    [Plugin] Pic2Shape - v1.3a - 17 Dec 25 (Image Contouring)
    45 Posts 15 Posters 12.2k Views 16 Watching
      schramdesigns
      I installed Fredo6 Pic2Shape but can not find it anywhere to use it. What gives?
        Rich O Brien Moderator @schramdesigns
        @schramdesigns Have you met the requirements in the top post?
          schramdesigns
          I installed this and cant find it to use it.
            That suggests you either haven't installed Libfredo or you have not restarted SketchUp. But since you are omitting lots of info to help us understand fully its hard to say.
            • fredo6F
              NEW RELEASE: Pic2Shape v1.2a - 13 Oct 25
              Requirements
              • LibFredo6: v15.2a or above
              • Sketchup version: SU2018 and above
              Pic2Shape 1.2a is a maintenance release including:
              • Bug fixing
              Home Page of Pic2Shape for information and Download.
              Main post of this Pic2Shape thread.
              1 Reply Last reply 👍
              • fredo6F
                NEW RELEASE: Pic2Shape v1.2b - 13 Oct 25
                Requirements
                Pic2Shape 1.2b is a maintenance release including:
                • Bug fixing (one remaining from Pic2Shape v1.2a)
                Reply Quote 2
                • TutorialsUpT
                  TutorialsUp
                  Amazing tool! Thanks, Fredo 😍
                  Just uploaded a new tutorial on YouTube!
                  Reply Quote 2
                  • V
                    VR123 Newcomers
                    Hello, this is an amazing tool—thank you very much. I use it mainly for landscape architecture to create plant shadows. I was wondering why the tool doesn't work with some plants. Quite a lot of plants don't work with this tool; for example, grasses, slightly blue plants, and delicate trees (like the tamarisk tree) seem to produce an open contour which creates a ghost image. I tried editing the PNG and adding a contour or changing the contrast in Photoshop—even adding a very dark black line—and changing the settings of the tool, but nothing seems to work. I wonder if you could have a look at that. I will upload some examples of plants that just don't work with the tool.
                    ex grass.
                    https://stock.adobe.com/uk/search?k=nassella+tenuissima&search_type=usertyped&asset_id=1758902289
                    Tamarix trees:
                    adobe.com
                    (stock.adobe.com)
                    adobe.com
                    (stock.adobe.com)
                    • fredo6F
                      The herbs are to thin to be valuably contoured by Pic2Shape.
                      Again, you can do proper contouring in specialized software like PhotoShop. Pic2Shape is only there for simple shapes.
                      • Z
                        ZG53 Newcomers @fredo6
                        I use Sketchup 2022 with Twilight render 2.0 Pro. A few days ago I upgraded LibFredo6 and PictoShape to the latest version, After that it started to go bad, the Shapes on the images I make with face to camera after rendering are black (as with the alpha mask), while the imported images in png format without PictoShape are visible OK after rendering.
                        After rendering in the attached image
                        Left shape - obtained from png imported image after PiCtoShape
                        Right shape - imported png and "raised" by 90°
                          We are a bit under informed...
                          If you post the actual tree PNG image it might help resolve this...
                          Z 1 Reply Last reply
                          • Z
                            ZG53 Newcomers @TIG
                            @TIG
                            SU image.jpg Render image.jpg cut out Trees pack_5 (24).PNG cut out Trees pack_5 (19).PNG
                              Your PNG processed fine for me.
                              Although there are a lot of semi-transparent pixels that could be improved by editing the image [Gimp].
                              I flattened the image which remove all transparency, then I selected all of the 'teal' background pixels with the magic-wand, and deleted them... and finally added the alpha channel back in. This takes longer to process, but it gives a much better result. Also cropping the image to avoid bothering with all of the background you don't want anyway speeds things up.
                                • fredo6F
                                  NEW RELEASE: Pic2Shape v1.3a - 17 Dec 25
                                  Requirements
                                  • LibFredo6: v15.6a or above
                                  Pic2Shape 1.3a is a maintenance release including:
                                  • Extension of validity
                                  • N
                                    nabilyon1992 Newcomers
                                    • T
                                      tilo mar tin
                                      Anybody have the 1.1 rbz old version to pass me?
                                      Dave RD 1 Reply Last reply
                                        Dave R @tilo mar tin
                                        @tilo-mar-tin why do you need v 1.1 of this extension?
                                        • KrassK
                                          Krass
                                          Un immense merci, je viens de voir une application étonnante de ton plug-in où on voit que ça prendrait en compte le mapping en 3 d à partir des images. Je vais essayer demain chez moi, mais suis bluffé encore une fois par ton travail
                                          Je parle de cette image
                                          Krass
                                          • KrassK
                                            Krass
                                            Hello,
                                            It’s really excellent. However, when I tried again this morning, it got stuck at the same point with this image. I even reduced the image resolution to 500 pixels, but the result is the same. Is there any setting I could adjust to improve speed or get past this block?
                                            Krass
                                            • 2 / 3
