    Rayscaper New Releases
    rayscaperrender
    466 Posts 12 Posters 207.0k Views 13 Watching
      Mike Amos @pixelcruncher
      @pixelcruncher
      Oh well, that lasted a long time did it not.
      I cannot run Rayscaper, it is installed but, when I start the app the !render! window will not open.
      All this happened post a diffusion update.
      Report below.
      Extension Errors Report
      SketchUp: 24.0.594
      OS: Windows 11
      Ruby: 3.2.2
      Extension: SketchUp Diffusion (1.2025.09.28)
      Error: LoadError (127: The specified procedure could not be found. - C:/Users/mike1/AppData/Local/Temp/SketchUpDiffusion.so)
      <internal:C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' <internal:C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require'
      c:/users/mike1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/su_diffusion/su_loader.rbe:28:in <module:SketchUpDiffusion>' c:/users/mike1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/su_diffusion/su_loader.rbe:1:in <main>'
      C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in eval' C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in require'
      C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in load' C:/Users/mike1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/su_diffusion.rb:21:in register_extension'
      C:/Users/mike1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/su_diffusion.rb:21:in <module:SketchUpDiffusion>' C:/Users/mike1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/su_diffusion.rb:5:in <top (required)>'
      • KrassK Offline
        Krass
        Hello, Pixelcruncher,
        I'have installed RS 9.6.9
        I'm testing it. When I hide a SU tag it stays visible. The only way seems to Hide a group so that it will not be visible. So: we can't use Hide/reveal Tags?
        Krass
          Going cold turkey, sketchup is completely uninstalled for a while.
          • KrassK Offline
            Krass
            This time I have a scene that is a bit heavy, I copied an entire apartment in duplicate and when I open RS, it is active but the window does not want to enlarge and remains stuck in the taskbar. We can see in the thumbnail that it is working on the project, it is rendering... but I also did not have a Rayscaper loading window
            Krass
            • KrassK Offline
              Krass
              The latest version is broken for me... I installed it and I don't think I restarted SU and it worked. But now the window is stuck in the taskbar;
              I'm going to reinstall 9.6.4 to test.
              Krass
              • KrassK Offline
                Krass
                Ok, rayscaper is back if I use 9.6.4
                Krass
                  Need a revert version button.
                    sashapepperspray @pixelcruncher
                    @pixelcruncher any update on when the material inheritance is going to be fixed?
                    • KrassK Offline
                      Krass
                      Hello, pictures of another apartment I would like to buy, I prefer this one. the exterior is made up, it's the hdri map. but the view is really nice in truth. Rayscaper render Magnfic Upscale
                      Krass
                        Can someone post the .9.6.4 build please, da nada here.
                          OK, hover the cursor over the sketchup icon on the task bar, right click on the Rayscaper window and maximise. The render window will not open elsewise.
                            Mike Amos @Mike Amos
                            Running the .69 build. EVERY new model loaded will require the steps above. right click on the render window on the task bar and select maximise. When this is done once per new model, session, each new start of Rayscaper will occur as per normal.5 1000s 2196 x 1071 GPU 2020016 tri 54s.png
                            • KrassK Offline
                              Krass
                              Thanks Mike, I'will test your tip. here is the 9.6.4 version, tell me when your download is ok, I will delete the file:
                              https://www.swisstransfer.com/d/698b91bc-e0e6-4fc5-8434-9b06ef0571f7
                              Krass
                                Done, I thank you Sir.
                                  Hey folks,
                                  Sorry for the late replies. It was a bad weekend to go on a trip. πŸ˜• β€” I assumed that the build I posted fixed the crash just before I left. Will post an updated build here ASAP.
                                  Will try to do that in the release after this one. The next one will be a hotfix for the crashes users encountered.
                                  Agreed, but it's not that simple to do with a SketchUp extension. I will make downloads of older releases available on the Rayscaper website. Stay tuned.
                                  Thanks for the workaround. I will fix it.
                                  Cheers,
                                  Thomas
                                  S 1 Reply Last reply πŸ™ Reply Quote 2
                                  • KrassK Offline
                                    Krass
                                    Thanks PixC. Good luck
                                    Krass
                                      I never doubted you would. My first thought was the Diffusion update seeing as that was the last thing to happen prior to the issue presenting.
                                      Conflict with Diffusion?
                                        Just so you know Mr Cruncher, Sir.
                                        When you get the chance to get away from the rat race, ANY weekend is a good time to do so. You Sir, are worth it. In a very poor paraphrasing of the advertisement.
                                          @pixelcruncher thank you
                                            Hey, Rayscaper users!
                                            Rayscaper 0.9.72 Beta is available. You can get it via the SketchUcation store.
                                            I recommend upgrading to the latest version.
                                            What Changed?
                                            • Rayscaper now supports direct integration with the Skatter plugin. Render-only Skatter data can now be ingested directly from Skatter, bypassing the
                                              SketchUp viewport. This offloads complex instancing and geometry handling to Rayscaper, keeping SketchUp responsive and lightweight during rendering.
                                              Perfect for large vegetation or scattering setups β€” just hit render and let Rayscaper handle the heavy lifting. (@ntxdave Thanks for connecting me with the Skatter people).
                                            • Bugfix: push/pull geometry would not properly propagate to Rayscaper.
                                            • Fix Rayscaper for SketchUp 2024, caused by a breaking change in the SketchUp SDK. Note: Going forward, Rayscaper will only support the latest three
                                              SketchUp releases because now that it's for sure that the SDK is not backwards compatible, it's too much overhead for me to maintain more versions. The
                                              current version supports: SketchUp 2026, SketchUp 2025 & SketchUp 2024.
                                            • Make materials assigned to a SketchUp group or component instance work again. cc: @sashapepperspray
                                            Here's a screenshot of a simple forest I created using Skatter:
                                            Help Me Build the Community πŸ‘
                                            If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its capabilities
                                            to new users.
                                            Follow me on https://x.com/rayscaper3d.
                                            Happy Rendering!
                                            Thomas
                                            • 11
                                            • 12
                                            • 13
                                            • 23
                                            • 24
                                            • 11 / 24
