    Rayscaper New Releases
    rayscaperrender
    744 Posts 14 Posters 317.8k Views 15 Watching
    • KrassK
      Krass
      Yes! Indeed
      Krass
      • pixelcruncherP
        Hey guys,
        Looking into the crashes.
        Hello, if I leave Rayscaper open and import a texture directly onto a face (with the import tool) it crashes
        Was this on the first texture, or after multiple imports?
        I can't create an emissive material with an image, if I increase the power the image disappears and the texture is white. I can't make a monitor screen. Can someone help me?
        Currently, Rayscaper doesn't support emission with a texture. Which image are you talking about? Maybe a screenshot of your setup helps me understand it better.
        Another crash when reopening RS and trying to apply a texture
        Looking into the crashes, I think (I hope) I found the root cause.
        I understand the frustrations, and I appreciate your help in making the software a lot better!
        Cheers,
        Thomas
        KrassK 1 Reply Last reply
        • KrassK
          Krass @pixelcruncher
          Nice render Mike!
          @pixelcruncher said in Rayscaper New Releases:
          I created a surface and imported a texture
          I found a solution to make an image emissive: for example for PC screens on the following images I make a copy of the face that must receive the image and I place it in front 2 or 3 millimeters of the initial face to which I applied an emissive. On this copy of the face I put my image as texture and I increase the Transmission slider, and it works well. (I just discovered this feature!)
          ci-dessous 3 rendus avec un upscale KREA.AI
          Krass
          • KrassK
            Krass
            for the record, all the furniture is really at my house, but I tried to see in these images what I could fit into this apartment that I could buy....
            the character is not contractual, I have a shaved head!
            Krass
            • pixelcruncherP
              pixelcruncher Extension Creator @Mike Amos
              @Mike-Amos Very nice render!
              • pixelcruncherP
                @Krass Great renders! Glad you found a workaround. That computer screen looks believable to me.
                Image | Krea
                Generate AI images with Flux, ChatGPT, Imagen, Ideogram, and more. Upload references and choose styles — the best text-to-image models in one place.
                Krea (www.krea.ai)
                You render it grainy in a low res, and then let it upscale? Or do you enhance the images in other ways with AI?
                BTW, I found the issue, will post a fix shortly. The crash occurs when you load too many thumbnails in the asset browser.
                Cheers,
                Thomas
                • KrassK
                  Krass
                  I use AI Upscale to get a sharper render and correct details, characters, it improves materials, wood, etc.
                  Krass
                  Reply Quote 2
                  • pixelcruncherP
                    Hey, Rayscaper users!
                    Another release!
                    Rayscaper 0.9.69 Beta is available in the SketchUcation store. As
                    always, I recommend upgrading to the latest version.
                    What Changed?
                    • Fix a crash when scrolling the asset browser. - @Krass can you let me know if this version behaves better for you?
                    Help Me Build the Community 👍
                    If you like Rayscaper, please share your renders (final or work-in-progress, it doesn’t matter)! This is motivating
                    and helps me showcase its capabilities to new users.
                    Follow me on Twitter.
                    Happy Rendering!
                    Mike AmosM 1 Reply Last reply
                      Mike Amos @pixelcruncher
                      @pixelcruncher
                      Oh well, that lasted a long time did it not.
                      I cannot run Rayscaper, it is installed but, when I start the app the !render! window will not open.
                      All this happened post a diffusion update.
                      Report below.
                      Extension Errors Report
                      SketchUp: 24.0.594
                      OS: Windows 11
                      Ruby: 3.2.2
                      Extension: SketchUp Diffusion (1.2025.09.28)
                      Error: LoadError (127: The specified procedure could not be found. - C:/Users/mike1/AppData/Local/Temp/SketchUpDiffusion.so)
                      <internal:C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' <internal:C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require'
                      c:/users/mike1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/su_diffusion/su_loader.rbe:28:in <module:SketchUpDiffusion>' c:/users/mike1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/su_diffusion/su_loader.rbe:1:in <main>'
                      C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in eval' C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in require'
                      C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in load' C:/Users/mike1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/su_diffusion.rb:21:in register_extension'
                      C:/Users/mike1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/su_diffusion.rb:21:in <module:SketchUpDiffusion>' C:/Users/mike1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/su_diffusion.rb:5:in <top (required)>'
                      • KrassK
                        Krass
                        Hello, Pixelcruncher,
                        I'have installed RS 9.6.9
                        I'm testing it. When I hide a SU tag it stays visible. The only way seems to Hide a group so that it will not be visible. So: we can't use Hide/reveal Tags?
                        Krass
                          Going cold turkey, sketchup is completely uninstalled for a while.
                          • KrassK
                            Krass
                            This time I have a scene that is a bit heavy, I copied an entire apartment in duplicate and when I open RS, it is active but the window does not want to enlarge and remains stuck in the taskbar. We can see in the thumbnail that it is working on the project, it is rendering... but I also did not have a Rayscaper loading window
                            Krass
                            • KrassK
                              Krass
                              The latest version is broken for me... I installed it and I don't think I restarted SU and it worked. But now the window is stuck in the taskbar;
                              I'm going to reinstall 9.6.4 to test.
                              Krass
                              • KrassK
                                Krass
                                Ok, rayscaper is back if I use 9.6.4
                                Krass
                                  Need a revert version button.
                                    sashapepperspray @pixelcruncher
                                    @pixelcruncher any update on when the material inheritance is going to be fixed?
                                    • KrassK
                                      Krass
                                      Hello, pictures of another apartment I would like to buy, I prefer this one. the exterior is made up, it's the hdri map. but the view is really nice in truth. Rayscaper render Magnfic Upscale
                                      Krass
                                      Reply Quote 2
                                        Can someone post the .9.6.4 build please, da nada here.
                                          OK, hover the cursor over the sketchup icon on the task bar, right click on the Rayscaper window and maximise. The render window will not open elsewise.
                                            Mike Amos @Mike Amos
                                            Running the .69 build. EVERY new model loaded will require the steps above. right click on the render window on the task bar and select maximise. When this is done once per new model, session, each new start of Rayscaper will occur as per normal.5 1000s 2196 x 1071 GPU 2020016 tri 54s.png
                                            • 11
                                            • 12
                                            • 13
                                            • 37
                                            • 38
                                            • 11 / 38
