    [Plugin] Pic2Shape - v1.3a - 17 Dec 25 (Image Contouring)
    31 Posts 12 Posters 7.3k Views 13 Watching
      That suggests you either haven't installed Libfredo or you have not restarted SketchUp. But since you are omitting lots of info to help us understand fully its hard to say.
      • fredo6F Offline
        NEW RELEASE: Pic2Shape v1.2a - 13 Oct 25
        Requirements
        • LibFredo6: v15.2a or above
        • Sketchup version: SU2018 and above
        Pic2Shape 1.2a is a maintenance release including:
        • Bug fixing
        Home Page of Pic2Shape for information and Download.
        Main post of this Pic2Shape thread.
        • fredo6F Offline
          NEW RELEASE: Pic2Shape v1.2b - 13 Oct 25
          Requirements
          Pic2Shape 1.2b is a maintenance release including:
          • Bug fixing (one remaining from Pic2Shape v1.2a)
          • TutorialsUpT Offline
            TutorialsUp
            Amazing tool! Thanks, Fredo 😍
            Just uploaded a new tutorial on YouTube!
            • V Offline
              VR123 Newcomers
              Hello, this is an amazing tool—thank you very much. I use it mainly for landscape architecture to create plant shadows. I was wondering why the tool doesn't work with some plants. Quite a lot of plants don't work with this tool; for example, grasses, slightly blue plants, and delicate trees (like the tamarisk tree) seem to produce an open contour which creates a ghost image. I tried editing the PNG and adding a contour or changing the contrast in Photoshop—even adding a very dark black line—and changing the settings of the tool, but nothing seems to work. I wonder if you could have a look at that. I will upload some examples of plants that just don't work with the tool.
              ex grass.
              https://stock.adobe.com/uk/search?k=nassella+tenuissima&search_type=usertyped&asset_id=1758902289
              Tamarix trees:
              adobe.com
              (stock.adobe.com)
              adobe.com
              (stock.adobe.com)
              • fredo6F Offline
                The herbs are to thin to be valuably contoured by Pic2Shape.
                Again, you can do proper contouring in specialized software like PhotoShop. Pic2Shape is only there for simple shapes.
                • Z Offline
                  ZG53 Newcomers @fredo6
                  I use Sketchup 2022 with Twilight render 2.0 Pro. A few days ago I upgraded LibFredo6 and PictoShape to the latest version, After that it started to go bad, the Shapes on the images I make with face to camera after rendering are black (as with the alpha mask), while the imported images in png format without PictoShape are visible OK after rendering.
                  After rendering in the attached image
                  Left shape - obtained from png imported image after PiCtoShape
                  Right shape - imported png and "raised" by 90°
                    We are a bit under informed...
                    If you post the actual tree PNG image it might help resolve this...
                    Z 1 Reply Last reply Reply Quote 0
                    • Z Offline
                      ZG53 Newcomers @TIG
                      @TIG
                      SU image.jpg Render image.jpg cut out Trees pack_5 (24).PNG cut out Trees pack_5 (19).PNG
                        Your PNG processed fine for me.
                        Although there are a lot of semi-transparent pixels that could be improved by editing the image [Gimp].
                        I flattened the image which remove all transparency, then I selected all of the 'teal' background pixels with the magic-wand, and deleted them... and finally added the alpha channel back in. This takes longer to process, but it gives a much better result. Also cropping the image to avoid bothering with all of the background you don't want anyway speeds things up.
                          • fredo6F Offline
                            NEW RELEASE: Pic2Shape v1.3a - 17 Dec 25
                            Requirements
                            • LibFredo6: v15.6a or above
                            Pic2Shape 1.3a is a maintenance release including:
                            • Extension of validity
                            • N Offline
                              nabilyon1992 Newcomers
                              • 2 / 2
