    Rayscaper New Releases
    rayscaperrender
    540 Posts 13 Posters 248.9k Views 14 Watching
      Mike Amos @Rich O Brien
      @Rich-O-Brien
      Agreed, getting this far this fast as a one man band, part time. Wow.
      Being in beta still, imperfection is a given but the ride is still good and hoping I am contributing sufficiently.
      • KrassK
        Krass
        Yes! Indeed
        Krass
        • pixelcruncherP
          Hey guys,
          Looking into the crashes.
          Hello, if I leave Rayscaper open and import a texture directly onto a face (with the import tool) it crashes
          Was this on the first texture, or after multiple imports?
          I can't create an emissive material with an image, if I increase the power the image disappears and the texture is white. I can't make a monitor screen. Can someone help me?
          Currently, Rayscaper doesn't support emission with a texture. Which image are you talking about? Maybe a screenshot of your setup helps me understand it better.
          Another crash when reopening RS and trying to apply a texture
          Looking into the crashes, I think (I hope) I found the root cause.
          I understand the frustrations, and I appreciate your help in making the software a lot better!
          Cheers,
          Thomas
          KrassK 1 Reply Last reply
          • KrassK
            Krass @pixelcruncher
            Nice render Mike!
            @pixelcruncher said in Rayscaper New Releases:
            I created a surface and imported a texture
            I found a solution to make an image emissive: for example for PC screens on the following images I make a copy of the face that must receive the image and I place it in front 2 or 3 millimeters of the initial face to which I applied an emissive. On this copy of the face I put my image as texture and I increase the Transmission slider, and it works well. (I just discovered this feature!)
            ci-dessous 3 rendus avec un upscale KREA.AI
            Krass
            • KrassK
              Krass
              for the record, all the furniture is really at my house, but I tried to see in these images what I could fit into this apartment that I could buy....
              the character is not contractual, I have a shaved head!
              Krass
              • pixelcruncherP
                pixelcruncher Extension Creator @Mike Amos
                @Mike-Amos Very nice render!
                • pixelcruncherP
                  @Krass Great renders! Glad you found a workaround. That computer screen looks believable to me.
                  Image | KREA
                  Generate AI images with Flux, ChatGPT, Imagen, Ideogram, and more. Upload references and choose styles — the best text-to-image models in one place.
                  Krea (www.krea.ai)
                  You render it grainy in a low res, and then let it upscale? Or do you enhance the images in other ways with AI?
                  BTW, I found the issue, will post a fix shortly. The crash occurs when you load too many thumbnails in the asset browser.
                  Cheers,
                  Thomas
                  • KrassK
                    Krass
                    I use AI Upscale to get a sharper render and correct details, characters, it improves materials, wood, etc.
                    Krass
                    Reply Quote 2
                    • pixelcruncherP
                      Hey, Rayscaper users!
                      Another release!
                      Rayscaper 0.9.69 Beta is available in the SketchUcation store. As
                      always, I recommend upgrading to the latest version.
                      What Changed?
                      • Fix a crash when scrolling the asset browser. - @Krass can you let me know if this version behaves better for you?
                      Help Me Build the Community 👍
                      If you like Rayscaper, please share your renders (final or work-in-progress, it doesn’t matter)! This is motivating
                      and helps me showcase its capabilities to new users.
                      Follow me on Twitter.
                      Happy Rendering!
                      Mike AmosM 1 Reply Last reply
                        Mike Amos @pixelcruncher
                        @pixelcruncher
                        Oh well, that lasted a long time did it not.
                        I cannot run Rayscaper, it is installed but, when I start the app the !render! window will not open.
                        All this happened post a diffusion update.
                        Report below.
                        Extension Errors Report
                        SketchUp: 24.0.594
                        OS: Windows 11
                        Ruby: 3.2.2
                        Extension: SketchUp Diffusion (1.2025.09.28)
                        Error: LoadError (127: The specified procedure could not be found. - C:/Users/mike1/AppData/Local/Temp/SketchUpDiffusion.so)
                        <internal:C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' <internal:C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require'
                        c:/users/mike1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/su_diffusion/su_loader.rbe:28:in <module:SketchUpDiffusion>' c:/users/mike1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/su_diffusion/su_loader.rbe:1:in <main>'
                        C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in eval' C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in require'
                        C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in load' C:/Users/mike1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/su_diffusion.rb:21:in register_extension'
                        C:/Users/mike1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/su_diffusion.rb:21:in <module:SketchUpDiffusion>' C:/Users/mike1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/su_diffusion.rb:5:in <top (required)>'
                        • KrassK
                          Krass
                          Hello, Pixelcruncher,
                          I'have installed RS 9.6.9
                          I'm testing it. When I hide a SU tag it stays visible. The only way seems to Hide a group so that it will not be visible. So: we can't use Hide/reveal Tags?
                          Krass
                            Going cold turkey, sketchup is completely uninstalled for a while.
                            • KrassK
                              Krass
                              This time I have a scene that is a bit heavy, I copied an entire apartment in duplicate and when I open RS, it is active but the window does not want to enlarge and remains stuck in the taskbar. We can see in the thumbnail that it is working on the project, it is rendering... but I also did not have a Rayscaper loading window
                              Krass
                              • KrassK
                                Krass
                                The latest version is broken for me... I installed it and I don't think I restarted SU and it worked. But now the window is stuck in the taskbar;
                                I'm going to reinstall 9.6.4 to test.
                                Krass
                                • KrassK
                                  Krass
                                  Ok, rayscaper is back if I use 9.6.4
                                  Krass
                                    Need a revert version button.
                                      sashapepperspray @pixelcruncher
                                      @pixelcruncher any update on when the material inheritance is going to be fixed?
                                      • KrassK
                                        Krass
                                        Hello, pictures of another apartment I would like to buy, I prefer this one. the exterior is made up, it's the hdri map. but the view is really nice in truth. Rayscaper render Magnfic Upscale
                                        Krass
                                        Reply Quote 2
                                          Can someone post the .9.6.4 build please, da nada here.
                                            OK, hover the cursor over the sketchup icon on the task bar, right click on the Rayscaper window and maximise. The render window will not open elsewise.
                                            • 11
                                            • 12
                                            • 13
                                            • 26
                                            • 27
                                            • 11 / 27
