    [Plugin] Pic2Shape - v1.3a - 17 Dec 25 (Image Contouring)
    31 Posts 12 Posters 8.1k Views 13 Watching
    • fredo6F Offline
      Please do it and report.
      DXF conversion is likely to give better results.
      • kimgaK Offline
        kimga
        I was about to try this extension out - using SketchUp 2025 Pro, but the extension doesn’t seem to process the image. Image size 155x50 mm / 300 pixel/inch.
        After 10 minutes still at Initialization…
        Is there any guideline on max/ recommended picture size?
        I tried it with a smaller resolution image, but I still can not get through Initialization....
        Thank you
        • kimgaK Offline
          kimga
          update: I succeeded with the plugin, when I opened the image in a new file.
          The original image was on a bent plane. I suppose that was the problem…
          R N 2 Replies Last reply Reply Quote 0
            rv1974 @kimga
            @kimga Are you going to to have trees with this amount of edges per leaf ) ?
            • N Offline
              nasmrtcz @kimga
              @kimga @TIG Hi. I also have this issue. It works really great in the picture, but after applying it on a textured face, it freezes like the leaf.
              • fredo6F Offline
                Do you have the model for me to explore the issue.
                  schramdesigns
                  I installed Fredo6 Pic2Shape but can not find it anywhere to use it. What gives?
                    Rich O Brien Moderator @schramdesigns
                    @schramdesigns Have you met the requirements in the top post?
                      schramdesigns
                      I installed this and cant find it to use it.
                        That suggests you either haven't installed Libfredo or you have not restarted SketchUp. But since you are omitting lots of info to help us understand fully its hard to say.
                        • fredo6F Offline
                          NEW RELEASE: Pic2Shape v1.2a - 13 Oct 25
                          Requirements
                          • LibFredo6: v15.2a or above
                          • Sketchup version: SU2018 and above
                          Pic2Shape 1.2a is a maintenance release including:
                          • Bug fixing
                          Home Page of Pic2Shape for information and Download.
                          Main post of this Pic2Shape thread.
                          • fredo6F Offline
                            NEW RELEASE: Pic2Shape v1.2b - 13 Oct 25
                            Requirements
                            Pic2Shape 1.2b is a maintenance release including:
                            • Bug fixing (one remaining from Pic2Shape v1.2a)
                            • TutorialsUpT Offline
                              TutorialsUp
                              Amazing tool! Thanks, Fredo 😍
                              Just uploaded a new tutorial on YouTube!
                              • V Offline
                                VR123 Newcomers
                                Hello, this is an amazing tool—thank you very much. I use it mainly for landscape architecture to create plant shadows. I was wondering why the tool doesn't work with some plants. Quite a lot of plants don't work with this tool; for example, grasses, slightly blue plants, and delicate trees (like the tamarisk tree) seem to produce an open contour which creates a ghost image. I tried editing the PNG and adding a contour or changing the contrast in Photoshop—even adding a very dark black line—and changing the settings of the tool, but nothing seems to work. I wonder if you could have a look at that. I will upload some examples of plants that just don't work with the tool.
                                ex grass.
                                https://stock.adobe.com/uk/search?k=nassella+tenuissima&search_type=usertyped&asset_id=1758902289
                                Tamarix trees:
                                https://stock.adobe.com/uk/search?filters[content_type%3Aphoto]=1&filters[content_type%3Aillustration]=1&filters[content_type%3Azip_vector]=1&filters[content_type%3Avideo]=1&filters[content_type%3Atemplate]=1&filters[content_type%3A3d]=1&filters[content_type%3Aimage]=1&k=tamarix+png&order=relevance&limit=100&search_page=1&search_type=usertyped&acp=&aco=tamarix+png&get_facets=0&asset_id=1718113607
                                https://stock.adobe.com/uk/search?filters[content_type%3Aphoto]=1&filters[content_type%3Aillustration]=1&filters[content_type%3Azip_vector]=1&filters[content_type%3Avideo]=1&filters[content_type%3Atemplate]=1&filters[content_type%3A3d]=1&filters[content_type%3Aimage]=1&k=tamarix+png&order=relevance&limit=100&search_page=1&search_type=usertyped&acp=&aco=tamarix+png&get_facets=0&asset_id=1732430083
                                • fredo6F Offline
                                  The herbs are to thin to be valuably contoured by Pic2Shape.
                                  Again, you can do proper contouring in specialized software like PhotoShop. Pic2Shape is only there for simple shapes.
                                  • Z Offline
                                    ZG53 Newcomers @fredo6
                                    I use Sketchup 2022 with Twilight render 2.0 Pro. A few days ago I upgraded LibFredo6 and PictoShape to the latest version, After that it started to go bad, the Shapes on the images I make with face to camera after rendering are black (as with the alpha mask), while the imported images in png format without PictoShape are visible OK after rendering.
                                    After rendering in the attached image
                                    Left shape - obtained from png imported image after PiCtoShape
                                    Right shape - imported png and "raised" by 90°
                                      We are a bit under informed...
                                      If you post the actual tree PNG image it might help resolve this...
                                      Z 1 Reply Last reply Reply Quote 0
                                      • Z Offline
                                        ZG53 Newcomers @TIG
                                        @TIG
                                        SU image.jpg Render image.jpg cut out Trees pack_5 (24).PNG cut out Trees pack_5 (19).PNG
                                          Your PNG processed fine for me.
                                          Although there are a lot of semi-transparent pixels that could be improved by editing the image [Gimp].
                                          I flattened the image which remove all transparency, then I selected all of the 'teal' background pixels with the magic-wand, and deleted them... and finally added the alpha channel back in. This takes longer to process, but it gives a much better result. Also cropping the image to avoid bothering with all of the background you don't want anyway speeds things up.
