    2.3k Posts 515 Posters 2.3m Views 520 Watching
      jemoavi14 Newcomers @fredo6
      @fredo6 Hola Fredo, intento entrar al link y no me deja, tengo un proyecto y quiero comprar la licencia
        Christel Chenot
        Thanks to Fredo6 for the sending solution 🙂 - Solved
        Merci à @fredo6 pour la solution qui m'a été envoyée 🙂 - Résolu
          Mvmcneil
          Hi I just purchased the 8 bundle licenses. But for some reason, when I go to activate Roundcorner with the downloaded license file, the plug-in doesn't see the file. It was doing the same with JointPushpull but then the file showed up for that plug-in but still not for Roundcorner. Any tips to make this read the file? I downloaded the license files several times and unblocked them.
            Are you sure you are trying to activate RoundCorner and not Fredo Corner?
            M 1 Reply Last reply Reply Quote 0
              Mvmcneil @Dave R
              @Dave-R
              Ah yes my bad. It was Fredo Corner not RoundCorner.
              Dave RD 1 Reply Last reply 👍 Reply Quote 0
                Dave R @Mvmcneil
                @Mvmcneil ahh ... Good that you got it sorted. Two different extensions and two different licenses. Both a good to have, though.
                  bentaclas
                  i need to buy license for animator.....how to purchase it...please reply me
                  G 1 Reply Last reply Reply Quote 0
                    Gábor @bentaclas
                    @bentaclas Log in to SketchUcation.com. Go to URL: https://sketchucation.com/purchase-smart.php?plugin=Animator
                    Press the "Buy Now" button
                      alexnegru1234
                      Hello can someone help me with solving this error please?
                        First you need to update your extensions because License Version 6.4a-74 is outdated.
                        Please upgrade Sketchucation Tools: https://sketchucation.com/plugin/696-sketchucationtools
                        Please upgrade Libfredo: https://sketchucation.com/pluginstore?pln=LibFredo6
                        Regarding your error message you need to whitelist *.sketchucation.com on your network or switch to a less strict network.
                          DWH88
                          [Success] How to purchase and activate the Animator SCF License in SketchUp Make 2017
                          Hi everyone,
                          I just wanted to share a quick guide for anyone still using SketchUp Make 2017. I successfully purchased and activated the SCF License for Animator. Since the "Purchase" button isn't always easy to find on the website, here is the method that worked for me:
                          Prerequisites:
                          Make sure you have the latest versions of SketchUcation Tools, LibFredo6, and Animator installed.
                          Step 1: Purchase the License via SketchUp (Recommended)
                          This method is the safest because it redirects you to the exact correct page in the shop.
                          Install the plugins mentioned above.
                          Open SketchUp 2017.
                          Go to the menu: Tools > Fredo6 Collection > Animator > License...
                          In the window that opens, click the button "Obtain License".
                          This will open your web browser directly to the correct purchase page for the plugin.
                          Purchase the license and download the .scflicense file to your computer.
                          Step 2: Activate the License
                          Now connect the downloaded file to the plugin in SketchUp.
                          Open SketchUp 2017 again.
                          Go to Tools > Fredo6 Collection > Animator > License...
                          (Note: If the "License..." menu item is missing, your LibFredo6 or SketchUcation Tools version is likely outdated).
                          Click on "Validate License".
                          Browse for the .scflicense file you downloaded in Step 1 and select it.
                          The system will do a quick online check. Afterwards, you should see a green checkmark with the status "Active".
                          I hope this helps other Make 2017 users!
                            kavi priyan Newcomers
                            can you give me the trail pack of curviloft
                              Dave R @kavi priyan
                              @kavi-priyan install the Sketchucation ExtensionStore and use it to search for and install LibFredo6 and Curviloft. There's a 30-day trial period for Curviloft. After the 30 days you can purchase the license if you wish to continue using it.
                              • Z Offline
                                ZMD
                                hi, i purchased the roundcorner perpetual liscense about two years ago. I am getting pop ups when i try to use it now stating that my trial period is over. Ive been going in circles trying to verify/update to the latest version of sketchucation with no clear path/luck. in my extension manager, the fredo 6 round corner extension ios signed and enabled....
                                HELP A BROTHA OUT 🙂
                                  @zmd make sure all your extensions are the latest releases.
                                  If they are please share the error messages you are getting so we have something to chew on
                                    @zmd
                                    Also make sure you have the latest SketchUcation toolset installed for the licensing etc [>=5.0.5], it's version is shown in the top bar of its dialog.
                                    If you update it restart SketchUp to sync everything...
                                    As well as the latest versions of Fredo's extensions ensure you have his latest LibFredo6 too...
                                    PS. Don't confuse Fredo's RoundCorner and FredoCorner extensions, they are separate tools, each needing their own license...
                                    PPS. The current toolset requires >v2017 - what's yours ?
                                    • ntxdaveN Offline
                                      ntxdave
                                      I keep getting this message
                                      If I go to the Extension Manager here is what I see:
                                      If I go to the SketchUcation Tools here is what I see:
                                      Notice item 13.
                                      NOt sure whatr I need to do to get the license updated.
                                      Press F1...thank me later
                                        Go to https://sketchucation.com/webshop/my-licences.php
                                        Download your license file
                                        Open SketchUp
                                        Go to Tools > Fredo Collection > FredoSketch > License
                                        Click Activate and pick your downloaded license file
                                        • ntxdaveN Offline
                                          ntxdave
                                          OK, When I go to the licenses link you provided, I am not seeing the FredoSketch license so I cannot download it.
                                            Dave R @ntxdave
                                            @ntxdave said in SCFLicense: Extension Licensing on Sketchucation:
                                            Did you purchase a license for FredoSketch?
                                            • 108
                                            • 109
                                            • 110
                                            • 111
                                            • 112
                                            • 115
                                            • 116
                                            • 110 / 116
