 Settings... > Fredo6 Plugin Information for Sketchucation Support, copy/paste the output of the Ruby Console here. Thanks.
        C 1 Reply Last reply Reply Quote 0
          Christel Chenot @Rich O Brien
          @Rich-O-Brien Hello, i made it in my french text 😉 Thank You
            Christel Chenot @fredo6
            @fredo6
            Hello,
            Thank you for your response and follow-up.
            Here is the requested informations.
            Have a nice day.
            Bonjour @fredo6
            Merci pour votre réponse et votre suivi.
            Voici les informations demandées.
            Belle journée
            Fredo6 Plugins Information on 2025-12-09 19:06:23 +0100
            • Sketchup: 26.0.429
            • LibFredo6: v15.6b
            • LibFredo6 Binary loaded
            • Sketchucation ExtensionStore: 4.4.1
            • SCFLicense: v6.4a - 74
            • Fredo6 Plugins
              Curviloft v2.0a
              FredoScale v3.6a - licensed FULL
              FredoTools v4.3a
              JointPushPull v4.9a
              RoundCorner v3.4a
              ThruPaint v2.8d
              Signature File: 2025-11-27 12:04:58 +0100
              FredoScale: 2025-11-27 12:44:06 +0100
              jemoavi14 Newcomers @fredo6
              @fredo6 Hola Fredo, intento entrar al link y no me deja, tengo un proyecto y quiero comprar la licencia
                Christel Chenot
                Thanks to Fredo6 for the sending solution 🙂 - Solved
                Merci à @fredo6 pour la solution qui m'a été envoyée 🙂 - Résolu
                  Mvmcneil
                  Hi I just purchased the 8 bundle licenses. But for some reason, when I go to activate Roundcorner with the downloaded license file, the plug-in doesn't see the file. It was doing the same with JointPushpull but then the file showed up for that plug-in but still not for Roundcorner. Any tips to make this read the file? I downloaded the license files several times and unblocked them.
                    Are you sure you are trying to activate RoundCorner and not Fredo Corner?
                    M 1 Reply Last reply Reply Quote 0
                      Mvmcneil @Dave R
                      @Dave-R
                      Ah yes my bad. It was Fredo Corner not RoundCorner.
                      Dave RD 1 Reply Last reply 👍 Reply Quote 0
                        Dave R @Mvmcneil
                        @Mvmcneil ahh ... Good that you got it sorted. Two different extensions and two different licenses. Both a good to have, though.
                          bentaclas
                          i need to buy license for animator.....how to purchase it...please reply me
                          G 1 Reply Last reply Reply Quote 0
                            Gábor @bentaclas
                            @bentaclas Log in to SketchUcation.com. Go to URL: https://sketchucation.com/purchase-smart.php?plugin=Animator
                            Press the "Buy Now" button
                              alexnegru1234
                              Hello can someone help me with solving this error please?
                                First you need to update your extensions because License Version 6.4a-74 is outdated.
                                Please upgrade Sketchucation Tools: https://sketchucation.com/plugin/696-sketchucationtools
                                Please upgrade Libfredo: https://sketchucation.com/pluginstore?pln=LibFredo6
                                Regarding your error message you need to whitelist *.sketchucation.com on your network or switch to a less strict network.
                                  DWH88
                                  [Success] How to purchase and activate the Animator SCF License in SketchUp Make 2017
                                  Hi everyone,
                                  I just wanted to share a quick guide for anyone still using SketchUp Make 2017. I successfully purchased and activated the SCF License for Animator. Since the "Purchase" button isn't always easy to find on the website, here is the method that worked for me:
                                  Prerequisites:
                                  Make sure you have the latest versions of SketchUcation Tools, LibFredo6, and Animator installed.
                                  Step 1: Purchase the License via SketchUp (Recommended)
                                  This method is the safest because it redirects you to the exact correct page in the shop.
                                  Install the plugins mentioned above.
                                  Open SketchUp 2017.
                                  Go to the menu: Tools > Fredo6 Collection > Animator > License...
                                  In the window that opens, click the button "Obtain License".
                                  This will open your web browser directly to the correct purchase page for the plugin.
                                  Purchase the license and download the .scflicense file to your computer.
                                  Step 2: Activate the License
                                  Now connect the downloaded file to the plugin in SketchUp.
                                  Open SketchUp 2017 again.
                                  Go to Tools > Fredo6 Collection > Animator > License...
                                  (Note: If the "License..." menu item is missing, your LibFredo6 or SketchUcation Tools version is likely outdated).
                                  Click on "Validate License".
                                  Browse for the .scflicense file you downloaded in Step 1 and select it.
                                  The system will do a quick online check. Afterwards, you should see a green checkmark with the status "Active".
                                  I hope this helps other Make 2017 users!
                                    kavi priyan Newcomers
                                    can you give me the trail pack of curviloft
                                      Dave R @kavi priyan
                                      @kavi-priyan install the Sketchucation ExtensionStore and use it to search for and install LibFredo6 and Curviloft. There's a 30-day trial period for Curviloft. After the 30 days you can purchase the license if you wish to continue using it.
                                      • Z Offline
                                        ZMD
                                        hi, i purchased the roundcorner perpetual liscense about two years ago. I am getting pop ups when i try to use it now stating that my trial period is over. Ive been going in circles trying to verify/update to the latest version of sketchucation with no clear path/luck. in my extension manager, the fredo 6 round corner extension ios signed and enabled....
                                        HELP A BROTHA OUT 🙂
                                          @zmd make sure all your extensions are the latest releases.
                                          If they are please share the error messages you are getting so we have something to chew on
                                            @zmd
                                            Also make sure you have the latest SketchUcation toolset installed for the licensing etc [>=5.0.5], it's version is shown in the top bar of its dialog.
                                            If you update it restart SketchUp to sync everything...
                                            As well as the latest versions of Fredo's extensions ensure you have his latest LibFredo6 too...
                                            PS. Don't confuse Fredo's RoundCorner and FredoCorner extensions, they are separate tools, each needing their own license...
                                            PPS. The current toolset requires >v2017 - what's yours ?
                                            • 107
                                            • 108
                                            • 109
                                            • 110
                                            • 111
                                            • 115
                                            • 116
                                            • 109 / 116
