    2.3k Posts 517 Posters 3.0m Views 522 Watching
      Rich O Brien Moderator @ethansatsky
      @ethansatsky
      Yeah, I can confirm there is a hiccup. Give us a few mins to look into it.
        @ethansatsky
        Can you try again please?
          dmsone
          Hello, I purchased the "round corner" license, installed the latest Fredo6, and Sketchucation. When I press the round corner plugin button, nothing happens. Appreciate any help or advice.
          A 1 Reply Last reply
            Anne O Grady @dmsone
            @dmsone
            Hi there - when I look at the license it appears that it has been activated. Could you send me a screenshot of this issue to support@sketchucation.com and I can help you from there.
            Anne
            • N
              nebhamzah
              Hi can anyone guide me on how to release license seats? I have gone to sketchucation>global license status but nothing come up. but if i checked under my license page i have all the plugins i have purchased with number of seats linked to it. i need to unlink some as im not using that computer anymore.
                With the latest versions of the SketchUcation tools installed you should see the options on our web page or in one of the settings tabs in the ExtensionStore dialog ?
                If not Rich will probably be able to do something via admin...
                  @nebhamzah
                  Releasing seats at My Licenses
                  • C
                    Christel Chenot
                    Hello,
                    I'm trying to use Thrupaint2 by Fredo06, which indicates that my trial license expired in 2021. However, I don't recall having used this extension before. Would it be possible to obtain a history or correct this date error? Thank you in advance, have a nice day.
                    Bonjour,
                    J'essaye d'utiliser Thrupaint2 de Fredo06 qui indique que ma licence d'essai a expiré en 2021. Or, il ne me semble pas avoir déjà utilisé cette extension précédémment. Serait-ce possible d'obtenir un historique ou de corriger cette erreur de date ? Merci d'avance, belle journée
                      Rich O Brien Moderator @Christel Chenot
                      @Christel-Chenot said in SCFLicense: Extension Licensing on Sketchucation:
                      ThruPaint was originally free and got a major update and went commercial.
                      I believe v1 is still in FredoTools
                      1 Reply Last reply 👍
                      • C
                        Christel Chenot
                        Hello @Rich-O-Brien
                        Thank you for your reply.
                        Indeed, but Thrupaint 2 has been on the market since 2023, yet my error message indicates that the trial period ended in December 2021.
                        I've never used Thrupaint 2, and I don't understand why the 30-day trial isn't working.
                        Is it possible to contact Fredo06? (Perhaps this isn't the right forum section for my question?)
                        Thank You 🙂
                        Bonjour Rich O'Brien,
                        Merci pour cette réponse.
                        En effet, mais Thrupaint 2 est commercialisé depuis 2023, or mon message d'erreur indique que la période d'essai est terminée depuis Décembre 2021.
                        Je n'ai jamais utilisé Thrupaint 2, je ne comprends pas pourquoi l'essai de 30 jours ne fonctionne pas.
                        Est-il possible de contacter @fredo6 ? (peut-être n'est-ce pas le bon endroit du forum pour ma question ? )
                        Merci 🙂
                          @fredo6 gets his attention.
                          C 1 Reply Last reply 👍
                          • fredo6F
                            Sorry, there may be a problem.
                            Could you give more information on your set up. Just invoke the menu Window > LibFredo6 Settings... > Fredo6 Plugin Information for Sketchucation Support, copy/paste the output of the Ruby Console here. Thanks.
                            • C
                              Christel Chenot @Rich O Brien
                              @Rich-O-Brien Hello, i made it in my french text 😉 Thank You
                              • C
                                Christel Chenot @fredo6
                                @fredo6
                                Hello,
                                Thank you for your response and follow-up.
                                Here is the requested informations.
                                Have a nice day.
                                Bonjour @fredo6
                                Merci pour votre réponse et votre suivi.
                                Voici les informations demandées.
                                Belle journée
                                Fredo6 Plugins Information on 2025-12-09 19:06:23 +0100
                                • Sketchup: 26.0.429
                                • LibFredo6: v15.6b
                                • LibFredo6 Binary loaded
                                • Sketchucation ExtensionStore: 4.4.1
                                • SCFLicense: v6.4a - 74
                                • Fredo6 Plugins
                                  Curviloft v2.0a
                                  FredoScale v3.6a - licensed FULL
                                  FredoTools v4.3a
                                  JointPushPull v4.9a
                                  RoundCorner v3.4a
                                  ThruPaint v2.8d
                                  Signature File: 2025-11-27 12:04:58 +0100
                                  FredoScale: 2025-11-27 12:44:06 +0100
                                  jemoavi14 Newcomers @fredo6
                                  @fredo6 Hola Fredo, intento entrar al link y no me deja, tengo un proyecto y quiero comprar la licencia
                                  • C
                                    Christel Chenot
                                    Thanks to Fredo6 for the sending solution 🙂 - Solved
                                    Merci à @fredo6 pour la solution qui m'a été envoyée 🙂 - Résolu
                                      Mvmcneil
                                      Hi I just purchased the 8 bundle licenses. But for some reason, when I go to activate Roundcorner with the downloaded license file, the plug-in doesn't see the file. It was doing the same with JointPushpull but then the file showed up for that plug-in but still not for Roundcorner. Any tips to make this read the file? I downloaded the license files several times and unblocked them.
                                        Are you sure you are trying to activate RoundCorner and not Fredo Corner?
                                        M 1 Reply Last reply
                                          Mvmcneil @Dave R
                                          @Dave-R
                                          Ah yes my bad. It was Fredo Corner not RoundCorner.
                                          Dave RD 1 Reply Last reply 👍
                                            Dave R @Mvmcneil
                                            @Mvmcneil ahh ... Good that you got it sorted. Two different extensions and two different licenses. Both a good to have, though.
                                            • 107
                                            • 108
                                            • 109
                                            • 110
                                            • 111
                                            • 115
                                            • 116
                                            • 109 / 116
